Oil Pressure Sensor - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 08-04-2019, 07:22 PM Thread Starter
Oil Pressure Sensor
Im working my way thru a P0652 code problem. The 5V ref2 is 0 volts. I have disconnected every sensor on that circuit save one. For any of you who have actually ever disconnected the oil sending unit, how in the world did you get the connector off?. I can touch it with two fingers but no more. Motor mount disconnect? Oil filter housing removal?
2007.5 LMM
Thanks for any info
Spyder27 is offline
post #2 of 10 (permalink) Old 08-04-2019, 10:10 PM
LHN...We ARE the Joneses
It has a center tab lock to lift and release to pull.
Are you underneath or inner fender liner removed and reaching in from the side well?
Hook'em_Horns! is online now
post #3 of 10 (permalink) Old 08-05-2019, 01:25 AM Thread Starter
I removed the liner because that is what was recommended. But, now that I know where it is, I cant even see it from the wheel well. Thats why I'm wondering if the motor mount has to come out. Underneath I can see it but cannot do much more than touch it. I think I can change it from underneath with socket and extentions if I can get the connector off.
Spyder27 is offline
post #4 of 10 (permalink) Old 08-05-2019, 02:55 PM
You want to do this because you are testing to see if your EOP sensor is shorted on your 5v reference?
  1. Turn OFF the ignition for 30 seconds or until the ECM powers down.
  2. Disconnect the accelerator pedal position (APP) sensor.
  3. Turn ON the ignition, with engine OFF and measure the voltage from the 5-volt reference circuit of the APP sensor 2 to a good ground with a DMM.
    • If the voltage measures 4.7-5.2 volts, replace the APP sensor.
  1. With the DMM still connected to the 5-volt reference circuit, disconnect all other components connected to the 5-volt reference 2, one at a time.
    • If voltage changes when one of the above components is disconnected, replace the component.
  1. Test the 5-volt reference 2 circuits for a short to ground or a short to voltage.
    • If no problem was found in the 5-volt reference 2 circuit, replace the ECM.
Ron Nielson
Ron Nielson is offline
post #5 of 10 (permalink) Old 08-05-2019, 03:21 PM Thread Starter
Yes, of the 5 items on the circuit the EOP is the only one left. Intentionally left for last because of the above mentioned access issue.
Spyder27 is offline
post #6 of 10 (permalink) Old 08-08-2019, 12:53 PM Thread Starter
Ok so i made a tool with a coat hanger and after a few tries and some force I was able to get the connector pulled off. 5V2 ref still zero. Thats all 5 sensors disconnected so on to ECM. Not looking good.
Spyder27 is offline
post #7 of 10 (permalink) Old 08-08-2019, 12:56 PM
Not looking good.
Not too bad at Rock
OE reman has the same warranty (24mos) as new.
https://www.rockauto.com/en/moreinfo...438268&jsn=464
post #8 of 10 (permalink) Old 08-09-2019, 10:32 AM
And now ECM about $280 after rebate at Amazon for refurb.
Ron Nielson
post #9 of 10 (permalink) Old 08-09-2019, 12:38 PM Thread Starter
Thanks for that info. Some of you guys on here may have changed out ECM but it sounds a little hairy to me. The description on alldatadiy is far from just swapping parts. Hard to get good info on the ecm swap. On top of that, I also heard ill have to buy another dpf delete tune if I swap ecms. I dont know if any of that it true.
Spyder27 is offline
post #10 of 10 (permalink) Old 08-09-2019, 02:26 PM
For sure you will have to have your new ECM programmed so that it works with your truck and it's modifications, and if you need a DPF tune, keep that in mind. But physically, it's just a parts replacement. You can buy pre-programmed ecm's that will have the DPF delete included, and then it would be just a parts swap. If you buy new from say Amazon, then you need to get the tune added elsewhere.
Here are a couple of important statements from ALLDATADIY:
Important: Before removing the engine control module (ECM), use the scan tool to capture the ECM data. This captured data will then need to be restored into the NEW ECM.
and at the end of the procedure,
If a NEW ECM was installed, program the ECM. See: Testing and Inspection\Programming and Relearning
Ron Nielson
