Ez Lynk sotf 5 tune from ppei. - Chevy and GMC Duramax Diesel Forum
 2Likes
post #1 of 15 (permalink) Old 06-23-2019, 11:21 AM Thread Starter
Ok not an efi question, but tuning related.
When itís time to load tunes, does the switch position matter.
There are 5 deleted tunes available. But the instructions arenít clear, and itís Sunday.
Stock hp
30 hp
60 hp
120 hp
180 hp.
Is there a specific position the switch needs to be in when we load each tune. Searched google and mostly get tuners websites bu no specific instructions.
MIkey52 is offline
post #2 of 15 (permalink) Old 06-23-2019, 12:12 PM
My Banks 6 gun goes from 1 (stock) to 6 (max HP) I would think that the switches work the same - progressive.
tbear640 is offline
post #3 of 15 (permalink) Old 06-23-2019, 12:13 PM Thread Starter
Yes but did you have to load multiple tunes or just the highest horse power tune?
MIkey52 is offline
post #4 of 15 (permalink) Old 06-23-2019, 06:25 PM
The tunes come preloaded and the switch selects them but if you load them manually you may have to program them to switch settings or switch may select tunes as they were loaded. You didn't get instructions or can't get answers from the place you got the equipment from?
tbear640 is offline
post #5 of 15 (permalink) Old 06-23-2019, 06:26 PM
Banks six gun comes set up and its basically plug and play.
tbear640 is offline
post #6 of 15 (permalink) Old 06-24-2019, 05:47 PM
denarli6.6's Avatar
When you install the switch into the truck to run with EZ LYNK you can pull up a parameter in EZLYNK( i beleive it is TS or something) but itll tell you the position of the switch. What i would do is install the switch and turn it all the way to the left which would be 1 on the TS parameter (if that is the name) and turn the switch and watch the parameter to see if it changes when you turn the knob. That'll let you know that the switch is installed properly and working as it should. Hope this helps
2016 LML Denali 2500
Reverse level with Mcgaughy's drop shackle set a 1"
Bilstein 5100 all-around
22x10 American Force Flux black w machined
Wehrli S300 kit w/ 66mm SXE
Wehrli CP3 conversion Race series with 10mm stroker
Profab Manifold & Up-pipes
Stock Trans For Now
Stock Sticks For Now
Air Dog 165 4G
denarli6.6 is online now
post #7 of 15 (permalink) Old 06-24-2019, 08:01 PM Thread Starter
Thanks, but I still donít understand . If I load the 0 hp time first, in switch position 1. Then load the 30 hp tune, do I need to move the switch to position 2, or will it just overwrite the 0 hp tune?
MIkey52 is offline
post #8 of 15 (permalink) Old 06-24-2019, 08:04 PM
mizterwizard's Avatar
I think what he is asking is does it matter where the switch is set while loading the new tunes? The answer is no.
The tuner overwrites the existing information in the ECM with the information that applies to the tune. First off, the new information contains a set of instructions on what to do with a particular piece of data. For example, the data might be the intake manifold pressure. The instructions will tell the computer to convert the pressure into a number and do several things with that number like adjust the injection amount and timing. How much it adjusts things is related to several tables full of numbers. Those tables are also part of the tune.
Most tunes actually keep the original information and call it "Stock". There is room in the memory of the ECM to hold more than one set of parameters. Different tables of parameters correspond to different tunes. What the switch does is tell the instructions where to go for the parameters it needs. Think of the switch as being like an index in a reference book. The index tells where to go for the maps and charts you are looking for. The switch is not involved in writing the info, only in selecting which set to use.
It is possible to edit the tunes that are already in the ECM rather than to completely overwrite them. It is also possible to overwrite one tune at a time. You can even change a single number in the vast tables. You need the right kind of tuner to do that but it can be done. Mostly what happens though is that the tune is rewritten on a desktop computer and then written in one pass to the ECM memory.
mizterwizard is offline
post #9 of 15 (permalink) Old 06-24-2019, 09:49 PM
SilverGorillaLML's Avatar
Unfortunately most people dont realize how the lml sotf tunes work. They use fuel temp to "fool" the ecm to limit mm3. That's it. You get one table with the same boost, pulse, timing etc just each one limits mm3 slightly less than the last.. Which is why I reccomend just using an autocal or v2 and switching from tune to tune if you need more than one so you actually have 5 DIFFERENT tunes. Most tuners do more than just add a little more fuel from tune to tune.
My name is Nic
2011 GMC Sierra 2500 CCSB LML,
Lil ole single s400, fuel,
supporting mods,
rancher tuned,
Various parts from SDP, WCFAB, LDS, DHD
Wiles Diesel Performance
Woodstock, Va
Contact me For Unleashed Duramax Tuning
[email protected]
post #10 of 15 (permalink) Old 06-25-2019, 10:57 AM Thread Starter
Mr wizard. Thanks, yes that is what. Was trying to ask. So I would load the highest hp tune I wanted and then the switch on 5 would give me that tune, then lower numbers should give me the lower ratings?
MIkey52 is offline
