New to drag racing - Chevy and GMC Duramax Diesel Forum
 18Likes
post #1 of 244 (permalink) Old 04-27-2015, 12:04 PM Thread Starter
New to drag racing
I have an 07 LBZ extended cab short bed with tunes from Duramax Tuner, lift pump, intake and downpipe back 5" exhaust. I started drag racing at the track doing only lightly boosted 2wd launches. Ordered kryptonite tie rods from dmaxstore and browsing the site it got me thinking about traction bars... What would you guys recommend for mods for the strip?
Best (with wheel spin) was a 14.803 at 96..
Thanks in advance guys/gals
2007 EC/SB LBZ
***11.851 @ 119.xx***
***Limitless Diesel Built Trans***
***HSP S475 over Stock Twins***
100 Over Injectors, 12mm Stroker pump, Mod Water Pump, SoCal Balancer, SoCal Injector hold downs, Fass 150, HSP EGR Delete, HSP Downpipe, HSP Hotside intercooler pipe, PCV Reroute, MBRP 5", S&B Intake, EFI Live from Duramaxtuner with DSP5, Longhorn fab Traction bars, Kryptonite Tie Rods, Empire Centerlink, PPE Idler/Pitman Support...More to come.
Ronisonce is offline
post #2 of 244 (permalink) Old 04-27-2015, 12:12 PM
Northwest Coal Roller's Avatar
Tie rods, Braced pitman/idler, braced centerlink/ straight, level CVs, traction bars
2017 GMC Denali: 5% tint all around, 55% windshield, RC traction bars, 6" Fabtech, 20x12 Hostile Stykers, 35x13.5 Toyo A/T
2003 LB7 ECSB Too much air, too much fuel(Died 26May2017)
Daily Driver: 2014 Cruze TDI, cold air intake (best mod ever), 5% all the way around
PhotoBucket: http://s793.photobucket.com/user/mic...bock1/library/
Northwest Coal Roller is offline
post #3 of 244 (permalink) Old 04-27-2015, 10:24 PM
unknown known most
8ualive's Avatar
Start saving for a tranny! Ha
2015.5 Denali 2500 on 35's at factory height...sold
2008 lmm......sold
2003 gmc RCSB with 6.0 and 4L80 for now...
2000 Camaro ss with 5.3 and s480 billet wheel...
8ualive is offline
post #4 of 244 (permalink) Old 04-28-2015, 01:52 AM
56taskforce's Avatar
^^^^^Transmission first and for most^^^^^
2006 GMC (THE MISTRESS) CCLB SLT 3500 SRW ONE BAD BITCH currently with a broken crank
56taskforce is offline
post #5 of 244 (permalink) Old 04-28-2015, 06:59 AM Thread Starter
I purchased kryptonite tie rods, long horn fab traction bars... Who makes a good pitman arm/idler brace as well as a centerlink brace that BOLTS in? I saw dirty hooker has the centerlink brace but haven't searched much for the other 2... I'm saving for a tranny, already been in touch with Evan at Limitless Diesel.
2007 EC/SB LBZ
post #6 of 244 (permalink) Old 04-28-2015, 09:11 AM
Very good choice in trans builder for the pitman arm, Kryptonite suport, frame gusset, and arm. Too stop the center link from twisting either DHD brace or the Cognito PISK.
Your on the right track.
post #7 of 244 (permalink) Old 04-28-2015, 09:13 AM
Tony323's Avatar
Dirty hooker diesel sells leaf spring clamps that will work well enough for now. They clamp at the front of the overload spring around the whole pack. I did that for awhile then got their traction bar kit when I got more into pulling.
Tony Lewis
06 ccsb lbz 4x4
Kory Willis dsp5
Big Dipper w/ml converter
Kryptonite steering, airdog165
rerouted,deleted,debadged,plugged, bt lockup
eaton front locker
[email protected]
Tony323 is offline
post #8 of 244 (permalink) Old 04-28-2015, 10:41 AM Thread Starter
Do you need to brace the pitman/idler as well as centerlink or is it one or the other. I'm not 100% familiar with the geometry. Wondering if I get the DHD centerlink brace if I would be good for now.
2007 EC/SB LBZ
post #9 of 244 (permalink) Old 04-28-2015, 11:53 AM
Tony323's Avatar
Yes the brace will be enough. I personally lost steering radius with the cognito pitman and idler braces. So I took them off.
Tony Lewis
06 ccsb lbz 4x4
Kory Willis dsp5
eaton front locker
[email protected]
Tony323 is offline
post #10 of 244 (permalink) Old 04-28-2015, 12:30 PM
A little different method but they both do the same thing so one or the other. I am lifted so my only choice is the PISK.
