FASS Lift Pump install using WEHRLI relocation bracket - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By 407driver
post #1 of 6 (permalink) Old 01-19-2020, 12:23 AM Thread Starter
Evil1974's Avatar
Installed my Fass pump with Wehrli's new bracket
https://www.wcfab.com/i-31643996-fas...b-duramax.html
2015 GMC Sierra 2500HD LML CC/SB 4x4 Denali S&B CAI, Resonator delete, Retrofit source HID, Rigid Ind Dot fog lights, Method NV HD 18x9 +18 wheels, Amp steps, EDGE INSIGHT CTS 2, King 2.5 Oem performance series shocks, 30inch OnX6 Baja Designs light bar. FASS 165G Lift Pump/On Wehrli relocation bracket Beans sump
Evil1974 is offline
post #2 of 6 (permalink) Old 01-19-2020, 07:13 AM
407driver's Avatar
Very elegant install with that bracket. They make one for a 2001-2016 too.
I hated the FASS bracket and original mount location. I moved mine to the second bed bolt on the drivers side.
I used a piece of old floor mat in front of the LR wheel to keep it from getting coated with dirt/gravel. It works but that new bracket would have saved me some inventiveness.
HWI likes this.
407driver is online now
post #3 of 6 (permalink) Old 01-19-2020, 08:52 AM
19trax95's Avatar
Very nice setup.
I definitely will be looking into this come spring and I pull the bed off again to do some cleaning and changing up the lines a bit.
Definitely is more protected and hidden there vs on the bed bolt mount.
2015.5 2500HD LML
19trax95 is online now
post #4 of 6 (permalink) Old 01-19-2020, 01:59 PM Thread Starter
Evil1974's Avatar
I took this pic farther back so you can see how hidden it is
Evil1974 is offline
post #5 of 6 (permalink) Old 01-19-2020, 04:27 PM
Looks good maybe I'll make something & move mine. Won't be as easy to steal there.
04 GMC LB7 2500 SAC 45 injectors DSP5 EFI live, ported air inlet. 4" MBRP droning exhaust.
77cruiser is online now
post #6 of 6 (permalink) Old 01-19-2020, 05:50 PM
HWI
HWI's Avatar
This is exactly what I did as well, but used an old mud flap vice floor mat. Got the job done, but that bracket looks nice, may pick one up in the future when it's time to change out the fuel lines.
06 LBZ CCSB
With some stuff.
HWI is offline
