Engine power is reduced - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 12 (permalink) Old 07-10-2019, 05:14 PM Thread Starter
If I'm idling the truck for about 2+ min the message "engine power is reduced" is displayed and the engine has no more power. After continuing driving for a mile or so the message changes to "clean exhaust filter" the engine power is back normal. My truck is a 07 with 285k miles. Any suggestions what's causing this behavior?
remiontheroad is offline
post #2 of 12 (permalink) Old 07-10-2019, 05:27 PM
J83
J83's Avatar
Im assuming since you have a DPF warning its a new body 07. i would guess a bad sensor or a plugged up DPF. do you have any codes or anything with it or a scanner that can monitor regen cycles? Is the money light on?
J83 is offline
post #3 of 12 (permalink) Old 07-10-2019, 10:01 PM
GoBlowSnow's Avatar
They put DPFs on 07s? I thought they didn't get them until 2008... On the LMMs
2008 Silverado 2500 Crew Cab Z71
GoBlowSnow is offline
post #4 of 12 (permalink) Old 07-10-2019, 10:41 PM
SilverGorillaLML's Avatar
07.5 is when they switched to lmm. Try driving it until the message goes away and you complete the regen cycle. Have to maintain 55mph iirc.
Race/Pulling truck:2012 Cummins/Built 6.8L/Big air/Big fuel/48RE Swap/PCS 2000/B&M Gated shifter
Playing eye spy for another duramax
SilverGorillaLML is offline
post #5 of 12 (permalink) Old 07-11-2019, 06:19 AM Thread Starter
Don't have DPF system. It's cleaning the exhaust filter with injection diesel.
Why the message "engine power is reduced "?
post #6 of 12 (permalink) Old 07-11-2019, 06:56 AM
LHN...We ARE the Joneses
'exhaust filter" = DPF
It needs to complete the burn off cycle.....don't let it?, "reduced power" is what you get.
Hook'em_Horns! is offline
post #7 of 12 (permalink) Old 07-11-2019, 07:00 AM
DPF= diesel particulate FILTER.
Icutmetl is offline
post #8 of 12 (permalink) Old 07-11-2019, 01:09 PM
GoBlowSnow's Avatar
So if you have a DPF and it is the original to the truck, with your millage, chances are the DPF is plugged in a way that can't be cleaned via the automated normal method. It will likely need to be removed and taken to a place that can acid bathe the thing and get it cleaned that way then it should theoretically operate as new and regen every 400-500 miles or so. Also- any sensors in that area of the DPF may also be worn and tired as well.
post #9 of 12 (permalink) Old 07-11-2019, 01:20 PM
J83
J83's Avatar
or find a really big pot hole to drive through.... things fall off, stuff happens...
407driver likes this.
J83 is offline
post #10 of 12 (permalink) Old 07-11-2019, 03:45 PM
If it doesnít have the DPF, it will not have diesel injection into the exhaust. If it does have the diesel injection, it has to have the DPF. Only reason it wouldnít have, is if someone has removed it. First thing is to pull the code as to what is causing the reduced power. Then you can diagnose from there. There are several things and failures that will cause the reduced power. We also need to know what, if anything, has been done to your truck. Is it deleted or stock, etc?
Sent from my iPad using Tapatalk Pro
2007.5 Chevrolet 2500HD CC SRW 6.6 LMM 190,000 miles. Bought new
New up-pipe, 3Ē downpipe, cold air intake, cold and hot side tubes, Transgo Junior kit, Allison deep pan and filter kit, Moog tie rod upgrade
2015.5 Chevrolet 3500HD CC DRW 6.6 LML 108,000 miles Bought with 98,000 miles
Stock
Toolbox58 is offline
