Supplemental cabin heater - Chevy and GMC Duramax Diesel Forum
2020+ (Non Powertrain) Discussion of 2020+ topics not related to powertrain
 3Likes
post #1 of 17 (permalink) Old 01-17-2020, 02:59 PM Thread Starter
Am I correct in remembering the new trucks come with a cabin heater like what is standard on the Rams and optional on Fords?
No idea where I heard or read that, or if I even did, but can't find it now.
nick112288 is offline
post #2 of 17 (permalink) Old 01-17-2020, 07:06 PM
LHN...We ARE the Joneses
I recall seeing a notation of it as an option.....made me think back to old '60s land cruisers.
Hook'em_Horns! is offline
post #3 of 17 (permalink) Old 01-18-2020, 10:24 AM
407driver's Avatar
I had a 69 and later a 72 FJ40 LCs. I had forgotten all about that heater til you mentioned it.
Those were some really good rock crawlers.
407driver is offline
post #4 of 17 (permalink) Old 01-18-2020, 10:41 AM
This one came from the Bahama's......wheel on the wrong side, 3-on the column, etc.
Metal everywhere, inside and out, T handle hood fasteners, I-6 gas....would climb up a wall with only bald tires. Top speed wasn't much more than 50, uncomfortable as heck...tool box under the pass side seat was neat.
post #5 of 17 (permalink) Old 01-18-2020, 02:25 PM
407driver's Avatar
My 69 was "Three on the Tree" too. That 6 was such a close copy of an old Chevy 235 that you could use the better Chevy valves if you did a valve job.
Converted mine to a floor shift in conjunction with dropping a 327 in it. Didn't speed it up on the top end any but it was really a beast!
post #6 of 17 (permalink) Old 01-19-2020, 03:54 PM Thread Starter
Well that derailed haha
post #7 of 17 (permalink) Old 01-19-2020, 04:20 PM
Ya know, now that I think about it, it may have been on the new Medium Dutys as an option.
post #8 of 17 (permalink) Old 01-19-2020, 07:17 PM
redwngr's Avatar
I don't recall it being mentioned on a thread.
I've been looking hard at the order guide, the design/build site, reviews, vids etc, trying to determine if I should update and I've seen no mention of an optional heater.
I do recall a thread discussing how long a GM can be left idling. Someone was wanting to keep it warm for a pet or something -- and reported being unhappy that the truck would auto-shutdown. (don't recall if it as a gas or diesel, or 15 or 25/35 -- but it was a pickup rather than a car or medium duty)
If it's a must have, perhaps a Wabasso or some other aftermarket system. Cabin heat or cabin + coolant heat systems available. Common in heavy truck applications.
redwngr is online now
post #9 of 17 (permalink) Old 01-20-2020, 02:07 PM
All Duramax equipped HD trucks do have an electronic heating element that helps provide warmer air from the vents more quickly. Here is the description from GM...
Auxiliary Electric Heater
Vehicles equipped with a diesel engine come with an auxiliary electric heater. This 12V electrically powered heating element is positioned directly behind the regular coolant flow based heater core in the HVAC case. All airflow goes through the regular heater core first, and then through the auxiliary electric heater. The auxiliary electric heater is active when the outside ambient temperature is below 8C (46F) , the coolant temperature is below 75C (167F), and the temperature air mix door is near the full hot position.
redwngr and Tom Anderson like this.
RichieRichZ06 is offline
post #10 of 17 (permalink) Old 01-20-2020, 03:19 PM
redwngr's Avatar
Thanks!
Certainly makes sense, but I'd not heard this before.
Not auxiliary in the sense of operator controlled, or an add-on to be selected at order -- but works in addition to the coolant system.
No wonder the windows clear as soon as they do.
Is the info from somewhere in the upfitter docs or perhaps the service manual?
