2003 LB7 CCLB Build - Chevy and GMC Duramax Diesel Forum
Build Threads Post Your Build Threads & Progress!
 10Likes
post #1 of 35 (permalink) Old 03-22-2017, 12:20 PM Thread Starter
2003 LB7 CCLB Build
Been pulling out hairs deciding between buying a 17 Duramax or keep sinking money into my 03. As you can tell from the title I chose the second option...for now. Bottom line is I don't plan on ever getting rid of the 03 at this point so might as well fix er up. I'm blessed with living in the great state of California and have a CA LB7 with an EGR. I want to go through everything fixing anything that could potentially be an issue in the future. Has over 300,000 miles and likes to spring leaks right as soon as you fix one so hopefully I can stop that. Im still not sure with what CP3, injectors or piston to go with yet so I'm open to any input there. Also contemplating pulling the batmowheel and getting a Cheetah or Stealth turbo to drop in. It is a daily driver and I'm trying to make it as reliable as I can while still having the ability to make some power.
Parts Currently On the Truck
-Cognito 4-6 NTBD Lift Kit
-Cognito Steering Braces
-Bilstien Steering Stabilizer
-Rare Parts Tie Rods
-DuramaxTuner Stealth G2 64
-ARP Head Studs
-4" Cat Back MBRP Exhaust
-3" MBRP Downpipe
-Airdog 150
-Banks Ram Air Intake
-Carrillo 6.6 Pro H Connecting Rod H-11 Bolts
-MA Performance Push Rod Kit
-MA Tig Welded Water Pump.
-ARP Main Stud Kit
-MA Braided Transmission Line Repair Kit
-Russell Steel Braided Brake Lines
-Lincon Diesel SAC 45% Injectors
-PPE High Flow Exhaust Manifolds with Up-Pipes
-PPE De-Lipped LB7 Pistons
-PPE Silicone Upper and Lower Coolant Hose Kit
-PPE High Capacity Cast Aluminum Oil Pan
-PPE Xtreme Damper
-PPE Boost Valve
-PPE Stage 4 Transmission & Brace
Glamour
Build Photos
llyschaffer likes this.
2003 Chevrolet Silverado 2500HD 6.6L LB7 4x4 CCLB -ARP Studs - Merchant Pump Rub Fix- 4' Cat Back MBRP Exhaust - 3" MBRP Downpipe - Airdog 150 - PPE Boost Valve - Banks Ram Air Intake - 4-6" Cognito NTBD - Rare Parts Gen-II Heavy Duty Tie Rods - PPE Stage 4 Transmission - Stealth G2 64 - PPE High Flow Manifolds & Up pipes
crowellalex is offline
post #2 of 35 (permalink) Old 06-21-2017, 09:54 AM Thread Starter
Photos Updated
post #3 of 35 (permalink) Old 06-27-2017, 08:08 PM Thread Starter
Photos Updated
post #4 of 35 (permalink) Old 06-27-2017, 09:32 PM
Buschman's Avatar
Subscribed, looking forward to seeing the progress! Gives me inspiration to keep putting $$$ into my LB7 instead of a new truck payment!
[/SIGPIC]2003 2500HD Duramax
7" BDS set at 5.5, 35/1250 Toyo MT's on H2's, EFI live, Head stud's, intake/exhaust, lift pump
Buschman is offline
post #5 of 35 (permalink) Old 06-29-2017, 07:12 PM Thread Starter
Photos Updated
post #6 of 35 (permalink) Old 07-20-2017, 05:18 PM Thread Starter
Engine is still out with PPE, Engine parts are out getting some powder along with the frame. Just waiting for the frame to start getting it back together.
post #7 of 35 (permalink) Old 08-05-2017, 11:18 PM Thread Starter
Photos Updated
post #8 of 35 (permalink) Old 08-27-2017, 10:06 AM
OFC
OFC's Avatar
Outstanding
All I need is time and money, and a ton of extra shop space with another lift, and shelving to stow all the parts, and a tow truck, and a couple of more guys to help me, and I could do that to mine, ...
Seriously, very cool. Can't wait to see it come together.
OFC is offline
post #9 of 35 (permalink) Old 08-27-2017, 12:21 PM Thread Starter
All common things one could find in your garage I am very fortunate to have access to some extremely helpful equipment and people.
post #10 of 35 (permalink) Old 08-27-2017, 12:27 PM Thread Starter
Spoiler Picture
Fresh set of SAC 45% Injectors from Brent at Lincoln Diesel
