5th Wheel Prep Reviews - Page 3 - Chevy and GMC Duramax Diesel Forum
2017 - '19 (Non Powertrain) Discussion of 2017 - '19 topics not related to powertrain
 3Likes
post #21 of 28 (permalink) Old 08-01-2019, 11:06 PM
redwngr's Avatar
Originally Posted by RichieRichZ06 View Post
The GM kit I have and the Curt kit I have are exactly the same. The GM accessory kit (84000461) came in the same plastic carrying case and had the Curt part number (60692) on the label. I've towed a 19k pound goose neck trailer over 30k miles with it and no issues.
You have a 2020?
How do you like towing with it compared to earlier models?
redwngr is offline
post #22 of 28 (permalink) Old 08-13-2019, 04:48 PM
2020 2500 Sierra Crew Cab with Factory prep
Five holes in total
From the front of the bed the first pair is 37" aft of the front of the bed, the gooseneck hole is 8"behind the first pair. The second pair is 13" behind the first pair. There is 21" between each pair and from the inside of the bed at the wheel well the first hole is hole is 16" inboard. Obviously the same on the other side.
If your going to pull a 5er in the next month you need to convert to one of the gooseneck hitches.
I just installed an Anderson Ultimate CONNECTION along with an Andersen 3249 connection kit. Everything fits and works as advertised. I tried a Curt 60692 for the chains and ran into a massive problem with clearance of the Curt loops from the Andersen hitch. Seethe Curt kit back. The gooseneck location is further aft than my 2013 by at least 3 inches. The 2020 will get bags as soon as they are available as it squats 2.5 inches with the 5er hooked up. ANY 2019 GMC GOOSENECK BALL FITS IN A 2020 DESPITE LOTS OF MISINFORMATION FROM MULTIPLE SOURCES OUT THERE. I do not know if I am completely sold on the Anderson so far. I have not trailered with it yet and leave tomorrow morning for 10 days. Hooking up the Andersen in the drive is a bit more of a pain than my old B&W to get the gooseneck ball fore and aft the correct amount. The in bed camera is not much help but I need to take some time to see if I can make a few alignment marks to make it easy. The second concern I have is having to raise the front of the 5er about 5 inches to get off the hitch. 2.5 inches on the squat and 2.5 inches of the ball. Half of that will go away when I get the bags on it. I will post a big report once I get trailering. I put in the break in miles and so far like the truck. the 10 spd takes a bit getting use to but there are tons of really nice features that my old truck did not have.
spflyfish is offline
post #23 of 28 (permalink) Old 08-13-2019, 05:22 PM
I bought a 2020 Denali Crew Cab five days ago. I just installed an Anderson Ultimate CONNECTION along with an Andersen 3249 connection kit. Everything fits and works as advertised. I tried a Curt 60692 for the chains with the Andersen hitch and ran into a massive problem with clearance of the Curt loops from the Andersen hitch. Sent the Curt kit back. The gooseneck location is further aft than my 2013 by at least 3 inches. I posted the new dimensions in another thread. The 2020 will get bags as soon as they are available as it squats 2.5 inches with the 5er hooked up. ANY 2019 GOOSENECK BALL FITS IN A 2020 DESPITE LOTS OF MISINFORMATION FROM MULTIPLE SOURCES OUT THERE. I do not know if I am completely sold on the Anderson so far. I have not trailered with it yet and leave tomorrow morning for 10 days. Hooking up the Andersen in the drive is a bit more of a pain than my old B&W to get the gooseneck ball fore and aft the correct amount. The in bed camera is not much help but I need to take some time to see if I can make a few alignment marks to make it easy. The second concern I have is having to raise the front of the 5er about 5 inches to get off the hitch. 2.5 inches on the squat and 2.5 inches of the ball. Half of that will go away when I get the bags on it. I will post a big report once I get trailering. I put in the break in miles and so far like the truck. the 10 spd takes a bit getting use to but there are tons of really nice features that my old 2013 truck did not have.
post #24 of 28 (permalink) Old 08-13-2019, 05:22 PM
Five holes in total
Take a tennis ball, slice it abut 1/2, 2/3 the way around it. Poke a small, stiff wire through the ball (I used a wire marking flag) opposite the slice. Push the wire through, bend it over so it cannot pull back out then wrap some red electrical tape or, flagging, etc around the wire opposite of where you bent it (if you didn't use a marking flag). Now, whenever you hook up the Andersen, pop the ball over the Andersen ball with the flag sticking up. Back the truck up to the funnel until the wire bends toward the cab of the truck, get out, remove tennis ball and lower the funnel onto the Andersen ball.
2008 GMC Sierra LMM CCSB LTZ
walleyerod is offline
post #25 of 28 (permalink) Old 08-13-2019, 05:40 PM
Here are some pics of my 2020 hooked up.
post #26 of 28 (permalink) Old 08-13-2019, 08:13 PM
powerhaulic's Avatar
Nice rig, good luck
2020 Sierra AT4 3500 Duramax
2018 Denali 2500HD L5P Derringer equipped
2018 Montana 3811MS Legacy 16400#2900pin
powerhaulic is offline
post #27 of 28 (permalink) Old 08-15-2019, 12:08 PM
B&W has a goose neck turnover ball hitch for the 2020 GMC/Chevy 2500 and 3500 trucks! Nothing from Curt yet, which is the one I prefer and will get when the time comes, probably next year.
Here it is. (B&W) https://www.bwtrailerhitches.com/hit...der?cshs=20137
post #28 of 28 (permalink) Old 12-17-2019, 01:03 PM
Rvn4me's Avatar
Looks good. We have the 2019 27-5L
2019 Arctic Fox 27-5L
Rvn4me is offline
