Diode Dynamics: SL1 LED Headlights for Chevrolet Silverado! USA Made! See Video! - Chevy and GMC Duramax Diesel Forum
 4Likes
post #1 of 44 (permalink) Old 02-28-2018, 07:35 AM Thread Starter
Supporting Vendors
Diode Dynamics's Avatar
Arrow Diode Dynamics: SL1 LED Headlights for Chevrolet Silverado! USA Made! See Video!
SL1 LED Headlight for Chevrolet Silverado
How to Install 2014-2017 Chevrolet Silverado Headlight
Diode Dynamics is pleased to offer the USA-made SL1 LED headlight for Chevrolet Silverado applications.
SL1 LED Headlight. If you're looking to improve your visibility at night, you've probably seen many options available for LED upgrades. There's plenty of LED bulbs on the market, but they all have their shortcomings. They're too big to install, have no hotspot in the beam pattern, or they simply stop working after just a few months. With its compact size, optically correct output, thermally-modeled cooling, and boost-mode electrical circuit, the SL1 LED finally provides a true upgrade in performance.
Street Legal Output. Don't be fooled by high lumen numbers or "projector specific" bulbs. Your car's headlights are designed to focus light. If the light source is out of focus, it doesn't matter how bright it is - you won't have a focused hotspot of light to shine down the road - just more glare. To correct this, the SL1 LED headlight bulb was engineered with advanced optical design software, to perfectly match filament location. This allows the SL1 LED to focus light just like an original bulb, preserving the focus and hotspot, with no added glare. It produces a functional beam pattern on the road, in compliance with photometric standards, for a safe, functional output, which we call Street Legal.
Tested to Perform. We test the SL1 bulb in factory headlamps, and measure the entire beam pattern using specialized equipment. It's an elaborate affair: a headlight is mounted to a computer-controlled rotating head called a goniometer. Light shines down a tunnel, where a sensor collects data as the headlight is rotated. The entire beam pattern is mapped, and we compare the total output to the original halogen, confirming that the SL1 bulb shines more light in the hotspot, without adding extra glare on the road. The test results speak for themselves: in most lamps, like the 2015 F-150 Halogen lamp below, there is 30-70% more light in the critical hotspot, with no added glare or spread of light. With optical engineering, testing, and validation in the application, we can assure correct optical performance.
Staying Cool. You may have seen bulbs that use large straps for cooling, or fans that just make noise. These bulbs run hot, resulting in degradation of output after a few months. When it comes to cooling, proper engineering is required to efficiently remove heat from the bulb. In the SL1, a copper core board, thermal phase-change material, and thermally-modeled zinc casting get heat to the base, where base fins release it, designed for aerodynamic performance in conjunction with the flow rate and pressure of the Sunon bearingless microfan. The result is a highly-effective and reliable cooling system, keeping the bulb running at maximum potential.
Fitment. With its patent-pending design, the SL1 LED fits where other bulbs won't, without cutting or modification. There's no hanging metal straps, just a compact bulb that plugs right in, with a nylon-reinforced shroud. Only slightly larger than a standard halogen bulb, it fits behind dust caps and in tight spaces. The base sizes are keyed for exact applications, not one-size-fits-all, and the compact driver easily tucks away.
Reliability. Every part of the SL1 LED was designed for reliability, from the high-temperature teflon wire, to the zinc castings, to the reinforced plastics. The compact driver uses a unique boost-mode circuit, which prevents thermal imbalance in the LEDs, and has transient protection for long life in automotive circuits. Finally, the SL1 bulb was put through its paces in our environmental testing chambers - where the bulb successfully performed through dozens of thermal cycles, from -40 through 150 degrees Celsius. The SL1 will keep performing for years, and is backed by a three year warranty.
Experience. After over a decade in business, Diode Dynamics is the most trusted name in automotive LED lighting. Unlike every other LED distributor, we manufacture and engineer products ourselves in the United States, for high quality and fast time-to-market of the newest and brightest LED technologies. We pride ourselves in offering only quality LED products, that will exceed your expectations.
Specifications
Measured Lumens: 1630 (per bulb)
Color Temp (CCT): 5700K Power (watts): 20.2
Operating Voltage: 5-16V
Current (amps @ 13.2V): 1.58 Polarity:
Polarity Specific LED Emitter: Luxeon Z ES
Connector(s): OEM-Size Plug and Play
Driver Features: External, Waterproof, Constant Current
Materials: Copper PCB, PP-TD30 Base, Zinc Heatsink
Cooling: Active, Mag-Lev Microfan
Compliance Ratings: FMVSS108 Beam Pattern, SAE J575 Durability Test
[B]Click To Order Your Chevrolet Silverado LED Headlight Replacements:
Diode Dynamics SL1 Low Beam LED Headlight for 1999-2006 Chevrolet Silverado
Diode Dynamics SL1 High Beam LED Conversion Kit for 1999-2015 Chevrolet Silverado
Diode Dynamics SL1 Low Beam LED Headlight for 2007-2015 Chevrolet Silverado
Diode Dynamics SL1 Low Beam LED Headlight for 2016-2017 Chevrolet Silverado 2500/3500
If you have any questions, please don't hesitate to post, PM, email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 44 (permalink) Old 04-11-2018, 09:52 AM Thread Starter
Supporting Vendors
Diode Dynamics | About Us
post #3 of 44 (permalink) Old 04-13-2018, 06:39 PM
sugarjohnson's Avatar
Do these fit behind the dust caps on both high and low beam?
2015 CCSB 3500 TM
sugarjohnson is offline
post #4 of 44 (permalink) Old 04-16-2018, 08:18 AM Thread Starter
Supporting Vendors
Our engineering team designed the SL1 to be extremely low-profile and fit inside dust caps with no modifications required.
Thank you!
Nick C.
post #5 of 44 (permalink) Old 07-20-2018, 05:44 AM
Are these in stock?
Do they work with the day time running lights?
Do they work right out of the box or are additional parts needed?
Do you have a high beam offering also?
dlsolo likes this.
Puzzled is offline
post #6 of 44 (permalink) Old 07-20-2018, 09:14 AM Thread Starter
Supporting Vendors
Hi there!
Certain sizes of the SL1 Headlight LED Bulbs are currently back ordered, and our production team is working hard to get everything back on the shelves as quickly as possible. The SL1 is 100% plug-and-play, no wiring, cutting, or modification needed. And yes, we offer high beams too!
If you're not sure exactly which bulb sizes you need, check out the Vehicle Finder tool on our website.
Thanks!
Jake H.
Diode Dynamics
post #7 of 44 (permalink) Old 08-17-2018, 07:25 AM Thread Starter
Supporting Vendors
SLF LED Fog lights in a new Tahoe from Lightwerkz!
Note the OEM+ 5,700K Color temperature
post #8 of 44 (permalink) Old 08-19-2018, 02:06 PM
I just wanted to confirm that a 2015 (not 2015.5) Silverado 2500HD does not need the anti flicker modules for this kit, right?
2015 LML CCSB with a few options.
Squished is offline
post #9 of 44 (permalink) Old 08-20-2018, 11:09 AM Thread Starter
Supporting Vendors
Diode Dynamics: Low Beam LED Headlight for 2007-2015 Chevrolet Silverado will not require an Anti-flicker module.
Thanks!
Nick C.
post #10 of 44 (permalink) Old 08-30-2018, 08:29 AM Thread Starter
Supporting Vendors
Do LED Headlights Work In Projector Headlight Housings? Diode Dynamics SL1 Review
Headlight Revolution
1TRIKHD likes this.
