2018 Leveling Question - Page 2 - Chevy and GMC Duramax Diesel Forum
2017 - '19 (Non Powertrain) Discussion of 2017 - '19 topics not related to powertrain
 3Likes
post #11 of 24 (permalink) Old 09-24-2019, 06:47 PM
Ron505's Avatar
Originally Posted by mizterwizard View Post
Because it is so easy to do, lots of people crank up their keys. Since they are cheap and everybody sells them, lots of people use lifting keys. Either one will mess up the suspension and make the truck less stable, less controllable and will wear parts faster.
The stock suspension is designed to change the camber so that the top of the tire moves in when the suspension extends and compresses. This keeps the tire contact patch in the same place so that the tire doesn't have to scrub sideways every time the suspension moves. When you mess with the keys it changes this action and the tires wind up skidding sideways a little every time the suspension extends or compresses.
If you only raise or lower the truck a little, say an inch, the effect is small but if you go much further it becomes more and more pronounced. If you try to raise the suspension to clear very large tires on over-sized wheels the cumulative effect will be negative for ride, control, safety and durability. That isn't to say that the truck will fall apart, break your spine or kill you the first time you drive it. It is a matter of degrees.
The good way to lift a truck is to cut off the original suspension and weld it or another suspension lower on the frame. If you do it right the engineering remains correct so that it works properly. This would be expensive though so few people do it.
The alternative is to swap in some aftermarket parts that reduce the negative effects of lifting. Among those effects are the location and travel of the ball joints. The UCA does not mount level on the frame. It is slightly higher at the front than it is at the rear so that when the suspension compresses the ball joint moves backwards a little. This increases castor and trail to compensate for the tendency of the truck to dive under braking.
A lifted truck with stock UCAs will have excessive castor and trail unless it is realigned properly but then it won't change the castor and trail as it is supposed to do. An aftermarket UCA can reposition the lifted ball joint so that it is in the right place with more normal alignment settings.
Additionally the stock UCA holds the upper ball joint so that it will have full travel in normal use. When the truck is lifted much of the extension travel is used up by the lift. The ball joint will not be able to bend enough to allow full suspension travel on a lifted truck. An aftermarket UCA will re-angle the ball joint so that it allows full suspension travel. The lower ball joint doesn't hit this limit until you lift it a bit further.
A better way to lift a truck is with new knuckles. You can get several inches of lift by having the hub mount lower in the knuckle. Then a couple of inches of lift in the tires and wheels and you may have all you need. Knuckles are not all that expensive.
I'm not recommending anything in particular but here is a kit for a reasonable price that goes with knuckles:
https://www.americantrucks.com/rough...ste-chevy.html
That kit is for a 1500 so it doesn't directly apply but if you look you will find something that does.
The front axle shafts work best if they are level. Lifting the truck causes them to bend down a bit. The more you lift the worse it gets. The CV joints in the shafts have ball inside that transfer power from one side of the joint to the other. When the shaft is straight the balls hardly move but when it is bent they move a lot. The more they move the faster they wear.
CV joints have limited flex. It is sufficient for normal use but when some of it is used up to compensate for the suspension being lifted then there is less left for steering. What can happen is that the joint will reach it's limit in a turn and then you will go over a bump that either causes the wheel to turn a bit more or the suspension to extend further. The result of a joint in bind that is forced to go further is a multi-piece axle shaft that doesn't transmit power any more. The fix is to relocate the front differential so that the axles are level most of the time.
I'm new to the 2500 world, but there sure doesn't seem like a lot to chose from when going the knuckle lift route with a 2500. Most seem to be 4"+, no?
Ron505 is offline
post #12 of 24 (permalink) Old 09-24-2019, 10:16 PM
I just leveled my 2019 3500HD DRW. 1.5 inches by adjust torsion bars. Also installed bilstein 5100 1.5" taller shocks. It didn't effect ride quality and still has a slight brake. Looks great with stock wheels tires.
2019 3500HD LTZ, silver ice, CC/LB DRW, 4x4.
2008 Lance 1181 Camper.
1993 Reinell Offshore 23'.
SS_Sean is offline
post #13 of 24 (permalink) Old 09-25-2019, 05:12 AM
Ron505's Avatar
About how many turns on the torsion bars was that (1.5")?
Ron505 is offline
post #14 of 24 (permalink) Old 09-25-2019, 02:39 PM
denarli6.6's Avatar
Mine was about 4 turns when i did mine, but each truck will be different. Best way to do it is to take your initial dimension from center of wheel to bottom of fender then adjust accordingly. Once you get it close go drive it around for a min then check dimension again to see if you need to adjust. make sure you jack the truck up tho when adjusting.
Ron505 likes this.
2016 LML Denali 2500
Reverse level with Mcgaughy's 2" drop shackle
Bilstein 5100 all-around
22x10 American Force Flux black w machined
Wehrli S300 kit w/ 66mm SXE
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
Off-road Only
denarli6.6 is online now
post #15 of 24 (permalink) Old 09-27-2019, 12:27 PM
mizterwizard's Avatar
I don't have any specs for the 2019 trucks but on my 2008 the factory spec allows for half an inch of change. Experience suggests that 1" never causes a problem. Depending on how sensitive a person is perhaps a 1.5" torsion bar lift would still be neutral. It's when people go for 3-5 inches of lift in the front that things get out of hand.
However there are people who claim that they can tell a difference with even an inch up or down. I had a Nissan with torsion bars years ago. I lowered it 2 inches and the ride was seriously compromised. I kept it that way for several years and when I put it back to stock I was amazed how much better it felt.
I have no position to mandate how anyone plays with their suspension, thank goodness. I advise people to make informed decisions and then be happy with them.
I guess it all depends on why you are messing with the suspension but it seems to me if you spread the changes over multiple methods you are least likely to get into difficulties. An inch from tires, an inch from torsion bars, an inch in the body, etc.
People used to like high rear ends. I had a neighbor who lifted his Mustang until it road around with maxed out shocks most of the time. I thought it was a big mistake but he thought it was great. Today there doesn't seem to be any consensus what is good and what is bad. I guess that is a good thing. I just want people to know what they are doing when they mess with their suspension.
mizterwizard is online now
post #16 of 24 (permalink) Old 09-28-2019, 10:04 PM
757ian123's Avatar
I just "leveled" my truck (in quotes because the back is still higher despite cranking the hell out of my keys) using aftermarket keys and shock extension brackets. When I first installed the keys, I had it set at maybe 1.5"-2" of lift. The ride stiffened up, but in a good way. Less bouncy and my steering felt more firm also. It was great.
However, I like tires that hang halfway out past my fenders so I had to crank the keys up to about 2.5" of lift to avoid hacking up my bumper. At this point, my ride is very stiff and my right control arm is almost sitting on the bump stop (the droop limiter on the frame). Oddly enough, my driver's side has plenty of clearance even though I measured both sides of the truck and they are the same.
So in conclusion, if you plan on going past 2" I would recommend the aftermarket control arms, and also keep in mind you are going to sacrifice some ride quality from having the bars cranked up that much.
The other thing I wonder, is what about the steering angles coming off the gearbox? Is there no way to compensate for those when we lift/level? And if not, does it matter?
2019 GMC Sierra 2500HD SLT
757ian123 is offline
post #17 of 24 (permalink) Old 09-29-2019, 05:23 AM
Banned
I have a 2018 and have turned up my torsion bars just a small amount (which I needed to help clear tires) but I would not want to max them out due to ride quality. I am also getting ready to buy UCA's and tie rods so I know that stuff is not the cheapest but as others have said its the only real way to go (especially if you will be towing in my opinion)
rboyd5589 is offline
post #18 of 24 (permalink) Old 09-29-2019, 06:01 AM
Ron505's Avatar
Ian, check out a PISK kit.
Ron505 is offline
post #19 of 24 (permalink) Old 09-29-2019, 08:57 AM
NHfireDmax's Avatar
I'll be using the RC 3.5" kit to lift my 2019. I am adding aftermarket tie rod ends as well... I've used this kit on my 2013 w success... It has 1.5" blocks in the rear, and I don't crank the new keys fully to keep a rake as I tow often...
2019 Quartz Red Denali HD Chrome deleted
NHfireDmax is offline
post #20 of 24 (permalink) Old 09-30-2019, 07:42 PM
757ian123's Avatar
From what I understand, that is just a brace for the pitman and idler arms. I don't think it does anything to correct the angles
