LBZ: HOW TO: Activate factory turbo brake - Page 92 - Chevy and GMC Duramax Diesel Forum
 120Likes
post #911 of 917 (permalink) Old 09-30-2019, 07:37 PM
407driver's Avatar
Originally Posted by lockcop View Post
I got to thinking that this mod will help keep the vanes moving freely with less chance of sticking. Going from zero to 100% often should keep them freed up. Make sense to anybody but me?
When I first did the mod on my previous LMM I was having conversations regarding the effects and Hook em Horns pointed out that very thing. Keeping the vanes moving will certainly help to prevent sticking.
I equated it to a couple of systems on the Aircraft I fly that if not exercised regularly those systems have valves or solenoids that can and will begin sticking.
The phrase "Use it or Lose it" comes to mind. It may not help but it certainly cannot hurt.
That was a lot of words to say, Your Thinking is Right On.
lockcop likes this.
407driver is online now
post #912 of 917 (permalink) Old 09-30-2019, 07:47 PM
D_R_C's Avatar
Exactly, keeping the vanes moving.
That where having rumble tunes helps the vanes opening and closing while idling when your not using the TB. I feel anyway.
Dan
EFILive TCM Duramax Tuner
DHD PCV Re-Route
AirDog 4G100
D_R_C is offline
post #913 of 917 (permalink) Old 10-01-2019, 01:40 PM
lockcop's Avatar
Cool
So if I give you my wifes phone number could you call and tell her I had a good idea?
Kenneth a.k.a. lockcop 2007.5 LMM 2500HD ECSB 4 Wheel Drive
EFI AutoCal by Idaho Rob; DSP5 Switch In Power Port; Edge CTS2 with Pyro; Deviant Trans Lines from Alligator Performance; PPE Deep Trans + Oil Pan (TRANSYND), AFE Differential Cover + Trans Cooler from XDP; FASS T95 Lift Pump from Synthetic Motorsports; XD Tie Rods + Fumoto Valve from the DMAX STORE; ; POWERSTOP Z36 Drilled + Slotted;TIMBREN Suspension Enhancement System; Quad LED Fog Lights; OWENS diamond plate running boards; AERO 52 GAL Tank; Turbo Brake w/switch and light; Amsoil 20-50 Dominator Oil; Schaeffer Moly Grease, + Gear Lube; Temp Sensors In Oil Pan + Rear Diff; Dorman PS Cooler; Flowtie Emblem
Arizona Diesel Club #11
lockcop is offline
post #914 of 917 (permalink) Old 10-01-2019, 01:52 PM
LHN...We ARE the Joneses
She should get you a T-shirt printed in big letters;
TURBO SAVER EXTRAORDINAIRE
Hook'em_Horns! is online now
post #915 of 917 (permalink) Old 10-01-2019, 07:14 PM
lockcop's Avatar
Thumbs up
Shoot Hook'em, I was happy that I was mentioned in the same sentence as the 'Grand Puba of All Things Duramax' --- YOU!
Besides, I can't spell them big long words you use all the time! lol
lockcop is offline
post #916 of 917 (permalink) Old 10-02-2019, 02:34 AM
407driver's Avatar
There you go with the bad ideas again. If I call her I may end up thinking I was wrong. Happens to me at home a LOT!
lockcop likes this.
post #917 of 917 (permalink) Old 10-02-2019, 08:05 AM
lockcop's Avatar
Thumbs up
Well thanks anyway! You can feel comfort in knowing that you're not alone!
407driver likes this.
lockcop is offline
