Edge CTS2 monitor work on 2016 LML?? - Page 4 - Chevy and GMC Duramax Diesel Forum
 14Likes
post #31 of 42 (permalink) Old 01-15-2020, 08:25 AM
D_R_C's Avatar
Originally Posted by Muzbomb View Post
You really need to call Edge to verify what will work without having to invest in the expandable EAS starter kit.
Iím trying to remember if the expandable EGT probe will work with having only one EAS device plugged into the HDMI to OBD2 cable, without spending more $$ for a starter kit. remember without calling them.
There was a good reason I didnít go with the expandable probe what it was.
EDGE Products phone 1 (888) 360-3343
They wonít bite if you call them with questions.
Dan
EFILive TCM Duramax Tuner
D_R_C is offline
post #32 of 42 (permalink) Old 01-15-2020, 01:18 PM
rockn69's Avatar
That kit has the proper cables to work if your CTS2 monitor has the HDMI connection on the back, the cable with part # H00008000 is what plugs into the OBD port & CTS2. The cable with the EGT plugs into the HDMI/OBD cable.
DRC I don't know how old your unit is but mine looks nothing like that
Muzbomb likes this.
2015.5 Chevrolet Silverado LTZ, Z71, SRW.
Summit White
rockn69 is offline
post #33 of 42 (permalink) Old 01-15-2020, 01:52 PM
D_R_C's Avatar
Thatís because that one is a CTS bought in 2012 before the change to HDMI.
CTS2 with HDMI cable is on my truck.
Dan
D_R_C is offline
post #34 of 42 (permalink) Old 01-15-2020, 02:28 PM
D_R_C's Avatar
Update, Edge fazed out the probe that I showed earlier, the replacement is 98620 $127.95 what rockn69 mentioned.
Time for me to delete that photo.
But I do have a new spare one if ever needed.
Starter kit only 98602 $38, probe only 98611 $108 which would cost more buying both compared to $127.95 @ Edge for the complete 98620 kit. Edge prices.
If you ever need to replace only the probe, it would cost a little less with only having to change out one part instead of 2.
Much better pricing than it was 2 years ago.
Iíd suggest to look for best prices, that one company mention was a little costly, but it was also Canadian prices, I donít have to deal with CA prices. If itís a good deal.
Dan
D_R_C is offline
post #35 of 42 (permalink) Old 01-15-2020, 03:34 PM
rockn69's Avatar
Canadian prices suck, we get bent over and get it hard & dry.
Muzbomb likes this.
Summit White
rockn69 is offline
post #36 of 42 (permalink) Old 01-15-2020, 05:45 PM
J83
J83's Avatar
Originally Posted by denarli6.6 View Post
I've had my EGT probe for around 6 months and its been acting up for the past 3. When i crank the truck sometimes the probe will just read what the temp was before the crank i guess cause its usually around the temp outside when its been sitting. It'll stay like that for a couple miles usually then finally start reading correct. The other night was the first time i actually had to change the PID to something random then change it back to EGT sensor for it to read correctly. Thought about calling Edge, but after reading this thread seems like its common.
Honestly that sounds like a software issue not a hardware issue. Refreshing the monitored sensor should not change the behavior of the physical probe hardware, but it could reset some variables in the CTS code when you change pids. Id check it for an update and see if you can get a fresh install of the firmware on it. That may solve your issue.
denarli6.6 likes this.
J83 is offline
post #37 of 42 (permalink) Old 01-15-2020, 08:31 PM Thread Starter
Muzbomb's Avatar
For the CTS2 I will get a EGT probe for sure but should I also look at getting a boost probe? My truck is all deleted but I only run just mild tune 45hp Extra efi live I have all 5 tunes but I have never ran another tune just the 45hp one I donít plan on running higher tunes and I donít really tow anything So is the boost gauge on the CTS2 good enough or should I still look at doing a boost probe?
2016 Chevy 2500HD: ready lift leveling keys with 1" blocks in rear, Flo Pro 4Ē NM, EGR blocker plates, Autocal with Mitch Cooper tunes/trans tune, CCV delete, Edge CTS2 monitor with EGT probe, 40Ē RC curved light bar mod in bumper, LED 45w headlights and fog lights, white Recon LED cab lights, LED switch back side tow mirror lights, Trex grille inserts, rear husky plastic wheel well liners, custom paint match mirrors, tow hooks and bow ties, Rough Country HD2 side steps, winter tires ultra 20x9" rims with 33"Goodyear dura trac studded, summer tires Mayham Arsenal 20x9" with 35" Comforcer tires
Soon to come in spring 5ĒRC lift!!!
Muzbomb is offline
post #38 of 42 (permalink) Old 01-15-2020, 08:35 PM
rockn69's Avatar
Why do you think the Boost from OBD port is not good enough? I would guess it is as accurate (or very close) as a manual gauge. You'll see how inaccurate you coolant temp gauge is in the dash compared to the CTS
Summit White
rockn69 is offline
post #39 of 42 (permalink) Old 01-15-2020, 08:43 PM
bellassaiw10's Avatar
The boost psi it pulls form is accurate, I have a separate boost gauge that I tapped for my pillar gauges and they read the exact same PSI. Now I have tried other Boost PSI's from the OBD2 port the were not accurate but my CTS2 is spot on with my separate gauge/sensor
Michael
09 LMM
Leveled, Deleted, and Tinted, 5" Flo-Pro SS, EFI by Kory Willis, PCV Re-route, Fass 150.
US Army Military Police
East Carolina Pirate Alumni
Amsoil Dealer
http://eastcarolinasynth.myamsoil.com
bellassaiw10 is offline
post #40 of 42 (permalink) Old 01-15-2020, 08:44 PM
rockn69's Avatar
Hey Muzbomb, I sent you a PM
Summit White
rockn69 is offline
