Oil change - Page 5 - Chevy and GMC Duramax Diesel Forum
2017+ L5P Performance Parts Discussion Discussion of Performance Parts For the '17 and up L5P Duramax Trucks No Advertising
 20Likes
post #41 of 49 (permalink) Old 04-06-2019, 08:38 PM
Thumbs up
Originally Posted by redwngr View Post
All this info is in the owners manual.
If it's missing (or you want one for a different vehicle or year), a pdf version can be downloaded from GM's website
Driver Information Centre
The version depends on the trim level of the truck.
Information Displays
Driver Information Center
(DIC) (Base Level)
The DIC displays are shown in the center of the instrument cluster.
The displays show the status of many vehicle systems.
The trip odometer reset stem in the instrument cluster is used to access the DIC menu items.
DIC Menu Items
Turn the trip odometer reset stem to scroll through the following menu items:
. Digital Speedometer
. Trip
. Fuel Range
. Average Fuel Economy
. Tire Pressure
. Remaining Oil Life
. Transmission Fluid Temperature
. Trailer Brake
. Hourmeter
. Unit
Skipping the sections that expalin each section, and how to make changes...
(DIC) (Uplevel)
The DIC displays are shown in the center of the instrument cluster in the Info app.
See Instrument Cluster on page 5-10.
The controls for the DIC are on the right steering wheel control.
Up or down arrows : Press to move up or down in a list.
In the main view, you can press up and down to move between different info app pages
L or R arrows : Press to move between the interactive display zones in the cluster. menu or select a menu item.
Press and hold to reset values on certain screens.
On uplevel DIC, you may can go to the 'Info Page Options' to select which items will be viewable when you scroll thru the pages using the up/down arrows on the steering wheel.
It might be necessary to 'turn on' or 'enable' the hours page.
Thanks for that detail and it really was a stupid question. I will check it out and learn all sorts of new things. Now if I can only remember what I learned.
gpadoug is offline
post #42 of 49 (permalink) Old 04-07-2019, 04:22 PM
basic division?
Originally Posted by LMLLover View Post
My LML has 115,000 miles, and 3050 hours. That equals a average of 38 mph ,every hour, over the life of the truck.
38 mph x 250 hours = 9500 miles. Sounds about the right time to change it.
his truck only has 5200 miles divided by 250 hours equals only 20mph.
philstat is offline
post #43 of 49 (permalink) Old 04-07-2019, 04:29 PM
EmmettTheL5P's Avatar
https://my.chevrolet.com/content/dam...supplement.pdf
2017 Chevrolet 3500HD (L5P)
CM SK Aluminum flat bed
EmmettTheL5P is offline
post #44 of 49 (permalink) Old 04-09-2019, 02:31 PM
Gregarek's Avatar
215 hours on my truck
Gregarek is offline
post #45 of 49 (permalink) Old 04-09-2019, 04:22 PM
LHN...We ARE the Joneses
Comin' up on 7k hrs.
EmmettTheL5P likes this.
Hook'em_Horns! is online now
post #46 of 49 (permalink) Old 04-09-2019, 05:16 PM
nutdriver's Avatar
Ultimately, the oil life monitor is a tool. Sounds like there is some variation in how this is calculating when our oil is in need of a change. I will probably stay conservative on my oil changes and in line with the monitor at least until I can pull a couple used oil samples for analysis and see how the engine is actually doing.
2018 Duramax GMC 2500 5500 miles
2006 VW Jetta TDI 265,000 miles
2000 VW New Beetle TDI Totaled by deer at 165,000 miles
nutdriver is online now
post #47 of 49 (permalink) Old 04-09-2019, 05:33 PM
I run 9000 full syn, all the way down to 0% on the DIC ('bout 10k miles)....then when I get time, I sample for EOA and change it.
All of the analysis reports say I should be running it longer.
CntrlCalDmax likes this.
post #48 of 49 (permalink) Old 04-10-2019, 08:44 AM
Itís hard for me to change oil at 5k. Iím a old guy that has driven roughly 50k annually most of my life and change all my vehicles between 7500-10k using Dino or non-synthetic oil. Most every vehicle Iíve owned went 250k or more miles before I sold it and none had engines issues etc. Based on this and doing the occasional oil analysis I see no reason to piss money away on oil thatís still has life left in it. If I drove only short distances with a lot of idling etc I might do the 5k changes.
Sent from my iPhone using Tapatalk Pro
LMLLover likes this.
Sawtooth is offline
post #49 of 49 (permalink) Old 04-11-2019, 03:35 PM
The bottom line is use the best oil you can buy and run it until the DIC shows you need to change. I run full synthetic in my LLY and all the rest of my vehicles (5). My DIC lets me run at least 10K and I'm not worried about it at all. I went to full synthetic in 1980 just to allow me to run my trucks for a full year on an oil change. I had been in the garage about once a month changing oil and it was just a drag. I have never had a failure of any kind with full synthetic! My 2006 LLY now has 225K along with 3 trips from NM to AK pulling my 5th wheel.
Just do it and stop worrying about how long you should run it. Warranty or not, GM can't force you to change it when their DIC tells you to do so. Only an oil sample can be used to show you oil is bad and unless you are driving it like hell, full synthetic oil will always give you the best under all circumstances. A few bucks more....but many less oil changes. Just do it.
nmjack is offline
Similar Threads
Oil Change vs DIC Oil Change % Values Salyers72Max$ 2017+ L5P Duramax Powertrain 7 06-18-2018 08:17 AM
please help have an oil cooler and about to do an oil change how much oil? hummerh1 General Discussion 8 01-14-2014 01:09 PM
change engine oil and change fuel filter messages TMFC Dirtymax Maintenance 3 01-26-2011 03:49 PM
Oil change and transmission fluid change Methu969 General Discussion 7 01-05-2009 06:32 PM
Message center says need to change oil just after oil change woodwise 01-04.5 LB7 Duramax Powertrain 9 10-09-2007 06:45 PM
