Use your V2!!!!! - Page 7 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #61 of 70 (permalink) Old 12-12-2012, 10:08 AM
That seems weird to me? I cant select what tunes to have on my dsp5 so if I have ten tunes how does it decide which ones to put on there has to be a selection process? Right?
granaya45 is offline
post #62 of 70 (permalink) Old 12-12-2012, 10:29 AM
Bear9350's Avatar
A DSP5 tune isn't 5 completely differant tunes, it is one tune with 5 different layers to it. When you load the tune you are only putting one tune file in the truck but that file has different levels. You could ask for 5 different tunes to be built. When you get the tunes make a copy of the original file and save it somewhere and never alter it. Use the second copy to make your own modifications to. You can save as many copies of the original file and alter them however you would like. You can then select those different modified tunes to load to the ECM. You can only load one tune with its 5 different levels to the ECM at one time though.
Hope that helps clear some stuff up.
2012 Chevy 2500 LML, Ext. Cab
Deleted running PPEI tuning
Sold: 2003 Chevy 2500 LB7, Crew Cab
Bear Claw Front and Rear Bumpers
EFI Live DSP5 from ATP/Rob, port and polished stock IHI turbo w/ Batmo Wheel, 3" Down Pipe, 4" straight pipe from the downpipe, intake horn mod, modded air box, custom overhead gauge console, pyro and boost gauges
Cognito UCA, Kyrptonite Straight Centerlink and Tierods, BFG KM2 255-85 on stock wheels
Truck Pictures
Bumper Build
Bear9350 is offline
post #63 of 70 (permalink) Old 12-12-2012, 11:32 AM
Oh ok thanks a lot that did clear it up pretty good for me. The whole process can be pretty confusing
post #64 of 70 (permalink) Old 02-11-2014, 06:51 AM
sandpirate's Avatar
Subd
2008 Chevrolet Duramax Dually LTZ
Was Bone stock
EFI Live, CTS gauge w/EGT Probe, S & B Intake, MagnaFlo 3.5" DP, MagnaFlo 4" SS Full Exhaust, EGR Blocked, Nicktane w/CAT Filter, Mike L Tranny Cooler, PCV Re-rout, TransGo jr, AD II 165, FPRV Shimed & Titan 62 gl.
GM DRW Club Member #78
sandpirate is offline
post #65 of 70 (permalink) Old 05-06-2014, 09:09 AM
GioBandy's Avatar
Send a message via Skype™ to GioBandy
Yeah, the laptop does get in the way when driving "Talk about strapping it down before take off"
2013 GMC Sierra 2500HD 6.6L LML Duramaxxx Diesel|5" straight pipe with a 8" Metal Mulisha tip, 22,000 Miles.|EFILive tuning with Edge CTS, Glow-Shift Gauges.|Twin-turbos, FASS Duramax Titanium Series Fuel/Air Separation Systems, Throttle Sensitivity Booster chip.| Powr-Flo Mass Air Flow Sensor, Train Horns, P.A-System.|6" lift kit with 20" rims and 35" tires, 2" blocks.|Spyder Black LED Tail Lights & Black Projector Headlights w/ CCFL Halo's.Emissions Removed, EGR Delete, Speed Limiter Removed|[COLOR="Cyan"]More Coming SOON!!!,|Made my first Smoke Tune! on 05-26-14 for my H&S XRT Pro Race Tuner!!
GioBandy is offline
post #66 of 70 (permalink) Old 09-14-2014, 10:10 PM
Basshole1's Avatar
sub
2004 LB7 - FASS 150 & CAT Fuel Filter 120k miles - Replaced injectors 170k miles - EFI Live w/ CTS by Idaho Rob 197k miles
Basshole1 is offline
post #67 of 70 (permalink) Old 09-15-2014, 05:55 AM
C20ELEPHANT's Avatar
Kinda of a pain in ass and may get you into an accident lookin' at it but it works, a jotto desk might be a better idea though
When loading tunes not a good idea to use a charger on the batteries or power your laptop with the 110v charger sent with the laptop.
~ Mike H.~
2006 2500HD EXTENDED CAB LONGBED
C20ELEPHANT is offline
post #68 of 70 (permalink) Old 09-15-2014, 09:06 AM
Stone Colds Brother
08LMMWYO's Avatar
Sub'd
RIDE: 2007 Chevy CCSB LBZ colormatched Black Pearl
LIFT: ZONE, Kryptonite Front end, Cognito Brace kit, Traction Bars, Comp. Tubes
TRANS: Big Dipper Stage IV/PPE Deep Pan / Pump rub fix
SOUND:X4500BT, 6 1/2 JL Audio's, 10"s, 5 Channel JL AMP
INTERIOR: EGT/Boost Autometers & CTS, Black Cherry Denali Trim and wheel, Black Leather, Red L.E.D's, US Speedo Cluster, Rubber Floor, 20% tint
ADD ONS: 40 overs, AD II 165, Oasis Diff, Roll pan, Merchant brace, BigChevyHitch, Cowl Hood, 4500K HIDs, AMP Research Steps, LM Grille, BedRug w/ Recon lights, ExTang Solid Fold, LED tails
TIRES/WHEELS: 35X12.50-20 Toyo MT on 20x10 BMF S.O.T.A's and 4.56 Gears
AIRFLOW: EPR Triples, Turndown, AFE intercooler pipe, EFI LIVE by www.ATPtrucks.com
08LMMWYO is offline
post #69 of 70 (permalink) Old 10-21-2014, 09:25 AM
DmaxMaraman's Avatar
I have an EfiLive v2 and I have no clue where to start can anybody help direct me to somebody or give me information on where to take it to get it done correctly
DmaxMaraman is offline
post #70 of 70 (permalink) Old 10-21-2014, 11:02 AM
All the PDF files are in the software and here
https://forum.efilive.com/forum.php
Happy reading, still learning myself......
~ Mike H.~
