Lmm dpf delete - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 16 (permalink) Old 02-27-2018, 04:39 AM
poosniffer's Avatar
Why not just leave all the EGR components intact and slip in a blocker plate.This is what I did.If/when I ever decide to sell my truck it can easily be returned to stock after the DPF is put back on of course.
2018 Toyota Tundra Platinum Crewmax
SOLD:2008 LMM Silverado 2500 LTZ ECSB 4X4.
Aftermarket DSP5 calibration by Danville Performance, Blocked and re-routed, Nicktane with Baldwin BF7587, PPE lift pump with Baldwin BF1212 water separator, 285/75/17 Dura Grapplers on H2s, CTS Insight with pyro.HIDs in fogs and high beams.
Proud Member U/A Local 693 Plumbers/Pipefitters.
poosniffer is offline
post #12 of 16 (permalink) Old 02-27-2018, 11:52 AM Thread Starter
Davechevy07's Avatar
Have you had any issues with the blocker plate?
Davechevy07 is offline
post #13 of 16 (permalink) Old 02-27-2018, 11:53 AM Thread Starter
post #14 of 16 (permalink) Old 02-28-2018, 12:21 PM
407driver's Avatar
The blocker plate leaves the EGR Cooler intact. It can still leak and put coolant into the cylinders with disastrous conseuences
407driver is online now
post #15 of 16 (permalink) Old 03-03-2018, 04:14 PM Thread Starter
Originally Posted by Timmer View Post
HSP, SDP, W FAB any of those would be quality kits. I got HSP. Rule of thumb, you get what you pay for. a cheapy ebay pipe wont fit as good etc.
I'm going to go with HSP. Witch cold side pipe are you running? The one that uses the stock bridge or the max flow y bridge? Also wondering if the pipe that uses the stock y bridge has enough bracing to keep the elbow from blowing out? Can't decide wether to go with that pipe or pony up the cash and go with the max flow y bridge....
post #16 of 16 (permalink) Old 03-06-2018, 01:27 AM
Timmer's Avatar
Idk i'm the kind of person likes to do things once. not saying you will have problems with Y bridge. But my research found that many do, I did the high flow Y bridge for peace of mind. Someone makes a strap that goes over the stock Y bridge to help it stay in place, not sure about the stock Y bridge from them far as bracing. It is quite involved project if you go with new Y bridge.
2008 3500 DRW, EFI with Rob's tunes, PPE downpipe and Flopro 5in strait pipe, HSP Y bridge/egr delete, HSP hot side I/C pipe, PVC rerouted, Fass 165, CTS 2, Trans go jr, Airaid intake.
Timmer is offline
