Best fuel additive - Page 11 - Chevy and GMC Duramax Diesel Forum
 11Likes
post #101 of 110 (permalink) Old 10-29-2019, 08:38 AM
Jbeck1986's Avatar
Originally Posted by wensteph View Post
I buy by the gallon and use a pump dispenser from Amazon to transfer to an empty Lucas bottle. It's 5 or 6 oz. Measured dose once with the cheapest measuring cup WalMart had and put a Sharpie mark on the Lucas bottle.
Do you have a picture or link to the pump dispenser you have?
Thanks
2016 GMC 2500HD Denali 6.6l LML
DOP (used) 10/16/19 @ 8,641miles.
Jbeck1986 is offline
post #102 of 110 (permalink) Old 10-29-2019, 08:46 AM
No additives here for 120k mi and no fuel/injector problems. Fill exclusively at Shell or Chevron stations out west.
mizterwizard likes this.
2012 Quicksilver SLT CCSB Sub 200mi regen club, fuel guzzling, dealer queen LEMON...
Amp Powersteps
Insight CTS
305/55/20 Mickey ATZ P3
Bilstein 5100s
Rancho stabilizer
B&W Turnover Ball w/Andersen Ultimate 5er Hitch
Sandman_73 is offline
post #103 of 110 (permalink) Old 10-29-2019, 08:06 PM
mizterwizard's Avatar
Chevron has been a leader in fuel quality for decades. I keep waiting for some MBA to decide it's time to cash in on their reputation by going cheap on quality but so far it hasn't happened.
GTO_Gregory and Babyhauler like this.
mizterwizard is offline
post #104 of 110 (permalink) Old 10-30-2019, 06:24 AM
D_R_C's Avatar
Visit Phx and get some Chevron Diesel even gas your waiting will be over.
Dan
EFILive TCM Duramax Tuner
D_R_C is offline
post #105 of 110 (permalink) Old 10-30-2019, 02:22 PM
Well, that's a shame.
post #106 of 110 (permalink) Old 10-30-2019, 02:30 PM
D_R_C's Avatar
Not really, at least I know that Iíll save $$$ by not buying Shell or Chevron.
Dan
D_R_C is offline
post #107 of 110 (permalink) Old 01-04-2020, 07:25 AM
Originally Posted by ALLY Cat View Post
The Hot Shot oil additive was designed for folks who own an ill fated Furd PS with the HPOP injector system. I doubt if there's any advantage to using it in a Duramax. However, the Hot Shot's Secret Extreme Diesel is a fuel additive. I tried it in my LLY, injectors were getting intermittently knocky so I figured I would try it before replacing them. So far, it has quieted them down so maybe i can hold off replacing the injectors, at least for now. Truck has noticebly more power, runs cooler, quieter, better MPG after two tanks. Mfgr only recommends using it once every 6 months.....
I recently changed my oil using synthetic t6 15w-40 and tried hot shot secret stiction eliminator. I used it to clean and lubricate anything the oil touches. I didn't really think it would do anything but the truck drivability has seemed to improve. The engine is quiter and smoother at idle now. It's hard to explain but it made a noticable difference that I like and I will continue to use it at the recommended schedule. At the same time I used diesel extreme.
I have been a long time user of opti-lube products but now have switched to using hot shot secret. So far I have used diesel winter anti gel, diesel extreme, and stiction eliminator. I just ordered FR3 for the next oil change, more diesel extreme for future use and I got a free 32 oz. of everyday diesel treatment.
I like how everything you order from there website has free shipping and you can get discount codes.
LBZ
SoCalMike is offline
post #108 of 110 (permalink) Old 01-24-2020, 05:04 AM
2006blackmax's Avatar
I mainly use Stanadyne Lubricity or Howes Meaner Power Cleaner...I know we have a CP3,this stuff was created to help with the problems on the new CP4 ....it beat out OptiLube in the test....Claims of highest Lubricity currently on the market...Has anyone tryed it ?
https://www.hotshotsecret.com/lx4-lubricity-extreme/
2006 2500HD Duramax LBZ with Allison 6 Speed Allison
Transgo Jr/Deep Pan/Filter Lock
PullRite SuperGlide 5th Wheel
Merchant Auto Pump Rub Fix
HD Stainless TieRod Sleeves
GM 3rd Gen. Tranny Lines
MBRP DownPipe
Bilstein 5100's
AirDog 165
Transgo Jr.
MBRP 4''
2006blackmax is offline
post #109 of 110 (permalink) Old 01-24-2020, 05:21 AM
LHN...We ARE the Joneses
in the test..
Whose test?
Hook'em_Horns! is online now
post #110 of 110 (permalink) Old 01-24-2020, 05:27 AM
Lubrication Specialties Inc ?
https://www.hotshotsecret.com/wp-con...port-1-min.pdf
https://www.hotshotsecret.com/wp-con...port-2-min.pdf
https://hss-cdn-lubricationspeci.net...l-with-LX4.pdf
MBRP DownPipe
Bilstein 5100's
AirDog 165
Transgo Jr.
MBRP 4''
