Code P0087 - Chevy and GMC Duramax Diesel Forum
 3Likes
post #1 of 12 (permalink) Old 04-23-2019, 07:26 PM Thread Starter
Code P0087
I have a headache with this code p0087. I'm traveling cross country from CA to Va. in Tx the error code p0087 put my engine in low power mode. I was able to replace the fuel filter and after ca. 2'000 mil it repeated the same scenario. I replaced the fuel filter again and the engine is working normal. Any idea what going on?
remiontheroad is offline
post #2 of 12 (permalink) Old 04-23-2019, 07:43 PM
SST 1953's Avatar
Are you empty, towing, on the flat, running hills? Give us a little info so we can throw out some ideas. Low fuel rail pressure can have many causes.
2016 CCLB Dually LML
SOLD: 2007 CCSB LBZ.
69 Camaro S/ST-S/Gas
SST 1953 is offline
post #3 of 12 (permalink) Old 04-23-2019, 07:49 PM Thread Starter
Yes I'm towing a 40 ft camper ca 15'000 lbs driving average speed about 63 mph in 5th gear. Driving this combination for many all the way to Alaska with no problem?!
post #4 of 12 (permalink) Old 04-23-2019, 07:52 PM
SilverGorillaLML's Avatar
What's done to the truck? Could just be bad fuel causing the need for filter changes. It also could be collapsing fuel lines but usually changing a filter wont help that.
My name is Nic
2011 GMC Sierra 2500 CCSB LML,
Lil ole single s400, fuel,
supporting mods,
rancher tuned,
Various parts from SDP, WCFAB, LDS, DHD
Wiles Diesel Performance
Woodstock, Va
Contact me For Unleashed Duramax Tuning
[email protected]
post #5 of 12 (permalink) Old 04-23-2019, 07:55 PM
What fuel filter are you using?
It could also be injectors returning too much fuel, cp3 dropping rail because of too big of a tune or just weak.
Sierraluva likes this.
My name is Nic
supporting mods,
rancher tuned,
Woodstock, Va
[email protected]
post #6 of 12 (permalink) Old 04-23-2019, 07:58 PM
SST 1953's Avatar
Throwing the code on the hills? Do you have a monitor like an Edge CTS/CTS 2? A monitor will show you the actual versus the desired fuel rail pressure, it will also clear the code. My experience with the P0087 taught me a lot including when it was about to throw the code by watching the pressure, but more of wathching the exhaust. If you watch the exhaust it will start to roll heavy black smoke just prior to throwing the code, sometimes with a lean condition engine shake. Just prior to that if you manually downshift you might have enough RPM's to keep from throwing the code. First thing first, get a monitor! Good luck!
SST 1953 is offline
post #7 of 12 (permalink) Old 04-23-2019, 09:27 PM
LHN...We ARE the Joneses
There are about 10 different sources for a fuel limp....1 or all could be the culprit.
Not a SITE issue, thread moved.
Search is your friend....solve 1 'could be', move to the next.
Fill out your signature so we have a clue what you're driving.
Hook'em_Horns! is online now
post #8 of 12 (permalink) Old 04-24-2019, 04:00 AM Thread Starter
I'm using a Delco fuel filter
post #9 of 12 (permalink) Old 04-24-2019, 04:29 AM Thread Starter
Thanks for all the positive responses, but the question remains why can I drive ca.2'000 miles before the code p0087 comes back? My truck is a 07 2500 with 280'000 miles. Maybe this info could help
post #10 of 12 (permalink) Old 04-25-2019, 04:40 PM Thread Starter
An update on my problem with the fuel system p0087 code. I found out my auxiliary tank was empty any time when the error code appeared. The empty auxiliary tank acted like a bad tank cap and massed up the sensor. Filling up the auxiliary tank fixed the problem!
Thanks for all your help
eli_harper13 likes this.
Similar Threads
trouble code p0087 vacacut 06-07 LBZ & LLY Duramax Powertrain 16 05-26-2015 03:52 AM
Help! p0087 code Rickman 01-04.5 LB7 Duramax Powertrain 16 10-22-2013 08:11 PM
08 LMM getting code P0087 duramax-upnorth 911 Problems Forum 3 02-22-2010 05:43 PM
FPR shims installed; now throwing code P0087 N2BRK Performance Upgrades 33 09-17-2009 07:24 PM
P0087 Code??? Help Please LMM tking11 07.5-10 LMM Duramax Powertrain 1 08-01-2009 07:02 AM
