Interior Map Light Upgrade - Chevy and GMC Duramax Diesel Forum
post #1 of 37 (permalink) Old 12-14-2013, 04:32 PM Thread Starter
LBzing's Avatar
This is a pretty simple DIY i did in a parking lot in 5 minutes on my lunch break.
I was at canadian tire this week just browsing and came across a set of PHILLIPS 6000k brand LED bulbs.
Normally i would stick with regular incandescent bulbs where they were originally installed, as i have been disappointed by LED "upgrades" in the past (eg. blinding to look at but actual light output is terrible).
But for $20 a pair, i decided to try them out because honestly, anything would be an upgrade from the stock map lights.
I used a small slot screwdriver to pop off the lenses and some needle nose pliers to get the bulbs out as they sit almost flush with the metal reflectors.
A little FIY, the LEDs only work one way so if they don't work at first, they are likely installed backwards.
The result was very surprising, not only were the lights bright, but the light output is literally 10 times better than stock.
So, if you are looking for an upgrade to the stock map/interior lights, I would highly recommend them.
Things i liked about them:
High quality construction.
Great, white light output, none of that ricey blue crap.
They DIM PROPERLY like the factory bulbs
(I will get more pictures of the lights at night.)
LBzing is offline
post #2 of 37 (permalink) Old 12-14-2013, 04:51 PM
Blue06Sierra's Avatar
What is the part number? I can't see it on Can Tire's web site. That looks pretty good, the stock ones aren't particularly bright.
Scott
Scott
2006 Sierra 2500HD CCSB 4x4 LBZ
2013 Prius V
2010 Salem LE 25T Travel Trailer
2007 Trailblazer Cargo Trailer
Other Stuff too
Blue06Sierra is offline
post #3 of 37 (permalink) Old 12-14-2013, 04:52 PM
TNASH481's Avatar
I changed all of my interior dome/map lights to LED's it's awesome!
2007.5 Greystone Metallic LMM CCSB SLT 4x4
|6000k 35W HID's from DDM Tuning|Headlight All-On Mod|Debadged|295/55/20 Trail Grapplers & XD Addicts -12 Offset|EFI by Kory|5" Diamond Eye Exhaust|WeatherTech Floor Mats|Recon Cab Lights (Junk)|ISS Pro Gauges|
2004 White LB7 CCSB-Sold 4/5/13
Instagram: tnash481
TNASH481 is offline
post #4 of 37 (permalink) Old 12-16-2013, 11:23 PM
My local CT had them in stock... 2 - T10 120 degree 6000K LED bulbs for $19.99. I'll give them a try.
Scott
2013 Prius V
Other Stuff too
post #5 of 37 (permalink) Old 12-18-2013, 09:21 AM Thread Starter
LBzing's Avatar
sorry for late reply, the Canadian Tire product # is #20-2933-0
Philips T10 Premium Mini Bulb, 2-pk | Canadian Tire
For some reason they list them under "premium halogen" lmao
LBzing is offline
post #6 of 37 (permalink) Old 12-18-2013, 09:43 AM
DLB
DLB's Avatar
Did the same thing on my 05. Made a big difference in looks and function. LED swap was the first thing I did to my LML. Should come from the factory like that. I've noticed several newer vehicles do now.
2013 Silverado 1500
275/60R20 AXTs, 2" level, UnderCover Flex, BedRug, WeatherTechs
2015 GMC Yukon XL SLT - SOLD
Husky Liners throughout, HID lows, LED fogs
2011 Duramax LML - SOLD
LTZ, Z71 pkg, VYU pkg, CCSB
AMSOIL in the diffs • Edge Insight CTS • FASS 150 • FLO~PRO 5" exhaust • H&S Performance • LINE-X bedliner • Mobil 1 5w-40 syn • PPE Diff Cover • Rough Country steering stabilizer • TranSynd • Trifold Tonneau Cover
DLB is offline
post #7 of 37 (permalink) Old 12-18-2013, 10:15 AM
Blackcloud556's Avatar
Nice.. did all my interior lights to LEDs when i did my dash lights.. great upgrade over the stock crap.
Blackcloud556 is offline
post #8 of 37 (permalink) Old 12-19-2013, 06:31 PM
I put these LEDs in today. What a difference, even more than in LBzing's pictures. Wish I'd done it sooner.
Scott
2013 Prius V
Other Stuff too
post #9 of 37 (permalink) Old 12-21-2013, 06:26 PM
830king's Avatar
Looks good!!! Anybody know of sum LED's for the interior light in the center of the cab?
Sent from my SPH-D710
My name is Dan, I drive a 2005 2500hd ccsb lly 4x4, victory red, Efi live Robs trans safe tunes, Edge cts w/pyro, Silverline 5" exhaust, Magnaflow downpipe, LML ds manifold, Arp head studs, S&b turbo inlet, S&b cai dry filter, Ppe shim kit, drilled fuel rails, B&w turnover gooseneck, Ma welded waterpump, Profab egr delete, Fass titanium 150, Beans fuel sump, Ma pump rub plate, 285/75-16 duratrac on stock rims, Kryptonite tie rod & centerlink, Kryptonite sway bar end links, kryptonite lower ball joints Rare parts extreme duty pitman and idler arms, Dhd steering brace, Alligator 5/8" trans lines.
830king is online now
post #10 of 37 (permalink) Old 12-21-2013, 06:43 PM
TNASH481's Avatar
Your dome light? They're 212-2 on an LMM
Instagram: tnash481
TNASH481 is offline
