Reset the computer - Chevy and GMC Duramax Diesel Forum
post #1 of 13 (permalink) Old 02-19-2009, 07:37 PM Thread Starter
tred311's Avatar
Send a message via AIM to tred311
Reset the computer
Is there and easy way to reset the computer? Can I just disconnect the batteries? Any side effects? 2007 2500HD new body style.
Thx!
tred311 is offline
post #2 of 13 (permalink) Old 02-19-2009, 07:40 PM
Banned
reset?
Ugh, it shuts down after a bit with key off.
What do you mean reset....?
MMLMM is offline
post #3 of 13 (permalink) Old 02-19-2009, 07:42 PM
FH Leader's Avatar
program history reset?
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Fass 150, EFI by Rob, SC4 TC1056, transfer case brace, hid 8k on highs and lows
My iron is yellow
Current project-389 pete glider C-16 Stage 2.5 pdi injectors, stage 3 pdi cam, stage 1 tuning,stage 3 turbo, ending hp 850 to the ground!
Id rather be dead then CUMMINS RED!
FH Leader is offline
post #4 of 13 (permalink) Old 02-19-2009, 07:44 PM
Banned
isn't there a button for that?
MMLMM is offline
post #5 of 13 (permalink) Old 02-19-2009, 08:29 PM
smog's Avatar
Why do you want to re-set the ecm?
If you disconnect the battery ; all readness monitor will be erase and idle speed learn and trans will re-set and raido, clock etc.
2006 CCSB LLY ZF-6
CAT DELETED
SECONDARY FUEL FILTER
EGR BLOCKED AND FINGERED
PPE AIR BOX MOD
PCV RE-ROUTED
EDGE RACE
03 GMC STEPSIDE (FOR SALE)
smog is offline
post #6 of 13 (permalink) Old 02-19-2009, 08:56 PM
Banned
it will?
i wasnt aware
MMLMM is offline
post #7 of 13 (permalink) Old 02-19-2009, 08:58 PM
Buck's Avatar
ya i was just told that if your batts go dead that its don't effect your trans?
Vehicle 2008 Black Chevy Crew Cab Short Bed Z71
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods EFI Live and DSP 5 By MMLMM, RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Titan 52gal fuel tank, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline
post #8 of 13 (permalink) Old 02-20-2009, 05:28 PM
if ur computer is locked by a tune on some brands of tunes the dealership can't even unlock it. this happened to me
Matty's truck specs
2002 crew cab duramax
7 inch suspension 3 inch body
36 12.5 wrangler r/t 2 military <--For Sale
straight pipe
Quadzilla stealth 2
ProSport Gauges
plugged resonator no diffrence though
:rockin
RidinHigh11 is offline
post #9 of 13 (permalink) Old 02-20-2009, 07:33 PM
Administrator
jc1843's Avatar
To answer your question, NO, there is no way to reset the computer. GM dealer can reflash the program and it will change some items, but most will be there.
Disconnecting the batteries will only affect the radio and clock-seat memory - it will not erase anything else that I know of.
jc1843 is offline
post #10 of 13 (permalink) Old 02-20-2009, 07:37 PM
why do you want reset the truck???
2006 gmc slt,full bore exhaust maniflod,leather,dee zee nerf bars,Diamondback hd tonneu cover,cloud rider mud flaps ,trans go jr with bd valve body, cognito level installed uca , ppe tie rod sleeves,atx teflon,pro comp shocks edge evoloution A/T.295/70/17 nitto terra grapplers::die NOW WHERE ARE THE CANADIAN TRANNY BUILDERS
marbles72 is offline
