tuning + egr delete reflash question - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 06-15-2019, 03:15 PM Thread Starter
Just a simple question, i got my truck tuned by ppei with the dsp5 switch and such a couple months ago, and just this week i removed the egr. Will i need to reflash the tunes or should it be good to go?
spoolin_lbz is offline
post #2 of 15 (permalink) Old 06-15-2019, 07:54 PM
SilverGorillaLML's Avatar
If the egr was turned off in the tunes already you're good to go.
My name is Nic
2011 GMC Sierra 2500 CCSB LML,
Lil ole single s400, fuel,
supporting mods,
rancher tuned,
Various parts from SDP, WCFAB, LDS, DHD
Wiles Diesel Performance
Woodstock, Va
Contact me For Unleashed Duramax Tuning
[email protected]
post #3 of 15 (permalink) Old 06-15-2019, 09:55 PM
D_R_C's Avatar
If PPEI did delete tunes for you in the first place, delete tunes usually include any emissions deleting even after the fact.
If you removed the egr this means itís unplugged which is a good thing.
One quick way to verify this is to start your engines, if you donít get a check engine light your good to go.
There might be a chance the ck engine light comes on even with the delete tunes this depends on what all took place when you deleted the egr.
If it does light up then clear it, if it comes back on again then youíll have to contact your tuner.
Dan
EFILive TCM Duramax Tuner
DHD PCV Re-Route
AirDog 4G100
D_R_C is online now
post #4 of 15 (permalink) Old 06-15-2019, 10:00 PM Thread Starter
If you removed the egr this means it’s unplugged which is a good thing.
One quick way to verify this is to start your engines, if you don’t get a check engine light your good to go.
If it does light up then clear it, if it comes back on again then you’ll have to contact your tuner.
i’m pretty sure delete tunes are standard with their tuning anyways right? Also there was some plug removed from the egr before the truck was even tuned (i think it is the MAP sensor)
and with the y bridge i didn’t even plug it back in either, i just re bolted in the plug for where the sensor would go into the charge pipe
post #5 of 15 (permalink) Old 06-15-2019, 10:01 PM Thread Starter
the first start up will be most likely this monday, i’m still waiting on my arp bolts to arrive for the up pipe, snapped two off into the dang manifold 😂
post #6 of 15 (permalink) Old 06-16-2019, 10:36 AM
D_R_C's Avatar
[QUOTE=spoolin_lbz;12170419]i’m pretty sure delete tunes are standard with their tuning anyways right? [QUOTE]
Not always EFI tuning companies do offer emissions tuning.
But it sounds like your all set with what you’ve done so far, providing you’ve started the engine before the EGR delete with no ck eng light.
I’m sure when you ordered tuning that you specified delete tuning.
Good luck
Dan
DHD PCV Re-Route
AirDog 4G100
D_R_C is online now
post #7 of 15 (permalink) Old 06-16-2019, 01:23 PM Thread Starter
Idk if this has anything to do with it, but the map sensor was unplugged before tuning, and was straight piped too, not sure if those will throw a code or not tho
post #8 of 15 (permalink) Old 06-16-2019, 10:33 PM
D_R_C's Avatar
Originally Posted by spoolin_lbz View Post
iím pretty sure delete tunes are standard with their tuning anyways right? Also there was some plug removed from the egr before the truck was even tuned (i think it is the MAP sensor)
and with the y bridge i didnít even plug it back in either, i just re bolted in the plug for where the sensor would go into the charge pipe
Unless Iím missing something here.
That plug removed from the egr is power for the egr, which IMO is a good idea unplugging the egr when disabling it.
That plug is not for the map sensor, if it was unplugged youíd get a check engine light and most likely the engine would go into limp mode.
Stock:
In the picture below the red circle is the MAP sensor location, the blue circle is the MAF sensor location.
Bottom picture is a MAP sensor the red grommet goes inside the hole, ICYDK
The brand in the link takes a specific MAP sensor seal, explained in the directions.
https://underdog-diesel.com/products...m-y-bridge-kit
File Type: jpg 204E8C9C-8CC6-48B2-A29C-5BB6AE05045A.jpg (75.9 KB, 36 views)
File Type: jpeg C1116E37-EB68-41D8-936E-E33657585EDF.jpeg (10.1 KB, 36 views)
Dan
DHD PCV Re-Route
AirDog 4G100
D_R_C is online now
post #9 of 15 (permalink) Old 06-17-2019, 12:03 AM Thread Starter
[IMG class=inlineimg]/forum/images/DuramaxForum_2016/smilies/tango_face_surprise.png[/IMG]
Unless I’m missing something here.
That plug is not for the map sensor, if it was unplugged you’d get a check engine light and most likely the engine would go into limp mode.
Stock:
like with what you mentioned (in the red) the MAP sensor in my case was unplugged before even tuning the truck, that green connector however was plugged in but is now unplugged, along with the plug that connected to the egr cooler
Still had 0 check engine lights
post #10 of 15 (permalink) Old 06-17-2019, 09:08 AM
D_R_C's Avatar
Without the map sensor functioning could very well affect drivability issues and proper fueling.
You can internet search why you donít want to unplug the MAP.
Dan
DHD PCV Re-Route
AirDog 4G100
D_R_C is online now
