06 3500 Hate My Brakes - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 03-29-2018, 12:23 PM Thread Starter
Does anyone know if there is actually a good upgrade for brakes. Can this truck get a larger Rotor ?
Bob06 is offline
post #2 of 14 (permalink) Old 03-29-2018, 01:14 PM
LHN...We ARE the Joneses
If you find it insufficient, it's probably the overall condition of the brake system as a whole.
(fresh brake fluid, lubed slide pins, non-expanding old/worn brake lines, etc.)
When everything is working right, she'll stop a load just fine.
Although, I do have some 'upgrades', sorta.
Hook'em_Horns! is online now
post #3 of 14 (permalink) Old 03-29-2018, 02:49 PM
Blue Granite's Avatar
Sub'd as I'll be rebuilding the front end and while I'm in there, might as well upgrade my squealing and dusty brakes. You'll read mixed reviews about drilled and slotted rotors as far as longevity and what not. Most will recommend fresh OEM brakes as they seem to last 150k miles at a time.
2006 LBZ CCSB 4x4
Goals: Daily driver that's a little faster and a whole lot stronger.
Performance: 5" Dumped Cat-back | S&B Intake
Suspension: 6" Fabtech | 325x60R20 Trail Graps | 20x10 Hostile Strykers | 2" Bora Spacers | Updated Rear Cab Mounts
Steering: Redhead | PISK | LMM PS Pump | GM Cooler | Stock Toothpicks
Blue Granite is offline
post #4 of 14 (permalink) Old 04-02-2018, 10:14 AM Thread Starter
Do they make a larger oil filter for 06 LBZ.
Bob06 is offline
post #5 of 14 (permalink) Old 04-02-2018, 01:57 PM
Probably not a good path to venture into, possible restrictions and all.
You can get a extended life (like when using Syn) filter with the synthetic media Mobile 1 (M1-303)....usually 'bout $10 at Wally's place.
post #6 of 14 (permalink) Old 04-02-2018, 02:04 PM Thread Starter
Thanks for reply just was looking for some added Filtration , coming up on 300k and have changed oil ever 3k since it was new.
Bob06 is offline
post #7 of 14 (permalink) Old 04-02-2018, 02:12 PM
I run Schaeffer's 9000 full syn, with the M1-303 syn filter.
On average, 10k mile intervals....all miles towing heavy.
The Dmax doesn't kick out much psi, BUT the volume of oil it moves is high. An oil filter restriction could be fatal.
post #8 of 14 (permalink) Old 06-20-2018, 05:06 AM Thread Starter
Gear oil leak
Seems like oil leaking from rear differential vent. Any suggestions.
Bob06 is offline
post #9 of 14 (permalink) Old 01-22-2019, 11:21 AM Thread Starter
DEF FUSTRATIONS 2013
Service exhaust system message is on again reducing speed to 65 MPH. Could this have to do with cold temperatures in the last couple days. Can’t handle going back to CHEVY again.
Bob06 is offline
post #10 of 14 (permalink) Old 01-23-2019, 04:43 AM Thread Starter
2013 2500hd. Def issues
Service exhaust system message came on after temps went to single digits. Any chance this will reset??
Bob06 is offline
