GM Recall #: N182206311 - Page 3 - Chevy and GMC Duramax Diesel Forum
L5P TSB (service bulletins, recalls, updates) Postings of Tech Service info for any New L5P engine issues.
 8Likes
post #21 of 50 (permalink) Old 07-26-2019, 07:44 PM
henry42's Avatar
My dealer did the recall without my permission. So I trashed them on the survey and now they're pissed. Told them maybe next time you listen to the customer as I brought it in for an oil change and said don't do anything else.
Service manager claimed "they had to because it was a fire risk" I told him only a fire risk if plugged in and he said oh no, live wires in there.
Told him he was an idiot and that's why he got a bad review.
Now on tell GM how f'd up it is to pass on surveys with customer's name attached.
What's the value of a survey if they do that?
“Insanity is doing the same thing over and over again, but expecting different results.” - Albert Einstein
2017 2500HD GMC Denali CCSB
henry42 is offline
post #22 of 50 (permalink) Old 07-27-2019, 09:22 AM
charlie brown's Avatar
In the mean time why not just stick a Kats oil pan heater on.
https://katsblockheater.com/block-he...pad-heater-250
2004 LB7 - Sold
2008 LMM - Idaho Rob - Full Delete - 350k miles and counting
2017 L5P - To be continued..
charlie brown is offline
post #23 of 50 (permalink) Old 08-01-2019, 03:22 PM
Odd that some here reported that dealers cut the cord on their heaters. I didn't take mine in because I live so far away from dealer, but I called today to see if there was any word on parts to fix it. Service tech told me that recall had changed and no longer included 2500 and 3500, just need to bring it in so they can clear it from the recall.
269 Bob
2019 Chevy 2500HD Midnight Edition
SW Mich.
269_Bob is offline
post #24 of 50 (permalink) Old 08-01-2019, 05:47 PM
henry42's Avatar
Yeah, and I've got some nice land to sell you in Florida (pay no attention to the yellow caution tape surrounding the neighborhood along with the signs saying sinkholes beware). Just come on by and let me lighten your wallet for you.
Why on earth would you have to bring it in if there's no recall?
Come on dude. If you were smart enough to buy a diesel you should know he was pulling your leg.
henry42 is offline
post #25 of 50 (permalink) Old 08-02-2019, 06:54 AM
I guess everyone isn't as smart as you are. He wasn't pulling anything, vehicle has to be in order to be cleared from recall, no one said there was no recall, he said it now only applies to 4500 and 5500 trucks. Gosh, I wish I was as smart as you(not). And I think you know where you can shove you Florida land!
269 Bob
SW Mich.
269_Bob is offline
post #26 of 50 (permalink) Old 08-02-2019, 07:33 AM
redwngr's Avatar
Maybe the dealer guy got confused about how they are treating the 45/55/65's?
https://static.nhtsa.gov/odi/rcl/201...9V328-3409.pdf
From top of notification:
Attention: It is a violation of Federal law for a dealer to deliver a new motor vehicle or any new or used item of motor
vehicle equipment (including a tire) covered by this notification under a sale or lease until the defect or
noncompliance is remedied.
This recall applies to used inventory. For customer vehicles, you do not need to disable the engine-block
heater. If the customer requests the disable procedure be completed, you may proceed but advising the
customer to NOT use the heater block cord is sufficient. GM is developing a final repair that will restore
the functionality of the engine-block heater.
Dealers will be advised when the disable procedure and remedy for 2019 Chevrolet Silverado
4500/5500/6500 medium duty trucks is available. At this time, these new vehicles are on a stop delivery
order under N182206312.
All involved vehicles that are in used inventory must be held and not delivered to customers, dealer
traded, or used for demonstration purposes until the repair contained in this bulletin has been performed
on the vehicle.
Later in pdf it does say that this current 'procedure' does not apply to the 45/55/65's.
FWIW, the procedure says to cut the cord off at the heater, rather than extending it and cutting the plug of the end of cord at the wheelwell.
(I'm gonna guess that's so it's not possible to attach a new plug to the end of the cord)
redwngr is offline
post #27 of 50 (permalink) Old 08-03-2019, 07:27 PM
Rick_Schaber's Avatar
Hello to the group. I have the chance to purchase a new 2019 Denali at a dealership. They will have to bring it in from a different dealership.
The build sheet says it has a engine block heater. A few line down on the build sheet is says engine block disabled.
Does that mean the cord was not installed or removed?
And should GM fix the problem?
I understand GM has a problem with the cords possiblity shorting out.
The dealership is closed till Monday so I thought I would ask the group.
Maybe someone else had the issue.
Thanks.
Sent from my SM-G950U using Tapatalk
Rick_Schaber is offline
post #28 of 50 (permalink) Old 08-03-2019, 09:25 PM
redwngr's Avatar
A dealer can't deliver to a retail customer a vehicle vehicle with an outstanding recall item.
Disabling the heater meets that requirement.
All Dmaxes are equipped with block heaters.
When the fix is released, that truck will have the fix applied, just like the rest of them that are already in customer hands.
The 'disabled' line and associated RPO code is indicating it was disabled at the factory, so a dealer that wants to deliver it to a retail customer does not have to perform the temporary repair.
Rick_Schaber likes this.
redwngr is offline
post #29 of 50 (permalink) Old 08-07-2019, 02:06 PM
Just called as I had an appointment on Friday to get my coolant tank fixed, and they have told me there is a fix for block heater cord and will be doing that also on Friday.
redwngr and paauto like this.
BeardedBBQ is offline
post #30 of 50 (permalink) Old 08-08-2019, 09:48 AM
Look forward to hearing how it goes - "Winter's Coming!"
BeardedBBQ likes this.
2017 GMC Denali HD Duramax - Deep Garnet Metallic Exterior, Cocoa/Dark Sand Interior
Mods: 18" Fuel Pump Matte Black Wheels w/ BFG T/A KO2 265/70s, 2" McGaughy's Drop Shackles, Bilstein 5100 Shocks, Amsoil Dual Bypass Oil Filters, MBRP Stainless Exhaust, Revolver X2 Tonneau, Morimoto XB LED Fogs, T-Rex Matte Black Stealth Grille with Light Bar / T-Rex Bumper Insert, AMI Styling GMC Grille Badge, Factory Badges Yanked Off, Wolo Air Horns to Replace Factory Horns, Kleinn Train Horns w/ On-Board Compressor, Cor-Box Storage Box, Edge CTS2, Rostra Heated Rear Seats, Aluminum Liquid Pedals, Mag HyTec Rear Diff Cover, Clear Bra 18", Front Doors Tinted 20%/All Other Windows & Sunroof Tinted 40%, IntelliHaul mirror cameras and front cam.
paauto is offline
Similar Threads
GM recall, the DPF, and Quadzilla jack_usa 07.5-10 LMM Duramax Powertrain 83 02-21-2012 05:30 PM
GM RECALL (soon) SSHauler 11-16 LML Duramax Powertrain 49 03-25-2011 10:17 PM
2011 GM Axle Recall garys08slt 11-16 LML Duramax Powertrain 6 01-21-2011 08:33 AM
GM Announces Brake Override System for All Vehicles as Massive Brake Recall Looms Administrator General Discussion 11 04-08-2010 05:23 PM
Did GM ever have a recall on the 2003 trucks for dash gauges going out? zman77 01-04.5 LB7 Duramax Powertrain 2 12-12-2008 05:50 AM
