Matt's 2015 engine rebuild/upgrade - Page 344 - Chevy and GMC Duramax Diesel Forum
Build Threads Post Your Build Threads & Progress!
 2890Likes
post #3431 of 4321 (permalink) Old 07-20-2018, 09:15 AM
Originally Posted by M.A.M. View Post
-73
Dear god at the trimming/cutting/hammering youíll be doing lol
M.A.M. likes this.
LML6600DMAX is offline
post #3432 of 4321 (permalink) Old 07-20-2018, 09:18 AM Thread Starter
M.A.M.'s Avatar
ďnodding in agreementĒ Gotta go where others canít! Plan on doing whatever I need to to these fenders, then buying new ones and getting them professionally done somewhere once I know exactly what they need to clear.
9/26/17 80k miles with no issues...
--2015 GMC 3500 SRW/CCLB--
Engine rebuilt @ 170,000 miles due to hole in cylinder #7
First start on 5/13/16
8/29/17 REBUILD 2.0 @ 295k miles
255k miles on 4/1/17, and goin' strong...
S&B Intake, 3" MBRP downpipe, Flo-Pro 5" downpipe back exhaust/no muffler, PPEI tuned no longer, MOONSHINE tuned by Tony @ RidgeRunner, Airdog lift pump...
Monitoring via CTS2
Engine
Fingers Oval Bowl pistons @ 17.5:1 .040 over
Carrillo rods
chromoly pushrods
SoCal Girdle
ATI Super-Damper
ARP main and head studs
Keyed crank and cam
SDP CP3 coversion w/ Sportsman pump
Suspension
305/55/20 MT Baja ATZ P3s on stock 20's...
Kryptonite tie rods/centerlink
BUILD THREAD
M.A.M. is online now
post #3433 of 4321 (permalink) Old 07-20-2018, 09:21 AM
kowclub173's Avatar
Biggest thing you have to watch with beads is most places donít use nearly enough. A set of duals takes more per tire to balance. Ex: semi steers take 10oz but drives take 12oz each.
Also many of them donít factor in the weight of different tires/rims. My steers they only did 6oz because thatís all they normally need for a tire of that diameter. They didnít factor in the heavy ass 19.5ís Iím running
My next time around I may invest in a set of centermatics.
M.A.M. likes this.
08 Sierra Dually
---Hot shot rig---
400K miles 06/29/17
New motor at 138K
Deletes, CTS2, EFI by Idaho Rob,Wherli 3" y bridge, Danville GT3794, billet converter, 4.44 gears, trutrac
kowclub173 is offline
post #3434 of 4321 (permalink) Old 07-20-2018, 09:25 AM Thread Starter
M.A.M.'s Avatar
Good to know. So how do you calculate how many you need for a certain wheel/tire set up? Does it go strictly by weight?
Monitoring via CTS2
Engine
Carrillo rods
chromoly pushrods
SoCal Girdle
ATI Super-Damper
Keyed crank and cam
Suspension
BUILD THREAD
post #3435 of 4321 (permalink) Old 07-20-2018, 09:36 AM
07Dmaxx93's Avatar
Iíve been told balancing beads really donít do much until you hit a 37. Iíd love to use them in my 35ís
2007.5 CCSB LMM
EFI live ECM Tuning by PPEI
S369SXE by WCFab
Fass 150GPH
XDP Sump
Instagram: 07Dmaxx
07Dmaxx93 is offline
post #3436 of 4321 (permalink) Old 07-20-2018, 09:53 AM
May ask Corbin on DD. Pretty sure he runs them in all his wheel tire setups
M.A.M. likes this.
post #3437 of 4321 (permalink) Old 07-20-2018, 09:57 AM
kowclub173's Avatar
That is true
08 Sierra Dually
---Hot shot rig---
400K miles 06/29/17
New motor at 138K
post #3438 of 4321 (permalink) Old 07-20-2018, 09:59 AM
kowclub173's Avatar
Local shop goes by size. I believe weight is really the important factor.
Seems when it comes to the stuff, too much is better than not enough.
M.A.M. likes this.
08 Sierra Dually
---Hot shot rig---
400K miles 06/29/17
New motor at 138K
post #3439 of 4321 (permalink) Old 07-20-2018, 10:40 AM Thread Starter
M.A.M.'s Avatar
Thanks, Graham. Iíll talk with the local shop and see what they think.
Iíll give Corbin a shout and see what he says as well...
kowclub173 likes this.
Monitoring via CTS2
Engine
Carrillo rods
chromoly pushrods
SoCal Girdle
ATI Super-Damper
Keyed crank and cam
Suspension
BUILD THREAD
post #3440 of 4321 (permalink) Old 07-20-2018, 10:50 AM
DuramaxForum Guru
1TRIKHD's Avatar
Location: Where Loggers do it better in the Woods. PNW Son!
Yeah talk to Corbin. He told me 6ozs would be enough for 12 wides and 305/50's. Check his thread on DD I think some posted a link
Sent from my VS988 using Tapatalk
M.A.M. likes this.
2006 Victory Red CCLB LT3 LBZ
Tuned by Blake Crenshaw
SDP Fully Built Trans w/ Billet Goerend G Converter
S472 SX-E.87/1.0ar sitting on a Wagler street intake W/ a twisted pedestal
Stock Sticks
Special thanks to Scott with Screaming Diesel Performance
Blake with Unleashed Duramax tuning
1TRIKHD is offline
