Prepping for a long ride - Chevy and GMC Duramax Diesel Forum
 22Likes
post #1 of 92 (permalink) Old 06-07-2019, 05:03 PM Thread Starter
henry42's Avatar
At the end of this month I'll be driving from NY to Houston and then back a couple of weeks later.
I'll be pulling a 28 ft car hauler with my kid's car as well as the contents of his apartment.
Looking for ideas on what kind of prepping to do.
I'll be getting the oil changed and tires rotated a week before I leave. I ordered a 5lb ABC fire extinguisher to take along. I'll have a 2.5 gallon spare jug of DEF. I'm taking a small pancake air compressor as well as a 2kw generator and a complete set of tools.
Truck has close to 9k miles and tires are in great shape. Trailer will have new Goodyear tires plus two spares.
So, I'm ready for suggestions on what I haven't even thought of.
Oh, I installed a wired 1080p always on camera onto the back of the trailer which will drive a 7" screen which will be securely attached to my rearview mirror.
Today I hitched up the trailer and installed the new weight distribution hitch I just got and tested the lights, brakes and rearview camera.
Trailer's going to be maxed out at 10k with about a 1000-1200 hitch weight leaving me 1000 lbs for myself, my son who will assist in the driving as well as the tools etc. in the truck.
I bought a hitch scale to be sure of the tongue weight and I'm weighing and tallying verything going into the trailer. My plan is to load the car into the trailer first and then sit the coupler on the scale so that I can keep an eye on and adjust as necessary the position of the weight in the trailer to maintain my desired tongue weight.
As soon as I enter NJ I'm planning on getting on a CAT scale to verify everything.
I'm also going to be keeping good notes on fuel consumption and figure out my optimum speed.
With an 11 ft high x 8-1/2 ft wide flat nosed trailer I know that I'll be crying all the way there and back. ing for 12mpg but we'll soon find out.
Total trip will be around 3500 miles.
“Insanity is doing the same thing over and over again, but expecting different results.” - Albert Einstein
2017 2500HD GMC Denali CCSB
henry42 is online now
post #2 of 92 (permalink) Old 06-08-2019, 03:54 AM
JimmyD's Avatar
Although you may already have planned for this, I would not leave on a trip like this without the following:
Jack for the trailer (blowouts do happen)
Impact wrench
Spare fuel filter
Fill out your sig so that we know what truck you have and will most likely garner more suggestions.
P.S. Seriously doubt that you will see 12 MPG. For those of us that tow heavy, 62-65 MPH seems to be the sweet spot for fuel economy with 6th gear locked out.
09 GMC SLT Dually
Steel Gray Metallic
All options except sunroof
Mods so far:
DF DRW Club Member #161
JimmyD is offline
post #3 of 92 (permalink) Old 06-08-2019, 04:04 AM
407driver's Avatar
WhenIm towing our 12000 lb 5er I get 10 MPG at 65. At 62 I get 11.
A 5% decrease in speed = a 10% increase in fuel mileage.
It is also a more relaxed drive just sitting in the right lane and letting every one else go as fast as they please.
^^^ is correct, stay out of 6th gear, keep rpms between 1800 and 2400, adjust speed to keep engine coolant and xmsn oil temps down and enjoy your upcoming adventure.
FASS 95 Lift Pump (with Baldwin filters), Edge Insight CTS Monitor on a Windshield Mount, Nicktane Fuel Filter Adapter w/ CAT 306-9199 UHE tertiary fuel filter, Bilstein 5100 Stock Height, MBRP Downpipe back 4" exhaust with muffler and FTE 30" resonator/muffler, Sinister EGR Delete, Tuned but wont say who did it, Bushwacker Bed Rail Caps, AMP Research Bedstep, Fumoto oil drain valve, Dorman PS Oil cooler, Pioneer AVIC 7200NEX GPS/Stereo, Air Lift LoadLifter 5000 Air Bags.
407driver is offline
post #4 of 92 (permalink) Old 06-08-2019, 05:20 AM
Carolina_coast99's Avatar
May want to top off the DEF fluid in the tank as well, even if DIC says level is "ok". I have started to add def fluid to the tank when I'm also performing an oil change in a effort to avoid any warnings while going down the road.
Current Truck:
2019 Sierra 3500HD DURAMAX L5P; W/T, 4wd, CC, SRW, Standard Box. <snow plow prep pkg, 5th wheel/goose neck prep pkg>
1997 Toyota Tacoma 4wd xTra Cab, V6, 213,xxx miles
Aftermarket Items:
-Dark as legal tint;window visors; Ranch Hand front bumper; Weathertech hood protector;
Gone but not Forgotten:
2016 Sierra 3500HD 6.0; W/T, 4wd, CC, SRW, Standard Box. <snow plow prep pkg>
Carolina_coast99 is offline
post #5 of 92 (permalink) Old 06-08-2019, 05:25 AM
^^^ is correct, stay out of 6th gear, keep rpms between 1800 and 2400, adjust speed to keep engine coolant and xmsn oil temps down and enjoy your upcoming adventure.[/QUOTE]
When you say "stay out of 6th gear" , I assume you mean keep tow mode selected?
On that note- is tow mode recommended whenever something is attached to the hitch? Or is there a weight minimum before it is needed?
Current Truck:
Aftermarket Items:
post #6 of 92 (permalink) Old 06-08-2019, 05:53 AM
JimmyD's Avatar
Recommend that T/H be engaged if a trailer is attached.
09 GMC SLT Dually
Steel Gray Metallic
Mods so far:
JimmyD is offline
post #7 of 92 (permalink) Old 06-08-2019, 06:30 AM Thread Starter
henry42's Avatar
Impact wrench
Spare fuel filter
I'm driving a 2017 2500 and I am planning on taking a 3 ton floor Jack. I already have a spare fuel filter and 36mm socket in the truck as well as a 24" breaker bar, 4 way spinner and torque wrench for the wheels.
I just purchased new aluminum wheels and Goodyear Endurance tires for the trailer as I didn't trust the China bombs that the trailer came with. I got the E rated tires for additional protection and will take two of the old wheels as spares.
I asked my former EMT son to recommend a first aid kit and he said tylenol and bandaid.
I've towed before, and always use T/H as well as 5th gear.
Truck also has the Cts2 for monitoring engine.
post #8 of 92 (permalink) Old 06-08-2019, 06:34 AM
407driver's Avatar
Yes, Tow Haul selected, pull shift lever down into M mode and set it to M5. It will shift normally up and down and will not go above 5th gear.
If it weighs more than my 14' flat boat (which is about 750 boat, motor ad trailer) I put it in TH.
TH does two wonderful things for the truck.
First, it changes the shift points to take advantage of the TQ the Duramax has.
Second it locks the TQ Converter above 2nd gear. This eliminates slippage, lowering Xmsn fluid temps.
post #9 of 92 (permalink) Old 06-08-2019, 06:38 AM Thread Starter
henry42's Avatar
Would be nice if these settings could be locked in for when on a long road trip.
post #10 of 92 (permalink) Old 06-08-2019, 06:53 AM
Ok, just so I am clear.
From Park- while stopped (and tow/haul engaged), shift into M ( I do not have M, mine has P R N D L 1); so I should shift into "L" I guess? Then press the "+" button up to 5; then accelerate off , and the transmission won't shift past 5th gear. Sorry for the confusion.
Current Truck:
Aftermarket Items:
