10 Speed towing - Chevy and GMC Duramax Diesel Forum
2020+ GM T1 Platform Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission, Etc.
 13Likes
  • 3 Post By carhauler
  • 1 Post By CDN Curtis
  • 3 Post By RichieRichZ06
  • 1 Post By sdelam
  • 2 Post By powerhaulic
  • 1 Post By redwngr
post #1 of 9 (permalink) Old 12-15-2019, 05:44 PM Thread Starter
Shov's Avatar
10 Speed towing
With the 6 speed I would lock out 6th gear while towing. Now with the 10 speed what gears will I need to lock out while towing my 5th wheel at about 14,500 lbs? TIA
2016 Chevrolet 2500 CC/SB LTZ Z71
745 miles and climbing
B&W Gooseneck w/Companion
2013 Honda CrossTour, 2006 GMC 2500 LBZ (sold), 2003 GMC LB7 CC/LB (sold) , 2012 Keystone Alpine 3600RS
Shov is offline
post #2 of 9 (permalink) Old 12-15-2019, 09:47 PM
carhauler's Avatar
The truck when in tow/haul likely knows best , just leave it alone and see.
Shov, CntrlCalDmax and Dmax affair like this.
2019 Chevy Dually Door handles/color matched 110 Gal transfer-flow bed tank / 20"AE wheels Mich. 265/60/20 defender tires /husky rear flaps /cargo box/weathertech mats.tinted glass, xpel on forward surfaces, blacked out pillars
carhauler is offline
post #3 of 9 (permalink) Old 12-18-2019, 11:23 AM
CDN Curtis's Avatar
Had the chance to pull my 5th a couple times before the snow came. Same weight (14,500 lbs) Put the truck in Tow/Haul and let the 10 spd do its thing. Pulled like a dream!
Shov likes this.
2020 GMC HD Denali SRW Onyx Black
2018 GMC HD All Terrain : SOLD
CDN Curtis is offline
post #4 of 9 (permalink) Old 12-18-2019, 11:55 AM
I've pulled ~17k pounds (43' Featherlite triple axle dual car race trailer) several times and I find the truck is happiest in 9th gear at any speed from 60-75 MPH on flat land. It locks the converter, trans temps stay low and the fuel mileage is best. I found that pulling any good grade at those speeds will require 7th gear for the truck to effortlessly pull it. I haven't encountered any steeper grades that require 6th gear or lower unless some jackass pulls out in front of my while climbing and I have to significantly slow down. Most insignificant grades can be pulled in 8th gear.
I was skeptical of the 10 speed after having a couple L5P trucks with the 6 speed Allison. I would not go back to the 6 speed for anything after spending 13k miles in the 2020 truck. The 10 speed does way less goofy stuff, shifts better under normal conditions (especially tipping in the throttle at lower speeds) and doesn't have the flare with harsh shifts the 6 speed did on occasion.
I have noticed that fuel mileage was slightly better with the 6 speed unloaded, but towing MPG is slightly better with the 10 speed.
Shov, nealmax66 and Gdady90 like this.
RichieRichZ06 is offline
post #5 of 9 (permalink) Old 12-18-2019, 01:07 PM
sdelam's Avatar
I have a 9-10k toy hauler and I put it in tow/haul and let it do its thing. Pulled through plenty of 5-6% grades without any issues.
Shov likes this.
2020 Denali 2500 Duramax Crewcab 4x4
sdelam is offline
post #6 of 9 (permalink) Old 12-19-2019, 05:59 AM
powerhaulic's Avatar
5er weight is 16700#, went 1300mi, all in D, tow haul on.
Really tows better than the 6spd period hands down.
just drive it, let the electronics do their job.
Shov and nealmax66 like this.
2020 Sierra AT4 3500 Duramax
2018 Denali 2500HD L5P Derringer equipped
2018 Montana 3811MS Legacy 16400#2900pin
powerhaulic is offline
post #7 of 9 (permalink) Old 12-22-2019, 02:59 PM Thread Starter
Shov's Avatar
Thanks everyone for the feedback! Put her in D and Tow Haul Mode and let it do its thing is what Iíll be doing!
Shov is offline
post #8 of 9 (permalink) Old 12-22-2019, 08:22 PM
redwngr's Avatar
And turn on the exhaust brake!
Shov likes this.
redwngr is online now
post #9 of 9 (permalink) Old 12-24-2019, 07:49 AM
The 2020 even reminds you to do so.
Shov and redwngr like this.
