2018 Non Bose Stereo upgrade questions - Chevy and GMC Duramax Diesel Forum
 6Likes
post #1 of 41 (permalink) Old 07-13-2018, 03:24 PM Thread Starter
I'm wanting to augment the stock stereo system in my 2016 Crew Cab. Would like to run 1 10" subwoofer and possibly a set of components up front.
1. What are the speakers sizes? dash/front doors/rear doors
2. Where can I pull a full stereo signal from?
Thank you!
2018 Chevy 2500HD CCSB Duramax/Allison 4wd Z71
2019 BMW 330i
1973 Chevy C10 250 Inline 6 (project truck)
moregrip is offline
post #2 of 41 (permalink) Old 07-13-2018, 03:26 PM Thread Starter
Sorry, my truck is a 2018 not a 2016
2019 BMW 330i
moregrip is offline
post #3 of 41 (permalink) Old 07-13-2018, 04:05 PM
Checkout Crutchfield.com
Door speakers should be 6.5s.
Id run a shallow mount jl 10 and some jl, alpine or Memphis 6.5s.
Sierraluva likes this.
LML6600DMAX is offline
post #4 of 41 (permalink) Old 07-14-2018, 04:49 PM
I did the kicker vehicle specific system with sub/amp and digital processor for the HU. Really pleased with the easy install and overall performance. Better than Bose imo. Just another option to choose from. Down the road Id like to do door speakers as well, but no rush on those.
kenny_r is online now
post #5 of 41 (permalink) Old 07-15-2018, 04:13 PM Thread Starter
Thanks guys, I'm primarily looking for which speakers I can get a full stereo signal from or 20Hz to 20,000Hz or close to it. Some newer car speakers only receive a partial signal, mainly to support the freq's those particular speakers are designed to produce, also more common in higher end stock stereo systems rather than the base model stereo systems like mine.
2019 BMW 330i
moregrip is offline
post #6 of 41 (permalink) Old 07-18-2018, 09:59 AM Thread Starter
update, my truck has RPO codes IO6 and UQ3 which are 8" navigation screen and 6 speakers sound system. I don't believe any of the speakers are amplified and quite possible the front speakers "might" carry a full or near full signal! more to follow as I learn
2019 BMW 330i
moregrip is offline
post #7 of 41 (permalink) Old 07-18-2018, 10:52 AM
J83
J83's Avatar
Thank you!
it depends what you mean by full stereo signal, technically GM radios do not produce full range audio, they have internal filtering to reduce wear and tear on the factory speakers for a longer service life. They do this by dropping out a lot of the low end and some of the high with some fairly aggressive band pass filtering, hence the saying, "all highs, no lows, must be bose" if you just mean signal that contains low mid and high frequency then you should be able to tag signal at the radio or at the bose amp, ive only worked on a couple of the new chevy trucks but the ones i worked on had analog audio at the head unit. either way, you will for sure have signal at the bose amp outputs, front doors are your best bet for signal, rears seem to me to have heavier bass filtering, though i have not use an RTA to prove that.
If you want true full signal then you either need to use an equalizer to rebuild what was lost by the decks signal processing using an RTA, or you need to replace the deck with an aftermarket.
edit: it occurred to me after posting that it says NON bose, so in that case, you should have audio at the head unit directly wired to each speaker. GM did change the standard radio wire colors on the NNBS trucks though if memory serves, do not use the NBS or OBS wiring info.
J83 is offline
post #8 of 41 (permalink) Old 07-18-2018, 05:29 PM Thread Starter
Would you happen to know if resistors are needed with the GM trucks if you remove the stock speakers (like an Audio Control LGD)? I'm not sure I understand what you mean by analog but in my head that means legacy or "how it used to be" and therefore may not need the resistors to produce sound when hooking up an amplifier.
I suppose I could drop some coin on an Audio Control LC7i that could do some summing and provide 3 channels of output........thoughts?
2019 BMW 330i
moregrip is offline
post #9 of 41 (permalink) Old 07-18-2018, 07:21 PM
J83
J83's Avatar
analog would mean that the deck produces an AC wave that plays directly to the speakers. That does not necessarily mean the deck does not have sensing for dead speakers (when you would need resistors) some decks send a digital signal to a amplifier that decodes the data, processes it, amplifies it, then sends an analog signal to the speakers. This can be done either over copper wire, or plastic fiber optic cable depending on the design of the car. GM does not use fiber optic cable, so you are in the clear there.
i have not done a 18, but i have done a 17 and resistors were not required, at least when replacing the speakers with an aftermarket with a 4 ohm voice coil.
I have used resistors on that truck before, but only when amplifying the door speakers. The resistor was used to keep the factory tweeters from blowing your eardrums with the door chime.
while i have not personally used the summing device you are talking about, i do know about it, and have heard lots of good things about it. I will tell you that the factory radio on those new trucks really cuts the bass hard, without some kind of signal processor, your final results (sub wise) may be underwhelming.
moregrip likes this.
J83 is offline
post #10 of 41 (permalink) Old 07-27-2018, 02:12 PM Thread Starter
Right now the plan looks something like this
Line Out Converter =
Audio Control LC2i
Front Door and Dash Speakers/Amplifier =
1x Pioneer GM-D8604 Class FD 4-Channel 600W amp
1x Pioneer TS-D1720C 6.75-Inch D-Series Components
Rear Door Speakers =
Stock
Under Rear Seat Subwoofer/Amplifier =
1x Pioneer GM-D8601 Class D Mono 800W amp
1x Sundown Audio SA-10 D2 Rev 2 (10" Dual 2-Ohm SA Series Sub)
Possibly a LC7i over the LC2i, use the component tweets in the dash position, 6.75" in the front doors, maybe sending power to stock rear door speakers
2019 BMW 330i
moregrip is offline
