Estimated 1/4 time? - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 10-31-2016, 04:14 PM Thread Starter
monster50iii's Avatar
Estimated 1/4 time?
It came in at 600hp, 1130tq at Danville.
Mods:
Stock tires
front end dropped
pitman arm, idler arm braces
sleeves
built trans 1078 from Evan
Billet 3794
pro fab manifolds/up pipes
shimmed fprv, drilled fuel inlet fitting
lift pump
pro fab cold side pipe
#7200-#7400lbs
what kind of 1/4 time roughly can a guy achieve?
Also, not sure if my truck has aftermarket torsion keys or not. With the bolts ran all the way out what is the measurement of gap between the middle of the tire and wheel well on the LMM's??
2008|5" MBRP|Self Tuned|Danville 3794|Air dog 165|Shimmed FPRV| Manifolds & Up Pipes by ProFab|Built Allison by McShane w/ Limitless Diesel 1078|
monster50iii is offline
post #2 of 16 (permalink) Old 10-31-2016, 05:04 PM
DuramaxForum Guru
lutzjk913's Avatar
High 12's or low 13's depending on driver.
Joe
2008 CCLB LMM
13.39 @ 99.44 W/ 1.76 60’
456 HP 925 TQ
2003 RCLB LB7 “UNDER CONSTRUCTION”
The life of my truck
Pics of my truck
lutzjk913 is online now
post #3 of 16 (permalink) Old 10-31-2016, 05:24 PM
Minerigger's Avatar
13.2-13.4 if you cut a half ass 60ft. But your heavy. As long as your cp3 hold rail you may get a 12.7-12.9 as you've got the air. What shocks you got? Torsion bars? Tires?
Brock
06 LBZ ECLB
Gauges, DP Tunes, 5" Dumped, Trans by Evan @ Limitless Diesel,
DP Stg2r, Sleeved & Braced
Minerigger is offline
post #4 of 16 (permalink) Old 10-31-2016, 05:45 PM
SilverGorillaLML's Avatar
I'd say high 12s would be easily achievable if your making the power the dyno says..
NIC R
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/48RE Swap/PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
SilverGorillaLML is offline
post #5 of 16 (permalink) Old 11-01-2016, 02:48 PM Thread Starter
my tires are 265/70R17's 31.65". These are my winter tires
I have bilstein shocks in the front, stock torsion bars, but im not sure if the keys are aftermarket or not.
I was hoping that 12.5-12.8 would be achievable
post #6 of 16 (permalink) Old 11-01-2016, 03:14 PM
Josh is running 12.8s with a smaller turbo, and a weak cp3..
You should be able to squeeze out some faster times with a good suspension setup and playing with tire pressure n launches.
NIC R
post #7 of 16 (permalink) Old 11-01-2016, 03:23 PM
Minerigger's Avatar
Lose weight to
Brock
06 LBZ ECLB
post #8 of 16 (permalink) Old 11-01-2016, 03:29 PM
DuramaxForum Guru
lutzjk913's Avatar
If it's a legitimate 600 I don't see him going any further than josh without a serious diet. Lol
Joe
2008 CCLB LMM
456 HP 925 TQ
Pics of my truck
post #9 of 16 (permalink) Old 11-01-2016, 03:57 PM
Drop some weight, throw some caltracs on n let it eat is the only way to know
Joe, joshs truck is weird, he should be faster than he is lol
NIC R
post #10 of 16 (permalink) Old 11-01-2016, 05:25 PM
DuramaxForum Guru
lutzjk913's Avatar
Look at @DaJokr though.
He's going low 13's with built trans and korys tuning.
Joe
2008 CCLB LMM
456 HP 925 TQ
Pics of my truck
