15% OFF: Morimoto XBLED Fog Light Welcome Offer: - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 04-14-2016, 03:03 PM Thread Starter
Our first new to the site welcome offer:
USE CODE: DMFXBFOGS (valid until 4/30/2016)
CHEVROLET SILVERADO (SQUARE): MORIMOTO XB LED FOGS | Longshot Lighting
We are offering 15% off Morimoto type C XBLED Fog lights. (Black Option Only)
We have these in stock choose normal Parcel Select at checkout and we will upgrade to Priority on our end.
DESCRIPTION
No Comparison: Stock sucks! But the new Morimoto XB LED projector fog lights: Look great. Are well-built. Perform like champs. Have a virtually infinite life span, an unbeatable warranty, and best of all you won't need to sell your soul to afford them!
Designed: Specifically for the 2007+ Silverado trucks and 2007+ Tahoes, these complete housings will mount behind the bumper with all of the stock mounting points. Their aim can also be adjusted just like stock with the integrated assembly that's cast into their shell. Check the compatibility section below for a list of known applications.
Powered: by three Philips Luxeon-T 5000K LED's that produce around 1200 raw lumens per side. The projector based optics inside concentrate a total of 2400 lumens of pure white light into a beam that's super wide and perfectly distributed for use as a fog light. They are SAE, DOT, and ECE approved.
Well-Built: Their durable polycarbonate lens should resist the test of time, keeping the housings looking new. The powder-coated cast aluminum housing is light-weight and much stronger than comparable plastic alternatives. Doubling as the heat-sink for the LED's, the housings completely protect the internals from moisture and road debris.
WHAT'S INCLUDED
2x Fog Lights:Type C Morimoto XB LED
Wiring:Plug-n-Play Connection Kit
Warranty:Ten Years
Plug n Play: Wiring is easy too! The XB LED Fogs are designed to work without any special wiring. They will plug into the factory 5202 power outlets for the stock fog lights and each fog light includes all necessary connectors, rubber seals, and pigtails for a plug n play install.
COMPATIBILITY
REPLACES GM PART #: 25883245 , 25883246
Chevy Avalanche 2007+ (all trim levels)
Chevy Silverado 2007-2016 (all trim levels)
Chevy Suburban 2007+ (all trim levels)
Chevy Tahoe 2007+ (all trim levels)
TECHNICAL
Input Socket:Sealed 5202 Male
Weather Rated:IP67 Waterproof
Lens Material:High Impact Polycarb (UV-Resistant)
Shell / Heat Sink:Powder Coated Cast Aluminum
LIGHTING SPECS:
Light Source:3x Philips Luxeon-T
LED Optics:Kuria Projector Fog Lens
Intensity:2400 Lumens
Kelvin Rating:5500K (pure white)
LSLighting is offline
post #2 of 6 (permalink) Old 04-16-2016, 10:53 AM Thread Starter
Bump
post #3 of 6 (permalink) Old 04-17-2016, 01:03 PM Thread Starter
Bump.
Send us a message, or comment if you have any questions pertaining to these or any other parts we offer.
post #4 of 6 (permalink) Old 07-04-2016, 11:07 AM
Hey LSL.... please message me with price and availability for these.
I have a 2011 Silverado.
Shipping is to 92656.
Thanks
AlisoBob is online now
post #5 of 6 (permalink) Old 07-04-2016, 11:11 AM
This image is supposedly of a installation in a Silverado. This is the beam pattern I can expect... correct?
post #6 of 6 (permalink) Old 07-05-2016, 11:06 AM Thread Starter
Correct, though that image has a drop off in the grass, that output of the XBLED fogs is a thin yet very wide beam pattern with near perfect beam pattern dispersion. This gives a great fog light pattern and slices under the fog when needed.
PM inbound
