Gauges - Chevy and GMC Duramax Diesel Forum
 6Likes
  • 1 Post By SilverGorillaLML
  • 1 Post By ALLY Cat
  • 1 Post By 1TRIKHD
  • 1 Post By JimmyD
  • 1 Post By D_R_C
  • 1 Post By D_R_C
post #1 of 8 (permalink) Old 01-11-2020, 05:23 AM Thread Starter
JimmyD's Avatar
Gauges
Looking to install a set of gauges in my truck.
Leaning heavily toward ISSPRO due to factory color match of the gauges.
Anyone have suggestions on these or any other gauges that I should consider before pulling the trigger?
Thanks.
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Mods so far:
DF DRW Club Member #161
JimmyD is offline
post #2 of 8 (permalink) Old 01-11-2020, 05:32 AM
SilverGorillaLML's Avatar
I have some speedhuts laying around from the old truck. I was impressed with them and the customization they allow. Check them out. I do have isspros in the new one.
JimmyD likes this.
NIC R
"Flat Back Gorilla" Daily/Tow rig- 04 GMC Sierra LB7 CC Flatbed/Tune/Exhaust
"Empty Pockets" Race/Pulling truck- 2012 CCSB Cummins/Built Engine/48RE Swap/PCS2000/
B&M Ratchet shifter/Big fuel/Big air/Lowered
post #3 of 8 (permalink) Old 01-11-2020, 07:44 AM
ALLY Cat's Avatar
ISSPROs for me. Been on my truck for about 9 years now, never had any issues. I looked at a lot of different gauges before I bought 'em, reliability was was a bigger concern than match, but they look pretty decent....
JimmyD likes this.
ALLY Cat is offline
post #4 of 8 (permalink) Old 01-11-2020, 08:52 AM
DuramaxForum Guru
1TRIKHD's Avatar
Location: Where Loggers do it better in the Woods. PNW Son!
I just picked up some autometer factory match EGT and 60psi boost guage, just need to install them before March when the track opens up again.
Sent from my VS988 using Tapatalk
JimmyD likes this.
2006 Victory Red CCLB LT3 LBZ
Tuned by Blake Crenshaw
SDP Fully Built Trans w/ Billet Goerend G Converter
S472 SX-E.87/1.0ar sitting on a Wagler street intake W/ a twisted pedestal
Stock Sticks
Special thanks to Scott with Screaming Diesel Performance
Blake with Unleashed Duramax tuning
1TRIKHD is online now
post #5 of 8 (permalink) Old 01-11-2020, 02:13 PM Thread Starter
JimmyD's Avatar
Thanks Russ, didn't know that Autometer had factor match gauges. Will check them out.
1TRIKHD likes this.
09 GMC SLT Dually
Steel Gray Metallic
Mods so far:
JimmyD is offline
post #6 of 8 (permalink) Old 01-11-2020, 09:38 PM
D_R_C's Avatar
I like the ISSPRO EV2 they have a pretty good selection of different gauges with matching faces and back light colors for GM.
I have 2 fuel psi gauges, #1 reading off my LP, #2 off the fuel test port on the engine both have a low or high red warning light located in the center bottom depending on what your monitoring.
Also Westach EGR/Boost gauge dual combo single gauge that Iíve had since 2003, itís on its second truck.
50 boost and 1500 EGT.
File Type: jpg 13A0D016-E8FC-483A-AAE6-DE40B29C8F83.jpg (70.8 KB, 46 views)
File Type: jpeg 98503449-9E63-402A-A77D-E3305ADCBB03.jpeg (24.7 KB, 45 views)
Epicenter likes this.
Dan
EFILive TCM Duramax Tuner
D_R_C is online now
post #7 of 8 (permalink) Old 01-12-2020, 09:43 AM Thread Starter
JimmyD's Avatar
Thanks for the responses guys.
Does anyone have any idea why ISSPRO gauges are so much more expensive than Autometer? Are the ISSPRO gauges that much better?
09 GMC SLT Dually
Steel Gray Metallic
Mods so far:
JimmyD is offline
post #8 of 8 (permalink) Old 01-12-2020, 11:36 AM
D_R_C's Avatar
Shop around for the best prices.
Pretty much most places/shops that I deal with claim AutoMeter are decent low cost gauges.
If you get on ISSPRO’s website search for gauges, the EV2 is the one I’m impressed with having additional functions.
I have my LP psi gauge set at 6psi for the low warning red light.
On my gauge off the test port it’s set at 5psi low warning red light.
I bought the software to adjust my own ISSPRO gauges, but ISSPRO will gladly set the low or high for you @ no charge, you just gots to send it to them or make arrangements in advance.
All gauges are dropped shipped from ISSPRO.
Look closely the gauges they should have the same layout face and color lighting as your factory gauges.
Mine does, but I don’t know about the newer models.
JimmyD likes this.
Dan
D_R_C is online now
