Help Needed (Fuel Filter) - Page 3 - Chevy and GMC Duramax Diesel Forum
 11Likes
post #21 of 28 (permalink) Unread 10-02-2019, 05:25 AM Thread Starter
I am going to attempt installing the new one tonight after work..
Are the fuel lines easy to get on ? any tricks to get them on easier ? That is the only part I am worried about.
Do they usually go on easy ?
1985TS is online now
post #22 of 28 (permalink) Unread 10-02-2019, 06:43 AM
LHN...We ARE the Joneses
Going on, yes.
Coming off,...they can bond to the metal, but a pick inserted and worked around the tube can break the bond and off they come.
Hook'em_Horns! is online now
post #23 of 28 (permalink) Unread 10-02-2019, 07:52 AM
NHfireDmax's Avatar
A lil dab of spit makes em slide on easy if tough...
2019 Quartz Red Denali HD Chrome deleted
NHfireDmax is offline
post #24 of 28 (permalink) Unread 10-02-2019, 09:59 AM Thread Starter
Going on, yes.
That's good to hear. I already have the fuel lines off, they weren't too bad, I used a small flathead first to loosen them up, took a little work..
post #25 of 28 (permalink) Unread 10-02-2019, 12:05 PM
get it on yet? they always go on easier than when they come off.
Big Daddy Yum Yum is offline
post #26 of 28 (permalink) Unread 10-04-2019, 07:16 AM Thread Starter
Yes! got it on no problems .. .fuel lines were super easy to get back on ..
THANKS FOR THE HELP EVERYONE. specially those who posted pictures ..
onetigger725 likes this.
post #27 of 28 (permalink) Unread 10-04-2019, 10:34 AM
4welynn's Avatar
I wish I would of caught your post earlier. The filter head orings are prone to leak air after several years of service, so the good thing is that you replaced the fuel filter head for not just your recent issue. But I would of strongly suggested that you replace the 2 fuel hoses that connect to the filter head because of age . They get soft and collapse because the fuel is being sucked to the fuel pump(CP3). There is some simple preventative maintenance that you can do to help your LBZ run for many years to come. There is a lot of good suggestion in the maintenance section of this forum.
06 HD2500 CC SB LT3 LBZ
EFI by Rob, DSP5, EGR blocked, 4" MBRP cat deleted, Edge CTS, Bilstein 5100 and stabilizer, Titan 52 gal tank, air lift in rear, Helo Max w/Ridge Grappler LT285/70R17.
4welynn is offline
post #28 of 28 (permalink) Unread 10-05-2019, 03:31 AM Thread Starter
Thanks !
I bought the truck from a friend from work who was OCD on preventative maintenance. He replaced the starter / alternator just because they were 5 years old. brake lines because he read on the forum they rust ..
My truck has 275,000 miles, original injectors, when we checked 2 years ago the balance rates were good as new. .
I have been using a little bit of the amsoil injector cleaner every once in a while as well, not sure if that helps ..
