New to diesels ! What’s my best choice for filters? - Chevy and GMC Duramax Diesel Forum
 8Likes
post #1 of 24 (permalink) Old 04-14-2019, 11:31 AM Thread Starter
Jberger93's Avatar
I’ve done some research and there are multiple answers to this .i was thinking this for fuel filter? Will this fit in stock ? https://www.amazon.com/Caterpillar-1...gateway&sr=8-4
Also do you guys recommend installing a lift pump at 138k miles ?i have a 2006 lbz
2006 Chevy Silverado 4x4 2500hd LBZ - 139k miles
Jberger93 is offline
post #2 of 24 (permalink) Old 04-14-2019, 12:31 PM
LHN...We ARE the Joneses
No
No.
LP...Your choice, but you don't need a fire hydrant.
Sierraluva likes this.
Hook'em_Horns! is offline
post #3 of 24 (permalink) Old 04-14-2019, 12:31 PM
Uh, No
No.
post #4 of 24 (permalink) Old 04-14-2019, 12:35 PM Thread Starter
Jberger93's Avatar
Uh, No
No.
What fuel filter do you run , also my computer on dashboard says there’s 19 percent life left in filter . How often do iou change it ? Is 19 percent low ?
post #5 of 24 (permalink) Old 04-14-2019, 01:16 PM
Below %10 is low, below %5 is lower, and below %0 is lowest.
MIkey52 is offline
post #6 of 24 (permalink) Old 04-14-2019, 01:20 PM
Mine is different, I'm running 3 filters and a JK lift pump.
But in the stock location, one of these are the top 3;
Baldwin BF46062
acDelco TP3018
Parker-Racor PFF50216
As for the DIC % (suggestion) or at what point, it is possible to put together a compund test gauge with an adapter to fit the bleed port on the fuel filter head. ('bout $25)
Clean filter baseline will show 2"Hg.
4-5"Hg is a restriction and needs to be changed out.
This^ will get the greatest lifespan use.
Or you can just follow the %, unless you feel a drop in performance or any type of fuel pressure codes that pop up.
Enigma66, 830king and Sierraluva like this.
post #7 of 24 (permalink) Old 04-14-2019, 02:30 PM
830king's Avatar
There is only 1 thing wrong with that cat filter. It has no water separator, so if you buy the adapter and use that filter you loose water separating capabilities. Most lift pumps have a water separator and a filter on them, if you have a lift pump than you can use the cat filter if you like.
There are filters that fit the adapter, I'd have to dig but I can find you the part number for a Donaldson filter with a built in water separator that fits the adapter. But wouldn't it just be easier to use a better filter that dont need a adapter? Hookem listed 3 that will fit right on your filter head with no adapter. Personally I run the parker racor on mine.
If you think you want to get a adapter Joe had a used one for sale in the classifieds on this site.
Sent from my SM-G930V using Tapatalk
My name is Dan, I drive a 2005 2500hd ccsb lly 4x4, victory red, Efi live Robs trans safe tunes, Edge cts w/pyro, Silverline 5" exhaust, Magnaflow downpipe, LML ds manifold, Arp head studs, S&b turbo inlet, S&b cai dry filter, Ppe shim kit, drilled fuel rails, B&w turnover gooseneck, Ma welded waterpump, Profab egr delete, Fass titanium 150, Beans fuel sump, Ma pump rub plate, 285/75-16 duratrac on stock rims, Kryptonite tie rod & centerlink, Kryptonite sway bar end links, kryptonite lower ball joints Rare parts extreme duty pitman and idler arms, Dhd steering brace, Alligator 5/8" trans lines.
830king is offline
post #8 of 24 (permalink) Old 04-14-2019, 03:30 PM Thread Starter
Jberger93's Avatar
I just ordered the Fass lift pump 095. Does that come with the filters ? Or do I need to order some
post #9 of 24 (permalink) Old 04-14-2019, 03:33 PM
Do you want us to lookup what's on HBO tonight for you too?
AlisoBob is offline
post #10 of 24 (permalink) Old 04-14-2019, 03:34 PM Thread Starter
Jberger93's Avatar
No , when you look up the kit tho it doesn’t mention what all comes with it ...
Similar Threads
PVC reroute. Is it worth it? Pro’s vs Con’s kuntrykid 11-16 LML Performance Parts Discussion 47 02-15-2019 11:21 AM
Can’t clear codes, truck won’t shift out of 1st Gear MAXED-OUT Drivetrain 6 08-20-2018 05:14 AM
2018 2500 - best leveling kit that won’t aftect ride quality? Ready2roll Suspension&Steering 3 06-13-2018 03:56 PM
35’s or 37’s Edgar510 Suspension&Steering 3 05-13-2018 06:36 AM
Time to change fuel filters. what can I cross reference my FASS filters over to? turbodon 01-04.5 LB7 Duramax Powertrain 4 06-28-2014 06:59 AM
