Question on venting a gravity feed aux tank - Page 5 - Chevy and GMC Duramax Diesel Forum
Aftermarket Fuel Tanks This forum is for the discussion of aftermarket fuel tanks and transfer tanks.
 1Likes
post #41 of 42 (permalink) Old 08-14-2019, 08:10 PM
Originally Posted by 1Blue78 View Post
Marv - It looks like I have the same locking cap as you, they are vented so you don't need to vent your aux tank. I am running a small fuel pump (has a small filter), then pass through a golden rod water blocker filter (probably not required but thought I didn't want to worry about water) then a 12v NC solenoid and into the tank via the fill line using the same kit in your Northern tool link. Here are a few pics, I don't seem to have one that shows the solenoid but its right downstream of the filter. I have been waiting until the truck's tank is about 1/2 full then turn on the pump and let it fill till the gauge reads ~3/4 full. When I shut the pump down it normally settles out at about 7/8 full. I have not had any issues throwing codes. My understanding is that it will throw a code if you don't let the tank level drop some which is why I don't switch it on until 1/2 empty and all is good....
How do you have that goldenrod filter mounted ? I see a notch cut on angle iron for reducer fittings to ,well fit in the notch.lol
I used that filter to bench clean my new to me aux tank.Draws from aux tank top and filled the bowl full.When I mounted filter in front of truck tank the bowl doesnt fill but 3 inch over the filter.
Only 1/4 inch up filter with filter before pump.So routed pump to filter only filling bowl 3 inch over bottom of filter.
Does the filter need primed due to the distance maybe? If so how?
Thanks
16 GMC Denali 3500 stock for now
Scott1979 is offline
post #42 of 42 (permalink) Old 08-15-2019, 05:03 PM
1Blue78's Avatar
[QUOTE=Scott1979;12193199]How do you have that goldenrod filter mounted ? I see a notch cut on angle iron for reducer fittings to ,well fit in the notch.lol
I welded a 1/2 black pipe with NPT threads on to the chunk of angle iron so I could mount it under the box and thread the filter in. I am gravity feeding so no need to prime.
2017 SRW 3500 SLT Z71 CC
1978 Trans Am, 400, factory 4 spd, 3:42 posi
DEF - saving the environment one plastic jug at a time
oh, and I love fossil fuels...
1Blue78 is offline
