Oil in the intake on my lml - Page 2 - Chevy and GMC Duramax Diesel Forum
 2Likes
post #11 of 19 (permalink) Old 04-08-2019, 01:54 PM
J83
J83's Avatar
Originally Posted by SilverGorillaLML View Post
If its building enough oil/dust/whatever up on the compressor wheel you have bigger problems. It would take quite a bit of oil or dust to make the wheel to become unbalanced to the point of affecting the shaft and causing it to contact the cover.
Not to mention since the wheel is spinning at like a bazillian kilo-ripms the dust / dirt / ball bearings should also uniformly coat the wheel which would further reduce the chances of the wheel being off balance.
SilverGorillaLML likes this.
Allison Transmission (stock)
J83 is online now
post #12 of 19 (permalink) Old 04-08-2019, 03:08 PM
The LML has a completly redesigned PVC system that traps oil from any blowby, and returns it to the sump.
No "delete" is needed.
AlisoBob is offline
post #13 of 19 (permalink) Old 04-08-2019, 11:55 PM
Riley 1820's Avatar
First as stated above I didn't say I owned them I seen them. Also didn't say they would be come unbalanced just there was a chance. Any dust getting that far should be checked and fixed. Not all trucks are created or cared for equally.
2012 3500hd srw 4 wd EFILive cp3 conversion dsp5 Jamco exhaust Blue Ridge Diesel lift pump Trifca bed cover
Riley 1820 is online now
post #14 of 19 (permalink) Old 04-08-2019, 11:57 PM
Riley 1820's Avatar
As for "system that traps oil" Guess my 12 lml wasn't working cause I had oil residue in my air intake. So I rerouted my pcv.
post #15 of 19 (permalink) Old Yesterday, 09:25 AM
J83
J83's Avatar
Ill second that, my 15.5 has a nice slick coating of oil inside the throttle body thats not a throttle body that looks just like a throttle body.
J83 is online now
post #16 of 19 (permalink) Old Yesterday, 09:28 AM
SilverGorillaLML's Avatar
My is rerouted to the ground for that reason also
Nic
2011 GMC Sierra 2500 cc/sb LML Quicksilver
Has some stuff to make it go fast and blow up sooner.
2 Banks performance dpf's, 2.5 egr coolers, 3 Def tanks filled with meth, custom hot air intake, snail mod,
garden hose ran from fass, 16 John deere injectors, 22x16-378 forces, and like sooo many stickers brah
Wiles Diesel Performance
Woodstock, Va
SilverGorillaLML is offline
post #17 of 19 (permalink) Old Yesterday, 09:34 AM
J83
J83's Avatar
Once the Y bridge and exhaust get here, thats happening as well. Figure id do it all together.
J83 is online now
post #18 of 19 (permalink) Old Yesterday, 11:41 AM
Yeah always easier that way
Nic
Woodstock, Va
post #19 of 19 (permalink) Old Today, 11:48 AM Thread Starter
Thanks for the info, will do a pcv reroute.
Cope9000 is online now
Similar Threads
please help have an oil cooler and about to do an oil change how much oil? hummerh1 General Discussion 8 01-14-2014 01:09 PM
Low Oil Pressure...Fuel in oil...Metallic particles in oil spdracer71 01-04.5 LB7 Duramax Powertrain 21 01-08-2014 03:27 AM
Oil Level High, Oil Pressure High Low Oil Warning Light On DuraMike 07.5-10 LMM Duramax Powertrain 10 01-07-2012 07:47 AM
