Prepping for a long ride - Page 7 - Chevy and GMC Duramax Diesel Forum
 22Likes
post #61 of 92 (permalink) Old 06-15-2019, 06:22 PM
chevor's Avatar
I been pulling new campers out of the factories in Indiana since 2010. I would say for over 500,000 miles now.
I wanna add I had a brand 5th wheel camper go boom, tire split down the sidewall 35 miles from factory.
And it has not been the only new camper that has had tires come apart.
The only reason ST tires have a higher weight rating is because they put 65 mph max speed on the side of that tire.
BIOTEC likes this.
2010 Gmc 2500 Duramax 853,500 Odometer miles - sold Nov 2018
2013 LT CCSB SRW bought with 508,000 miles, now over 645,000 miles
2013 LT CC & Chassis with 9' Hillsboro Aluminum flatbed - over 82,000 miles
chevor-2010-gmc-2500-maintenance-log
Favorite book : The Richest Man in Babylon
chevor is offline
post #62 of 92 (permalink) Old 06-15-2019, 06:39 PM
Crawal234 is offline
post #63 of 92 (permalink) Old 06-15-2019, 09:41 PM
Just my 2 cents worth--
I use LT Michelin's on all my trailers and trucks except the Pete. It has Michelins as well but offhand not sure of type.
On my 3 horse which has a GVWR of 16K, I have LT 235/85 R16 XPS RIB. Load range E. Its good for 3042 LBS @ 80 PSI cold.
I have never had any type of failure on any Michelin's on my vehicles. I keep the pressure correct and I don't haul faster than 70 and cruise at 60-65.
On the 8 horse the Michelins are a strange looking radial but looks like a bias. Big, heavy flat tread and carries 110 PSI. But it has a speed rating of 62 max. These have been known to blow when ran for long periods of 70+ MPH.
JimmyD and BIOTEC like this.
2019 Chevrolet 4500HD CC 4X4 Flatbed
2018 Chevrolet 1500 CC 4X4 High Country 6.2 liter
2019 Chevrolet 3500HD CC 4X4 Flatbed--SOLD
2011 Peterbilt 337 hauler with 360HP 8.3 Cummins--SOLD
1957 GMC 1 ton flatbed with 22K original miles.
3 different Kubotas
2003 Chevrolet 2500HD CC: 2011 Chevrolet 3500HD CC 4X4 and 2013 3500HD ex. cab 4X4-- all sold.
sambor is offline
post #64 of 92 (permalink) Old 06-16-2019, 08:55 AM
Originally Posted by henry42 View Post
Sorry, no hg, gave em all to the democraps
Sorry to hear, I wish you safe travels!
2019 2500 Silverado Z71 LTZ. God Bless America!
tobyhd02 is offline
post #65 of 92 (permalink) Old 06-16-2019, 02:45 PM
Location: we live in a high mountain valley in the hi country of northern arizona
CONFUSED ABOUT TRAILER TIRES, cont:
Cant thank you guys enough for TRYING to help; just because I disagree with some of you doesn't change the fact any contribution, whether we agree or not, is valuable because it makes us THINK.
Present status - after reading everything I can get my hands on, I am coming to the conclusion that for trailer use ( provided one dosnt need to cruise at much over 60-65) BIAS tires seem to be least likely to fail explosively.
The more people we can get to chime in with their opinions, the better !
6686L is offline
post #66 of 92 (permalink) Old 06-16-2019, 05:11 PM
They will still explode or blow out. It’s just that without the steel slinging around they do less damage when they do go. I like the Goodyear 614 g rated for my 4 horse. 10 years on first set.
MIkey52 is offline
post #67 of 92 (permalink) Old 06-16-2019, 06:02 PM
[QUOTE, I have LT 235/85 R16 XPS RIB. Load range E. Its good for 3042 LBS @ 80 PSI cold..... and I don't haul faster than 70 and cruise at 60-65. …….These have been known to blow when ran for long periods of 70+ MPH./QUOTE]
Thank you for your info. on your experience. Dosnt help me - my primary interest now is to learn about the experiences of those who have actually used bias tires in the 16 in range that are legit TRAILER tires. And you discussed RADIAL tires.
As I noted in my previous post, I am now gravitating towards the idea that a BIAS tire is less prone to catastrophic failure.
The 235/85R16 is a truck tire; not a trailer tire...- just that much bigger than what I have, that even if I didn't want to follow industry recommendations, wouldn't fit.
Again, I am reluctant to question the experts who actually make the different types of tires - going to stick to an ST.
I do agree with you as to towing speeds - both my trailers weigh at least 10,000 lbs - and while both are equipped with excellent brakes, I am not interested in finding out what a "panic stop" even at the speeds you and I agree are appropriate, much less faster speeds...!
Again, my primary interest at this point is hearing from those guys who have BIAS trailer tires in the 16" wheel size range towing heavy loads.
6686L is offline
post #68 of 92 (permalink) Old 06-16-2019, 10:37 PM
I generally agree with Hook'em's opinion of the ST tire. Yeah, it's "special".
- It doesn't have to have a UTQG rating (for wear, temp, and traction).
- It doesn't have to meet the more stringent requirements of vehicles carrying people.
- I don't know if they still say this (I haven't even seen an ST tire in over 10 years), but "Not for use on a drive wheel" (or something like that). What? These so-called "stronger side-walled tires" can't handle the stresses of a drive wheel? Wait a minute, isn't there just as much stress from braking?
Good luck with your ST tires!!
2004.5 Silverado 3500 SRW 4x4, D/A (LLY), Ext. Cab, Long Bed
engineer837 aux rad, TxC CAI, LBZ MP, Scangauge II, Nicktane aux filter head, KD lift pump, 2008 PS pump, 2011 hydroboost, Frederico Swaybars, Rancho 9000XL, Torklift StableLoads, BFG AT/KO2, Lance 835 Camper often in the bed.
jake111 is offline
post #69 of 92 (permalink) Old 06-17-2019, 03:54 AM Thread Starter
henry42's Avatar
So tell me mr smarty pants, what's the UTQG rating on the tires that come on our $70k trucks?
“Insanity is doing the same thing over and over again, but expecting different results.” - Albert Einstein
2017 2500HD GMC Denali CCSB
henry42 is offline
post #70 of 92 (permalink) Old 06-17-2019, 08:28 AM
I generally agree with Hook'em's opinion of the ST tire. Yeah, it's "special"......!!
Wow - you guys are convincing me, more and more, that we've got still another major fraud against us consumers.
I have been following the CP4 fuel pump issue ( the charming little device that was not engineered for American diesel fuel ( let's all give thanks to the "bunny huggers" for that fiasco) that, when it fails, will pretty much wipe out our entire fuel system to a cost of around eight or nine grand....!).
As I noted above - thanks to each and every one of you for your posts; really makes one think - and, again as I noted above, makes me think more and more next time I buy tires for heavy load trailering, they will be "BIAS". Hope to see more posts from guys who have done that.
6686L is offline
