Cp3 conversion on a 2011 - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 08-03-2019, 02:50 PM Thread Starter
J_thomas675's Avatar
So I have a 2011 Denali hd and wanting to get the cp3 conversion and got a question after getting it done will I need to re tune? Currently running efi 150hp also looking for someone in the Birmingham Alabama area that can do the conversion for a decent price can’t find many duramax mechanics around.
J_thomas675 is offline
post #2 of 6 (permalink) Old 08-03-2019, 05:17 PM
Location: we live in a high mountain valley in the hi country of northern arizona
Originally Posted by J_thomas675 View Post
wanting to get the cp3 conversion and got a question after getting it done will I need to re tune?.... do the conversion for a decent price cant find many duramax mechanics around.
the conversion kit I just received (see other threads for details) is specific to "bone stock" Durmax - is set up to mimic the CP4's delivery rate; so NOTHING needs to be done.
What do YOU mean by "decent" price for the installation? My local GM dealer quoted me approx. 10-15 hrs shop time, or about $1,500.
I have a long history with this particular GM shop, so am satisfied both of their integrity and their shop technician's competence.
You may have seen in other "threads" that SOME of these guys are having problems with SOME GM dealers. I have no solution for that.
6686L is online now
post #3 of 6 (permalink) Old 08-09-2019, 08:26 PM
D_R_C's Avatar
Pretty much start searching for a diesel shop that deals with performance, most shops work on Ford, Dodge and Dmax.
Let your fingers to the searching, or maybe someone in your general area might chime in.
If you was in Phx, Id know where to send you.
Dan
EFILive TCM Duramax Tuner
D_R_C is offline
post #4 of 6 (permalink) Old 08-12-2019, 01:54 PM
D_R_C's Avatar
So I have a 2011 Denali hd and wanting to get the cp3 conversion and got a question after getting it done will I need to re tune? Currently running efi 150hp also looking for someone in the Birmingham Alabama area that can do the conversion for a decent price cant find many duramax mechanics around.
I seriously doubt youd have to re-tune.
But this would be the perfect ? to ask your tuner.
My guess is you have not had any problems yet, your just getting concerned over one paranoid member that did not even have a problem, but it appears he really gets off on stirring things up, with having absolutely no personal experiences or knowledge and talks more than my wife, never shuts up.
Are you running a liftpump and using a good diesel fuel additive ?
If not ask your tuner if hed suggest having a LP and using a good diesel additive, I already know the answer to both.
Dan
D_R_C is offline
post #5 of 6 (permalink) Old 08-12-2019, 02:16 PM
…... wanting to get the cp3 conversion and got a question after getting it done will I need to re tune?....
My apologies that my earlier post in this thread did not completely answer your question.
I recommend LIMITLESS DIESEL. They are going out of their way to help me get a CP3 conversion kit for my '13 LML. They are a dealer for S & S DIESEL, who advertises that their CP 3 conversion kit is "50 state with pump CARB exempt no tuning required".
Unfortunately, like many mfgs, S & S does not have a provision for direct contact of any kind - they wouldn't even talk to my local GM tech reps.
That's where LIMITLESS comes in - that's who I've ordered my kit from; ( should be here any day now) that's where you can confirm the answer to your question re. tuning. Again, their literature says "no tuning required" .
May I suggest you don't get too annoyed by some of the posts in here; obviously, they feel a need to post even tho they may not even own LML's & thus may not have as much experience or sound advice like, for example, LIMITLESS DIESEL can provide you.
To that end, don't you agree the Internet performs a valuble release for some folks with personal agression problems - provides a release for them; they can post whether or not they have actual knowledge about a question. Makes em feel ruff & tuff & macho. I think that's a good thing - these people sound to me like folks who might otherwise get aggressive or worse ?
2013 3500 long bed crew cab. Purchased at approx. 80,000; at this writing have 93,000+, bone-stock except for a few things to increase reliability - convert to CP3. CAT oil filter with nipple installed. Removed one leaf for smoother ride when "empty" - air-shocks to re-gain correct rear elevation when heavy "bumper-pull" towing. Sold to me with round wheels and round tires. I am happy with round wheels & round tires. Went into "limp mode" at the wrong time. Had the DPF cleaned by a professional DPF cleaning service so pollution system is bone stock and fully operable....well..it was until.....
6686L is online now
post #6 of 6 (permalink) Old 08-12-2019, 02:52 PM
J83
J83's Avatar
yes and no, yes, the CP3 will require some form of modification either to the truck or the pump to get it to deliver fuel correctly to the LML. Theres 2 types of kits out there, one that uses a standard CP3 and the truck is tuned to address the changes to the pumps fueling rates, or there are kits where the pump itself if modified and no additional external tuning of the truck is required. If your already running EFI live, and your tuner is still tuning, the kits that require truck tuning seems to be a fair bit cheaper.
J83 is offline
