Glow plugs keep failing - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 10-23-2014, 02:35 PM Thread Starter
Hello all. Thanks in advance for any replies.
I have a 2006 2500HD LBZ motor. I had to let my wife drive it about a month ago unfortunately. Of course when I get back into it the check engine light is on. I have an edge tuner, so I pull up P0675 glow plug number 5. No big deal, I have extras, get home and swap it out. Truck works fine for following two days, then I go to start it, and glow plug light won't shut off. I wait prob 5-10 seconds and check engine light flashes and comes back on. Pull up the code and once again P0675. My first thought is the glowplug had been sitting for years, maybe it had just got banged around in my tool box. I order a set of new ones. Before they get here, and while I was still driving the truck, I pulled the code again one day and I am getting P0678 now too. New glowplugs come, I swap out number 5 and 8. Truck cooled off for a few hours and I went out to test it. Light shut off like normal and started right up. Works fine for a few days, then another cold start, glow plug light doesn't shut off. Engine light on and code is saying p0675 and p0678 again. Obviously something is causing them too fail. Where do I start? follow the glowplug wires to the relay and replace those? Where and how do I check the controlling unit for the glowplugs? Thanks again.
Oh and each time I swapped them, the bad ones had max resistance reading on the ohm meter. New ones had .8-.9.
KA4993 is offline
post #2 of 11 (permalink) Old 10-23-2014, 04:31 PM
jc8825's Avatar
Sounds more like the glow plug controller. I do not know how to test the unit.
NOTHING WORKS LIKE A CHEVY TRUCK.
2007.5 Silverado 2500HD WT 4X4 LMM Victory Red
2017 Honda Accord Sport 6MT Crystal Black Pearl
2006 R53 MINI Cooper Sa Dark Silver
jc8825 is offline
post #3 of 11 (permalink) Old 10-23-2014, 06:21 PM
mguay's Avatar
My LBZ was eating Glow Plugs too for a while. Turned out to be a bad battery. I have no idea why it would matter? A friend of mine is a tech and figured it out. Swapped in 2 new batts and it stopped throwing the code...even with the old GP still in it!
2015.5 GMC 3500 Denali DRW CC Sonoma Red/Cocoa-Dune
Banks DPF Back Monster Exhaust
Banks Ram Air CAI
CTS Insight
Transfer Flow 50 gal Cross Bed
DWR CLUB # 185
mguay is offline
post #4 of 11 (permalink) Old 11-25-2014, 08:46 AM Thread Starter
Thanks for replying gents. Just finally getting time to dive into this ghost problem again. I will test the batteries and see what that brings since it is the easiest to test.
KA4993 is offline
post #5 of 11 (permalink) Old 11-25-2014, 09:59 AM
biketopia's Avatar
Test them separately as one bad one can be disguised by a good one, and if one tests bad, replace them both, good luck.
2003 2500HD LT CCLB, EFILive by Idaho Rob, 4" MBRP, Diamond Eye Down Pipe, Ported Intake Horn, S&B Intake, PPE Boost Valve, ADII, Nicktane CAT Adapter, CTS Insight, Cognito UCA, Rare Parts Tie Rods, Cognito Brace kit, Bilsteins, Gear Alloy wheels, Hankook RF10 285's, All on Mod, DDM 5k Low's & 4300 Fogs, air horn, on board air, limo tint, blue led interior
biketopia is offline
post #6 of 11 (permalink) Old 11-25-2014, 02:42 PM
trickydave's Avatar
gm also has a tsb/recall for a reflash for lbz's for repated glow plug failure. basically the original programming is too harsh on the glow plug system.
2006 lbz cclb dually, white, 4in flo pro, sled deck!
sold--2003 lb7 eclb, auto meter gauges boost/pyro, mbrp 4in, moto metal 951's LT275/65/18, 3500 rear springs.
EFI LIVE by ATP TRUCKS!
In the garage:
2006 all american sport 281fb toyhauler
2005 trx450r mx quad
1996 starcraft 2212 cuddy, 5.7l
2001 kawasaki zx6r
2007 ski doo mxzx 600sdi, 2012 arctic cat f800
2002 honda foreman 450es built for mud!!
trickydave is offline
post #7 of 11 (permalink) Old 05-29-2015, 08:36 AM Thread Starter
Long overdue update. I swapped two brand new batteries into the truck and saw no change with DTC codes, P0675 and P0678. I purchased a new glowplug control module from DMAXstore.com. Installed it and cleared the codes. They instantly came right back and now I have a new P160c engine calibration code. I'll be swapping back to the old one since that obviously isnt it. Any other tips?
KA4993 is offline
post #8 of 11 (permalink) Old 05-31-2015, 03:58 AM
poosniffer's Avatar
I had this problem as well.You need to use Genuine AC Delco glow plugs since the resistance of some aftermarket GPs might be different which will cause the code to come back.If you absolutely want to use aftermarket glow plugs you will need to switch ALL 8 to avoid the CEL.
2018 Toyota Tundra Platinum Crewmax
SOLD:2008 LMM Silverado 2500 LTZ ECSB 4X4.
Aftermarket DSP5 calibration by Danville Performance, Blocked and re-routed, Nicktane with Baldwin BF7587, PPE lift pump with Baldwin BF1212 water separator, 285/75/17 Dura Grapplers on H2s, CTS Insight with pyro.HIDs in fogs and high beams.
Proud Member U/A Local 693 Plumbers/Pipefitters.
poosniffer is offline
post #9 of 11 (permalink) Old 06-01-2015, 11:02 AM Thread Starter
You my friend are a life saver. Thought I was going nuts when I checked the "bad" aftermarket glowplug and the resistance was showing the plug was good. Swapped 2 AC Delco 9g in there hoping they wouldn't conflict with the 61g plugs and they dont seem to be. Thanks for the help.
KA4993 is offline
post #10 of 11 (permalink) Old 06-01-2015, 11:53 AM Thread Starter
And I now have a slightly used control module for sale. Purchased, plugged in, found out it wasn't the problem, and taken back out. Purchased from DMAXstore.com. PM me if interested.
KA4993 is offline
