Annoying da*n serpentine belt LMM - Chevy and GMC Duramax Diesel Forum
 2Likes
  • 2 Post By Hook'em_Horns!
post #1 of 9 (permalink) Old 03-07-2019, 05:35 PM Thread Starter
SaucebossLBZ's Avatar
Brand new Serp brand new tensioner no idea where the squeel is coming from .. just to see if I can pin point it I squirted a tiny bit of wd40 on the inside of the belt sound went away on idle and got way louder during acceleration.. I’ve about had it with this embarrassment belt I’m going to ghost ride the truck into the pacific
09' LMM 2500HD
EFI live custom 5 tunes
Alligator trans tuning
Fas 150 titanium LP w/ Donalson twist and drain filters
DPF delete
EGR delete
MBP 5" turbo back
Precision triple disc TC
BD valve body, pump,
Transgo Jr. shift kit
Just rolled 115,000
SaucebossLBZ is offline
post #2 of 9 (permalink) Old 03-08-2019, 09:53 AM
Bearings o k in alternator?
MIkey52 is offline
post #3 of 9 (permalink) Old 03-08-2019, 10:06 AM Thread Starter
Had a mechanic change the belt and tensioner he tested the alternator and said it was fine I have no idea.. never had a problem with the alternator
09' LMM 2500HD
DPF delete
EGR delete
MBP 5" turbo back
Just rolled 115,000
post #4 of 9 (permalink) Old 03-08-2019, 10:09 AM
Just that sometimes squealing belts are caused by something thatís hard to turn so it slips somewhere. The wd40 just gives it a little more traction, for a short while. Could also be ps pump or ac compressor, or just a cheap belt.
MIkey52 is offline
post #5 of 9 (permalink) Old 03-08-2019, 10:29 AM
LHN...We ARE the Joneses
Drive belt replacement involves a package of parts that wear together;
Belt, Tensioner pulley, AND both idler pulleys (3 if you have dual alternators).
Did your Tech also swap those two $17 items at the same time?
Also, look at your pulley on your alternator.
Does it have a large nut visible in the center?
Or does it have a flat disc covering the front of it?
If it's a disk, that's a clutch pulley and they can fail and leave an annoying chirp like a belt does. The Alt will test fine, but a stethoscope will reveal the source if it is the pulley clutch. As well as if it's coming from the PS pump. AC off will rule out the compressor as a source.
Ron Nielson and FAIRCHASE like this.
Hook'em_Horns! is online now
post #6 of 9 (permalink) Old 03-08-2019, 03:09 PM
My LMM likes to squeak on occasion. I've changed everything together as Hook mentioned above, and I still get it. I suspect its a slightly out of alignment power steering pump pulley in my case. Might want to check that. I will be checking mine soon, in the meantime, spraying some vinylex or other rubber lube on the belt stops it for a few thousand miles.
corneredge is offline
post #7 of 9 (permalink) Old 03-08-2019, 04:28 PM Thread Starter
I put baby powder on it and boom it stopped ! Went to the store down came back still nothing. .. pulled infront of my house and my buddy was driving by in his 6.7 PS . So i decided to launch it ( blew his doors off LMM power baby ! .. turned around noticed it was squeaking again ugh.. where do I get Vinylex ?
09' LMM 2500HD
DPF delete
EGR delete
MBP 5" turbo back
Just rolled 115,000
post #8 of 9 (permalink) Old 03-08-2019, 04:30 PM Thread Starter
It has a Nut in the front .. don’t know what the tech did as I bought this truck offf some guy from my town . All I was told was the belt was replaced the day before I bought it and new tensioner .. he did all the fluids also except trans
09' LMM 2500HD
DPF delete
EGR delete
MBP 5" turbo back
Just rolled 115,000
post #9 of 9 (permalink) Old 03-08-2019, 04:33 PM Thread Starter
Just that sometimes squealing belts are caused by something that’s hard to turn so it slips somewhere. The wd40 just gives it a little more traction, for a short while. Could also be ps pump or ac compressor, or just a cheap belt.
Yup. That’s why I hate having noises belts it’s a nightmare trying to pin point it and if you can’t you just have to start replacing stuff until you find it
09' LMM 2500HD
DPF delete
EGR delete
MBP 5" turbo back
Just rolled 115,000
Similar Threads
LMM-serpentine- belt or kit - gates oscyjack Maintenance 4 04-09-2016 02:01 PM
serpentine belt idrivebowtie 06-07 LBZ & LLY Duramax Powertrain 9 12-10-2009 08:12 PM
Idler Pulley for Serpentine belt- Rattling Hausz 01-04.5 LB7 Duramax Powertrain 18 10-06-2009 05:05 PM
Serpentine belt/Timing belt bowhunternkbay General Discussion 6 02-23-2009 04:51 PM
