China Tech2 - Page 38 - Chevy and GMC Duramax Diesel Forum
Behind The Garage Door For your garage / shop including tools & equipment
 5Likes
post #371 of 380 (permalink) Old 05-21-2017, 11:51 PM
I picked up my T2 clone from OBD2tool.com paid $295 for it. This was to find problems on my 07 LBZ. I hooked it up when I got it with the CANDi module and was able to read engine data. Then the next day it didn't work. The CANdi module was bad. It took almost a month to get them to send a new module, but they did.
After playing with it, while it does give some valuable data, the data list is different than on the earlier models. For instance, it does not show injector pulse width on my LBZ, but shows it on my LB7. I hadn't thought to try and log on as an earlier model to see if it would show it. I also have not been able to connect it to my computer. The current issue is that I don't have a driver for the USB adapter. The other issue is that the software want you to select which serial port you are using, but the USB ports are not an option I can select. I would like to get logged on, as I would like to program my spare ecm.
Walker,
2002 GMC Sierra 4x4 with a Duramax
250,000 miles
Awalker is offline
post #372 of 380 (permalink) Old 08-06-2017, 10:41 PM
campingguy's Avatar
Do you have a set of factory manuals? I have the paper set from Helm that I bought when I got the truck new but have decided it's time to quit lugging a ton of manuals around when I need to research stuff. The info you get from the Tech2 is great but it really comes together when you run it against the scan tool data lists in the manual.
07 GMC Sierra Classic (LBZ) Duramax Dually Crewcab 4X4, FASS Titanium 95, Ohio Diesel Parts Tank Sump, bypass engine oil filter, synthetic lubes; 84 Chevy 6.2L 1.25 Ton (Army CUCV) with Banks Sidewinder Turbo and Gear Vendor's Overdrive; 83 Chevy Suburban 6.2L 4X4; Retired Journeyman Heavy Duty Truck Mechanic
campingguy is offline
post #373 of 380 (permalink) Old 08-07-2017, 03:37 PM
btexpress's Avatar
Where are you getting the software from, to program your 07 LBZ??
2011 GMC 3500 Denali HD, Banks Exhaust From DPF Back, Stock Tune, Pullrite 22K Super Rail 5th Wheel Hitch. Pioneer AVIC-8200NEX Navigation Radio, Tailgate camera view moved from mirror to Navigation display, Pace Edwards Electric Bedlocker Tonneau Cover, with a 37 gallon Transfer Flow tank with Trax2 display, under it's canister, Chrome wheel opening moldings, Mirror mod, with forward led marker and turn signals and puddle lights.
SOLD: 2003 Silverado 2500 HD, Banks Exhaust from turbo back with exhaust brake, Late model mirrors with forward led marker and turn signals and puddle lights, Pullrite 22K Super Fifth hitch with Super Rails, Brake Smart controller, Air horn mod, HID's and LED's
btexpress is offline
post #374 of 380 (permalink) Old 08-07-2017, 04:04 PM
Do you have the latest pcard software? I think 33.04 or something like that. I bought an MDI as I thought it would be easier than using a serial cable to program. Do you have a subscription to tis2web or just using the local database on the older software for programming? You are in az and I am in north phoenix, maybe we could try my mdi and see if would work. I have never tried to program, but assume it can't be too hard.
2012- Denali HD 4x4 2500
Xpel clear bra, amp steps, Inyati Bedliner. Rancho RS5000 Steering Stabilizer-Rancho 9000XL Shocks
PPE PTO-front/rear/Allison covers with transynd and amsoil severe gear oil. Magna-flow DPF back exhaust.
48548 is offline
post #375 of 380 (permalink) Old 10-27-2018, 10:23 PM
Well my tech2 clone has died, get error for can't read candi. Anyone know of something that will work like a tech2. I really don't want to put out another 300.
Glen,
06 GMC CC SLT 4WD, Cat cleaned out, CAT back Magnaflow Dual Exhaust, BDPP in Tow/Economy Setting.
Glen A Pryor is offline
post #376 of 380 (permalink) Old 10-28-2018, 04:51 AM
The mongoose adapter or an mdi/mdi2..
Sent from my SM-G955U using Tapatalk
48548 is offline
post #377 of 380 (permalink) Old 06-12-2019, 01:10 AM
@DualThreat
if you buy from www.chinacardiags.com,I think this is new domain
tuita is offline
post #378 of 380 (permalink) Old 06-12-2019, 01:12 AM
Originally Posted by tuita View Post
I mean chinacardiags.com
tuita is offline
post #379 of 380 (permalink) Old 06-12-2019, 10:55 AM
campingguy's Avatar
@DualThreat
It looks like the same site that I used to order my TechII in 2014. I opened the link and logged in using my old login and it came up with the info on my previous orders.
post #380 of 380 (permalink) Old 07-29-2019, 01:43 AM
Originally Posted by DualThreat View Post
Csthompson12, The scanner is still working great and Yes I believe I have run that test. Not that I needed to. I was just curious what it did to the engine. You could definitely tell that sound of the engine changed as the pressure was increased. On another test I commanded the fuel solenoid off. Scared the crap out of me. The truck just shut down LOL WHOOPS!!!
I got my T2 from chinacardiag.com.
"I got my T2 from chinacardiag.com" I have search this site,the domain has been change to chinacardiags.com,lol,finally I got the item sp23
gm tech2 it's amazing clone tool just like original cool
tuita is offline
