How To: Radiator Stack Removal and Install - Page 22 - Chevy and GMC Duramax Diesel Forum
 14Likes
post #211 of 235 (permalink) Old 03-27-2019, 03:52 PM
CA88 - I always encourage Duramax owners to periodically clean all their coolers, not just spray them with a garden hose, though that helps a little if the stack isn't too dirty. When you say Colorado, I'm assuming high altitude Colorado. You need to remember that at high altitudes the air is 'thinner' meaning less dense, and air that is less dense does not have the same the same capacity to remove heat from your cooling stack compared to more dense air, like at sea level. Also, humidity comes into play and Colorado high altitude generally has lower humidity than sea level. So I'm not surprised to see the temp levels you experienced. And I wouldn't be concerned as long as your fan clutch kicks on fully at some point and the engine cools down. If my engine went to 245, that's just too hot and I would strongly suspect the fan clutch to be defective. I think the highest my truck has ever been is 236 (high altitude, steep grade, pulling 5th wheel) and then lockup occurred and cooled down.
Another thing to remember is that your fan clutch lock up temp is not directly tied to your coolant temp. If your cooling stack is clean, the air flows equally through all parts of the stack and hits the fan clutch equally as well. If your cooling stack isn't clean, it will most likely block the airflow to the fan clutch and the fan clutch won't see the temps that the rest of the air coming thru the stack has, and consequently your fan clutch doesn't lock up when you think it should. Enough preaching.
Ron Nielson
Ron Nielson is offline
post #212 of 235 (permalink) Old 03-27-2019, 08:35 PM
CA88's Avatar
Thanks Ron. Sounds like a good time to replace the fan clutch. I guess I shoulda said southern Colorado. Pagosa springs. Still higher elevation but prolly not too crazy. Like I said earlier. The engine temp hovered around 220-230 almost the whole 12 hr trip and would engage randomly. Of course when temps were high. But not everytime they got up there and some of those times it would not stay engaged long enough for temps to go down enough. Which is what led me to think the clutch is goin out. And bout the water pump. I was just askin bout that since I’m almost to 200k miles and I’ll have the cooling stack outta the way. Didn’t know if it’s a ‘run it till it goes out’ type of thing.
*2007 Chevy Greystone Metallic 2500HD 4x4 CCSB LBZ
EFI Live by Idaho Rob DSP5, Transgo jr
Leveled, debagded, demolded
Thunderstruck front replacement bumper
285/75/16 Mickey Thompson ATZ P3
Atwood gneck hitch
Tekonsha Prodigy 3 Brake controller
Stock exhaust cat and muffler deleted with 5" tip
And more to come…
*85 Chevy 2500 custom deluxe sclb 4" lift
Needs a little work here and there…
CA88 is offline
post #213 of 235 (permalink) Old 03-27-2019, 08:35 PM
Originally Posted by ron nielson View Post
i think the highest my truck has ever been is 136 (high altitude, steep grade, pulling 5th wheel) and then lockup occurred and cooled down.
136?
07 Bowtie LMM CCSB Z: Nice truck, mad wife, empty wallet.
With all this "gun control" talk I haven't heard one politician say how they plan to take guns from criminals, just law abiding citizens.
knotReally is offline
post #214 of 235 (permalink) Old 04-07-2019, 06:25 AM
Finally got to mine. Should have done it last winter when I did the injectors. I think a lot of it is from a drive across ND in the fall & the cat tail fuzz was blowing around IC doesn't look bad but the radiator had some build up.
04 GMC LB7 2500 SAC 45 injectors DSP5 EFI live, ported air inlet. 4" MBRP droning exhaust.
77cruiser is online now
post #215 of 235 (permalink) Old 04-07-2019, 09:52 AM
I did my stack at 129K when I did the EGR delete and turbo swap. It needed cleaning too.
The coolant should be changed every 100K anyway.
If the water pump makes it I'm at 199K now... My plan for 229K is drop the coolant, break down the stack for cleaning, replace the water pump, idlers, belt, fan clutch then put it back together with fresh coolant.
1TRIKHD likes this.
2007.5 GMC 2500HD, Gear Alloy 712C Injector wheels on 285x65x18 BF Goodrich T/A KO2, Cognito leveling kit, Cognito suspension and steering upgrades, Bilstein shocks, Amsoil bypass filtration, FASS 95GPH, Transgo JR, PCV Re-route, AFE cold air intake, Diamond Eye 3" down pipe, AFE DPF and CAT delete pipes, EGR delete by ProFab, Danville 3794 Stage 2, Katzkin leather, Mean Green alternator
doug25427 is offline
post #216 of 235 (permalink) Old 04-09-2019, 05:52 PM Thread Starter
nmeyer414's Avatar
IMO it would be a good time to do the water pump along with the fan clutch.
If you do change the pump, you have 1 of 2 routes to go if my memory serves me correctly......stockish/oem or aftermarket pinned.
Several diesel performance shops sell complete replacement sets
NATE
2018 GMC SIERRA 2500HD DENALI
2006 LBZ (Regency Edition) sold
http://real-man-truckworks-and-survi...p?action=forum
nmeyer414 is offline
post #217 of 235 (permalink) Old 04-10-2019, 08:03 AM
CA88's Avatar
Thanks Nate.
Atwood gneck hitch
And more to come…
CA88 is offline
post #218 of 235 (permalink) Old 04-17-2019, 11:13 AM
CA88's Avatar
Is there any special tools I would need to replace my fan clutch and water pump?
Atwood gneck hitch
And more to come…
CA88 is offline
post #219 of 235 (permalink) Old 04-17-2019, 03:07 PM
LHN...We ARE the Joneses
Spanner wrench for breaking loose the fan.
Water pump, nothing special...except that one of the bolts is behind the lower pulley....Sold as a pair (amazoid?) is the socket to fit and the flywheel lock tool. Not expensive.
Then you need something for that socket....I borrowed a 4' long 3/4 drive 600 ftlb torque wrench to break it loose. It's a beast, you need some leverage.
However, since you ask in this thread.....having removed the Rad and CAC, you'd have enough room where you could then use an impact wrench on it, vs the socket & breaker bar plus the neighbors two mules to pull on it.
CA88 likes this.
Hook'em_Horns! is offline
post #220 of 235 (permalink) Old 04-17-2019, 03:16 PM
CA88's Avatar
Lol. Ok thanks hook.
Atwood gneck hitch
And more to come…
CA88 is offline
