How To: Remove/Replace Power Steering Pump - Page 3 - Chevy and GMC Duramax Diesel Forum
 6Likes
post #21 of 23 (permalink) Old 06-28-2019, 03:09 AM Thread Starter
LHN...We ARE the Joneses
Maybe use a different browser?
Hook'em_Horns! is online now
post #22 of 23 (permalink) Old 06-29-2019, 01:31 PM
407driver's Avatar
I just looked at this again in both Google and Firefox. The pics come up in both perfectly.
I did this a week or so ago and the original write up was right on for my LMM.
I did find that I could not pull the pulley until I removed the pump and I had to press it back on prior to installing the pump due to the inner radiator shield interfering. I also cut one arm brace for that inner shield, with a vibrator cutter, to give me more room to work reinstalling the bolts. Since the entire shield is cast hard plastic i do not believe I seriously weakened it to any significant degree.
I took the advice to put the center front bolt in first but I had trouble rocking the pump to get the other two bolts started though. I found that by installing the top side bolt second lined up all the rest perfectly.
ANOTHER Great How To thread by Hook. MANY THANKS!!
407driver is online now
post #23 of 23 (permalink) Old 06-29-2019, 06:58 PM
askyup88's Avatar
I'll have to try on a home computer. Thanks.
2006 Chevy 2500HD 4x4 - MBRP Downpipe, 5" Magnaflow Straight Piped, SDP EGR delete, FASS 150, PPE Airbox Mod, PCV reroute, EFI Live by Idaho Rob, Reverse leveled, 20x10 (-12) Fuel Mavericks with 305/50 Nitto 420's
MY LBZ Build
askyup88 is offline
