Installing Tow Mirrors - Chevy and GMC Duramax Diesel Forum
2017+ L5P Performance Parts Discussion Discussion of Performance Parts For the '17 and up L5P Duramax Trucks No Advertising
post #1 of 8 (permalink) Old 05-24-2019, 03:54 AM Thread Starter
All,
I didnt have any luck searching this out, so if there are threads on it, please point me in the right direction.
Im looking to replace the small stock mirrors with the OEM optional tow mirror on my 19'. I originally wanted to have the dealer do this for me when i bought the truck, however, they said the OEM mirros are over $1,000 to buy, and another $1200 to install - this seems incredibly high to me.
So, id like to see if any of you have done this, and how much of a PIA this is, also if anyone has a good connection to buy the OEM mirrors from that would be appreciated as well, i dont want aftermarket in this case. I was a race mechanic back in the day, so im not afraid to do this myself its just the dealer making this sound like its some huge project - how bad can it be, its only mirrors?
Thanks for the help!
Dirty5P is offline
post #2 of 8 (permalink) Old 05-24-2019, 08:20 AM
marcy's Avatar
not exactly what youre asking...but i just put new style mirrors on a friends 05 duramax...they are all the same. remove the door panel and theres 3 nuts you have to remove off the studs coming through the door. once you remove them the mirror will come out. wiring and connectors should will all the same if you currently have signal mirrors.
2006 duramax- stock
marcy is offline
post #3 of 8 (permalink) Old 05-24-2019, 08:27 AM
marcy's Avatar
dont know how to edit or delete my post. just noticed you have a '19 probably different... ignore me! haha
2006 duramax- stock
marcy is offline
post #4 of 8 (permalink) Old 05-24-2019, 12:24 PM
codivm's Avatar
Originally Posted by Dirty5P View Post
All,
Just gotta tell them your going somewhere else than and they will bend over for you.
Sent from my SM-N960W using Tapatalk
codivm is offline
post #5 of 8 (permalink) Old 05-24-2019, 01:01 PM
redwngr's Avatar
Try the 'non-powertrain' section, instead of 'performance parts discussion',
Lots of mirror threads in both L5P and LML non-powertrain sections. Topic became extra popular when the new style mirrors were released.
Be sure to get mirrors with temp sensor in the passenger mirror -- it's the one used for ecm.
Dmax also has the one in the grill, like the gasser, but it's for temp display and HVAC
redwngr is online now
post #6 of 8 (permalink) Old 05-28-2019, 05:26 AM Thread Starter
Will do! Thanks redwngr!
Dirty5P is offline
post #7 of 8 (permalink) Old 05-28-2019, 06:00 AM
toddmeister's Avatar
This topic over at gm-trucks will provide lots of info.
Phil Gamboa is the mirror expert over there.
https://www.gm-trucks.com/forums/top...omment-2254710
2016 GMC 2500HD SLT All Terrain CC SB 4x4 D/A 26K
1995 GMC 2500 EC 4x4 6.5TD,223K,Amsoil bypass filter,Max-E-Tork chip,HX40W-II Turbo,KD Exhaust,FSD Cooler,KD Headlight Booster,Hi-Cap Cooling
toddmeister is offline
post #8 of 8 (permalink) Old 06-15-2019, 09:14 PM
I installed OEM tow mirrors on my '17 LT myself after buying my truck without them. Why do they even sell HD trucks without them?!
Anyway, I bought them off ebay for $568. Then you have to buy door wiring harnesses. I think i found both sides from an online store for around 150 total. Mirrors are easy to replace. Wiring harnesses aren't terrible, but it was more than i expected. You have to pull the door panel off and get inside the door to switch those out. With a youtube video to help i was able to not break anything.
What trim level do you have and what type of mirror do you plan to use? I have the LT and went with the LT style mirror. The LT tow mirrors have power adjust and defrost, but the higher trim mirrors also have power fold and maybe extension, i don't know off-hand.
If you have an LT and want full power mirrors you would need to change the switches out in the door panel to add the switches you need, in addition to the wiring harnesses.
kenman is offline
Similar Threads
How to swap out tow mirrors for non tow Denali mirrors DocsTa 2017+ L5P Duramax Powertrain 6 03-18-2018 02:47 PM
Help! No power windows or locks after installing tow mirrors! westhall55 Gauges, Electronics and Wiring. 3 09-06-2013 08:27 AM
wtt: Accordian tow mirrors for big tow mirrors belly_up Looking For/ Wanting To Buy 0 08-08-2010 11:53 AM
Installing tow mirrors NJDuramax Exterior 6 03-13-2010 11:59 AM
