07 Tahoe motor mount - Chevy and GMC Duramax Diesel Forum
Gas Burners Discussion of anything Gas powered.
post #1 of 6 (permalink) Old 04-10-2019, 07:21 AM Thread Starter
CA88's Avatar
My wife’s 07 Tahoe has a broken motor mount and I need to change it out. Anybody know how hard this kinda job is? What all does this entail or should I getta shop to do it? I know I can do this myself unless it calls for pullin the motor or somethin. Any help is appreciated.
*2007 Chevy Greystone Metallic 2500HD 4x4 CCSB LBZ
EFI Live by Idaho Rob DSP5, Transgo jr
Leveled, debagded, demolded
Thunderstruck front replacement bumper
285/75/16 Mickey Thompson ATZ P3
Atwood gneck hitch
Tekonsha Prodigy 3 Brake controller
Stock exhaust cat and muffler deleted with 5" tip
And more to come…
*85 Chevy 2500 custom deluxe sclb 4" lift
Needs a little work here and there…
CA88 is offline
post #2 of 6 (permalink) Old 04-10-2019, 08:41 AM
So my uncle has a 07 Denali and he says it eats motor mounts. He just gets them from the autoparts store but he replaces every few years. I know from doing my trucks, the diff in the way is the worst part. Will have to unbolt from engine and rock the engine up to get it in and out. Then I think 3 bolts holding to frame. It wasn't a huge pain just kinda got to play around with it.
2005 Silverado 2500, Crew Cab Short Bed. 122,000 miles
MODS: AFE intake, LBZ mouth piece, MBRP cat- less exhaust.
DailyDmax is offline
post #3 of 6 (permalink) Old 04-10-2019, 02:00 PM Thread Starter
CA88's Avatar
Dang that stinks for him. This is a 2wd Tahoe btw. So u think I will b able to replace it by loosening the other mounts and wiggling the old out and new in? Thanks for the quick reply.
Atwood gneck hitch
And more to come…
CA88 is offline
post #4 of 6 (permalink) Old 04-10-2019, 02:27 PM
goobs's Avatar
2wd easy. either jack or lift the motor up some after you unbolt it. in and out in an hour or so unless its on passenger side then its a lil tricky. but still doable.
Garrett, that's 2-R's & 2-T's
2015.5 ccsb HC, deep ocean blue metallic, 2wd, cst 4" knuckles, camburg 1.25" uniball uppers, fox 2.5 dsc shocks, 17x9 fuel anza beadlock, 35x12.50 maxxis razr mt.
goobs is offline
post #5 of 6 (permalink) Old 04-10-2019, 02:28 PM
You will have to lift the engine because that is sitting in the mount. The bolts are red locktighted to hell, so a propane torch will help release that so they will turn easier. I broke 1 bolt off before I figured that out.
So I would lossen up both nuts that attach the mount to the motor. I then would put a floor Jack with a board or something under the oil pan and put slight pressure on the motor. Then pull one side all the way out and lift the motor up off the mount probably 1in. Unbolt the motor mount frame side and slide it out. Then repeat for other side.
post #6 of 6 (permalink) Old 04-10-2019, 07:26 PM Thread Starter
CA88's Avatar
Don’t sound too bad of a job. Thanks everybody for ur helpful advice. I really appreciate it
Atwood gneck hitch
And more to come…
CA88 is offline
Similar Threads
07+ Tahoe / Yukon front seat arm rests? SGMdmax Gas Burners 6 12-03-2010 03:31 AM
07+ Escalade/Tahoe/Denali 2WD/AWD with Air ride. dooramax Looking For/ Wanting To Buy 3 08-14-2010 05:19 PM
07 Tahoe Service Park Assist Boss Hoss Gas Burners 1 12-15-2009 05:19 PM
07 tahoe Duramax Power Gas Burners 10 08-28-2009 10:51 AM
