Broke off glow plug connector - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By DaJokr
post #1 of 7 (permalink) Old 12-07-2019, 04:29 PM Thread Starter
Solo Ascent's Avatar
I only found one similar post and no resolution. I broke off the end of the glow plug connector. I can't tell if the glow plug wires are two wires or one. It is too hard to see close, but I just soldered on a new end. Anyone dealt with this that knows how to fix them? I think my solution will work but I don't want to try it until I have someone with knowledge to help out. Thanks. It's a 04 lly. I'll add pictures.
Last edited by Solo Ascent; 12-07-2019 at 04:32 PM. Reason: it added weird apostrophes
Solo Ascent is offline
post #2 of 7 (permalink) Old 12-07-2019, 04:46 PM Thread Starter
Here's the broken.
Here's the new end
Can I fix it like this?
2004 LLY Duramax.
Silverado Crew Cab LT
post #3 of 7 (permalink) Old 12-07-2019, 06:53 PM Thread Starter
Should I cut the wire and splice on a new extension? I just wrapped an end over the copper crimp that was left and soldered the new crimp onto the remaining copper crimp. Should I cut the wire and splice? I just don’t know if there are two wires or if it is just one hot wire.
post #4 of 7 (permalink) Old 12-08-2019, 05:17 AM
ieetgluu's Avatar
One wire to each plug
Sent from my SM-N920V using Tapatalk
Chad
04.5 4x4 ~160k miles
DE 4", 5100s, LBZ MP, S&B LBZ air, KoryWillis Go-go Juice, Insight CTS, ADII, 8' Fisher, Highroller Ultimate Idler Arm, Profab delete, XD RareParts tie rods
Dirtymax this, Dirtymax that... :taunt
ieetgluu is offline
post #5 of 7 (permalink) Old 12-08-2019, 05:36 AM
407driver's Avatar
One stranded wire, it is energized by the GPCM and grounded thru the GP to the head.
What you did will work like a champ! Good Job!
When putting it back on use your index finger on the other hand to prevent the terminal from rotating and repeating the issue.
I know you already figured that out, but others who read this may not have. So I thought a little instruction may save some other poor soul from having this happen to them too.
407driver is offline
post #6 of 7 (permalink) Old 12-08-2019, 06:56 AM
beardedlbzguy's Avatar
I just sent you a response to your PM and then seen this post.
Your problem was similar to mine where the ring broke off, but you fixed yours the same way as I did mine. Like I said, I haven't had any problems since I fixed it like that.
Sent from my SM-G950U using Tapatalk
2006 Silverado 2500HD CCSB
345k+
Painted Stock wheels
beardedlbzguy is offline
post #7 of 7 (permalink) Old 12-08-2019, 09:28 AM
DaJokr's Avatar
As long as the solder connection is good, thats basically a shop repair right there.
Dean E likes this.
Beastly Build
LBZ Drag Racing
2006 GMC LBZ 4x4 CC/SB
1/4 Mile [email protected]
1.793 60'
DIED 09/19/17 11:02AM
REVIVED 12/21/17 3:57PM
DaJokr is offline
