Recall for Engine Block Heater - Page 6 - Chevy and GMC Duramax Diesel Forum
2017-19 GM T-K2 Platform Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
 8Likes
post #51 of 59 (permalink) Old 11-20-2019, 05:12 AM
Rvn4me's Avatar
Block heater fixed.
Recall number N192264210
9104743 Diesel Block Cord
1279 W
19419326 Cord Kit
12346290 Coolant
2019 Arctic Fox 27-5L
Rvn4me is online now
post #52 of 59 (permalink) Old 11-21-2019, 06:50 AM
Originally Posted by Rvn4me View Post
Block heater fixed.
1279 W
19419326 Cord Kit
12346290 Coolant
Good to hear! BTW, where are you located?
2017 GMC Denali HD Duramax - Deep Garnet Metallic Exterior, Cocoa/Dark Sand Interior
Kryptonite Front End Leveling Kit (UCA, Center Link, Tie Rods, Idler, Idler Arm, Idler Bracket, Pitman Arm), Fox Shocks, Bilstein Steering Stabilizer, Front Diff Drop, 20" Fuel Sledge Wheels w/ BFG T/A KO2 285/65s, 2" McGaughy's Drop Shackles, Amsoil Dual Bypass Oil Filters, MBRP Stainless Exhaust, Revolver X2 Tonneau, Morimoto XB LED Fogs, Custom Grille, Wolo Air Horns to Replace Factory Horns, Kleinn Train Horns w/ On-Board Compressor, Edge CTS2, Rostra Heated Rear Seats, Aluminum Liquid Pedals, Mag HyTec Rear Diff Cover, Clear Bra 18", Front Doors Tinted 20%/All Other Windows & Sunroof Tinted 40%, IntelliHaul mirror cameras and front cam.
paauto is offline
post #53 of 59 (permalink) Old 01-18-2020, 07:25 AM
Just curious , for all of you that have had the recall done. I bought a 2018 and the block heater had not been changed. They got it done but took almost 5 hours . I knew I was getting a load of B.S. but they had it on the rack by then. How long did they take to change out your block heater?
redhawk44 is offline
post #54 of 59 (permalink) Old 01-18-2020, 07:39 AM
LHN...We ARE the Joneses
Warranty/Recall stuff doesn't pay well.
Most will take 'em in and rack 'em, but if a good rate paying job comes in, they'll divert labor over to it and come back to the low pay job, when they get a chance.
Hook'em_Horns! is offline
post #55 of 59 (permalink) Old 01-18-2020, 08:15 AM
mine took about 2hrs.
Pete,V is offline
post #56 of 59 (permalink) Old 01-18-2020, 10:23 AM
redwngr's Avatar
Maybe the job(s) ahead took longer than expected?
Other customer(s) probably had appointments too..
Did they give you a loaner to drive so you could go about your business?
redwngr is offline
post #57 of 59 (permalink) Old 01-18-2020, 10:31 AM
redwngr's Avatar
Originally Posted by Busa Dave View Post
Confirmed with my dealer at least.
This is from my owners manual page 216..
"Engine Heater
If equipped, the engine heater can
provide easier starting and better
fuel economy during engine
warm-up in cold weather conditions
at or below −18 C (0 F). Vehicles
with an engine heater should be
plugged in at least four hours before
starting. An internal thermostat in
the plug-end of the cord may exist,
which will prevent engine heater
operation at temperatures above
−18 C (0 F)."
MAY is the key word.
FWIW, I don't use the block heater (and don't see temps below 0*F very often, but lots of 0*F to 10*F).
I'd much rather let 'elevated idle' do it's thing and warm the transmission as well as the coolant.
Typically this creates the warmest trans oil temperature of the day.
redwngr is offline
post #58 of 59 (permalink) Old 01-18-2020, 10:44 AM
Warm coolant via the heater, heats the trans fluid quicker.
post #59 of 59 (permalink) Old 01-18-2020, 11:24 AM
No loaners, but they knew they were about to lose my business so they threw in 5 oil and fuel filter changes. I told them I wouldn't sign the papers until they finished the job. I almost thought they didn't have the parts and were waiting to get them in. Who knows?
Similar Threads
Engine Block Heater cpscott20 01-04.5 LB7 Duramax Powertrain 17 11-14-2017 08:19 PM
block heater plug at block? Dmaxed426 01-04.5 LB7 Duramax Powertrain 8 11-29-2011 06:23 PM
Please help me find my "engine block heater" cord. Oil-Burner 2007.5 + (GMT 900) Non Powertrain--New Body Style-- 5 12-10-2009 05:10 PM
Block Heater...? Is there a clip or something that holds the cord to the heater. Luv4chaos1 01-04.5 LB7 Duramax Powertrain 4 11-01-2008 09:01 PM
Engine Block Heater white rhino General Discussion 1 01-04-2008 05:42 PM
