2018 Hard Shifts - Chevy and GMC Duramax Diesel Forum
2017+ L5P Duramax Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
 3Likes
post #1 of 25 (permalink) Old 08-06-2019, 12:17 PM Thread Starter
2018 Hard Shifts
2018 CCSB High Country.. Built late Feb 2018. 14,000 miles, bone stock. Dealer serviced, fluid level is ok hot, just over the high mark. Not towing, not using tow/haul mode or exhaust brake.
I keep getting some firm shifts on random days, but can't get it to do so for the dealer.
Seems completely random, but is especially noticeable 3-4 and 4-5.
This seems to happen mostly when the trans is up to temp (160-180 depending on how hot it is here)
Dealer says I'm all up to date on software and calibrations
Any thoughts?
4wdaaron is offline
post #2 of 25 (permalink) Old 08-06-2019, 12:45 PM
Someone with more knowledge might have a better idea, but I would take a pint of fluid out. The Allisonís donít like to be over serviced.
hdrolling and Sierraluva like this.
MIkey52 is online now
post #3 of 25 (permalink) Old 08-07-2019, 04:50 AM
My 2019 2500HD Z71 has had hard shifts since day one! Took it back to the dealer within a few days of purchase and was told it was NORMAL! Was told the new vehicles shift all over the place, not to worry about it! Yah Right! Just spent $65,000.00 for a harsh shift when my old 95 4L80E still shifts smooth as silk! GM needs to FIX their problem. Truck now has about 6500 mi. on it and it has not changed. It also has a shudder under heavier acceleration. A lot of people here on this forum claim the fluid change to TES-295 really helps. I think I am going to try the fluid change. If I had to do it all over again and know then what I know now, I would not have bought the truck!
Highmaster is offline
post #4 of 25 (permalink) Old 08-07-2019, 04:53 AM
hdrolling's Avatar
I would do the same, better to be a little below the hot mark vs above it.
My 18 shifts great.
Sierraluva likes this.
2018 3500HD LTZ DRW
My build thread https://www.duramaxforum.com/forum/b...lly-build.html
GM DRW club member #224
hdrolling is offline
post #5 of 25 (permalink) Old 08-07-2019, 06:07 AM
redwngr's Avatar
Mine has the random 'harsh' shifts the OP reports - I think the 4-5 is the most common one on mine, and with normal or slightly above acceleration into traffic. Not harsh enough that I think it is causing damage, but harsh enough to be annoying.
So far, I also can't produce them at will. It has about 20,000 miles, but has done it regularly since new.
I've not been able to correlate it to trans temperature (but I rarely see 180 on mine)
Did take the dealer tech that does the Allison work (and drives one of these) out -- but of course it didn't do it. As I'm writing this I wondering if that was because we were driving in the city, so speeds may not have been high enough to get 4-5 occurring at a high enough rpm for it to happen - time for some experimenting.
None of the previous dmax/allies I've run did anything like this.
redwngr is offline
post #6 of 25 (permalink) Old 08-07-2019, 09:02 PM
Well add me to the list ...my 2018 has done this since day one. Everytime I bring it in for service or anything I make them document it so when I'm out warranty and this tranny kicks the bucket I can refer back. It never does it for them. I have 53K on my truck. Actually doesn't seem to do it in Tow/Haul Mode when I'm towing my travel trailer.
Denali2012HD is offline
post #7 of 25 (permalink) Old 08-08-2019, 12:24 PM
Mine only does it once in a while and usually only right before coming to a complete stop.
2019 GMC Denali HD 3500 SRW Tri-Frost
-S&B Filters CAI
-Bilstein 5100s
-Mountain2Metal Tranny Cover
MrGraff is offline
post #8 of 25 (permalink) Old 08-08-2019, 02:40 PM
redwngr's Avatar
Mine does than one sometimes too. Like it didn't get the torque converter unlocked soon enough.
To me, it doesn't feel like it's the same issue as the 4/5 shift.
redwngr is offline
post #9 of 25 (permalink) Old 08-08-2019, 04:09 PM
theJman's Avatar
My 2018 does it as well. It doesn't always happen, and the amount of harshness varies too. It's very schizophrenic.
2018 GMC Sierra 2500HD, DMAX, CC, 4WD
theJman is offline
post #10 of 25 (permalink) Old 08-09-2019, 11:09 AM
my 15 has harsh shudder shifts from 2nd-3rd it is intermittent and i can not replicate or cause it. but i can also not find a solution to it.
2015 Duramax LmL
5" exhaust no Muffler
PPEI 5 stage Tuner
Fass 150 lift With Sump
Edge Insight cts2 With EGT Probe
Big Daddy Yum Yum is offline
