FASS Titanium Series Fuel Pressures - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 14 (permalink) Old 06-26-2012, 06:43 PM Thread Starter
ippielb's Avatar
I have a 2006 duramax LLY with a FASS fuel pump, i have a fuel pressure gauge hooked up and my pressure i get at idle is below 5. It is an autometer. The pressure fluctuates from 5 to barely 1. Is my gauge going?
ippielb is offline
post #2 of 14 (permalink) Old 06-26-2012, 10:02 PM Thread Starter
ippielb's Avatar
I also just put all new fuel filters on the truck, the one on the engine, and the two on the FASS lift pump. I want to try the 5 gallon bucket trick, but am not sure exactly what it entails. What kind of connections are needed to thread into the fuel pump on both sides? And what fuel line size?
ippielb is offline
post #3 of 14 (permalink) Old 06-27-2012, 07:03 AM
Im Superrrrr!
jmaz268's Avatar
Send a message via Yahoo to jmaz268
Is it adjustable? Which FASS pump is it?
Goes by John
--2001 ECSB
SDP Big Single, Wehrli Dual Fuelers, 50% sticks, Front Coilover Conversion, Anorexic .....much much more
Sponsored by Creatures of the Night Performance and SDP
--2005 CCLB Dually
The tow pig
Tuned and Edge Insight CTS
jmaz268 is offline
post #4 of 14 (permalink) Old 06-27-2012, 08:11 AM Thread Starter
ippielb's Avatar
I believe it's the 95 titanium.
ippielb is offline
post #5 of 14 (permalink) Old 06-30-2012, 11:30 AM Thread Starter
ippielb's Avatar
Still running below 5psi at idle, and then now it's started to go back to 1psi at idle, and 0psi at any kind of throttle.
ippielb is offline
post #6 of 14 (permalink) Old 06-30-2012, 11:54 AM
like a Ninja
guytonLBZ's Avatar
how long have you had the pump? id give FASS a call
guytonLBZ is offline
post #7 of 14 (permalink) Old 06-30-2012, 05:35 PM Thread Starter
ippielb's Avatar
The pump says it was manufactured June 2011. I will give FASS a call on monday thanks.
ippielb is offline
post #8 of 14 (permalink) Old 07-03-2012, 10:25 AM
Try taking the return line off and fitting off of the pump and you will find a spring and ball behind that fitting. Stretch that spring about 1/4 of an inch and see if the pressure is around 8-10 psi and if it fixes the issue I can send out a replacement spring.
FASSAshley is offline
post #9 of 14 (permalink) Old 08-04-2012, 07:57 PM Thread Starter
ippielb's Avatar
I did that and it fixed the pressure, it is around 9 PSI now. Drops to 7-8 under heavy throttle.
youtube.com/ippielb
2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax - NADP Race Transmission - NAPC Built Transfer Case - ATS Trans pan - 3" high flow y-bridge - 3" erg delete tube - AFE Stage 2 intake - AFE 3" hot side intercooler pipe - Snow Performance Methanol Injection - FASS 150gph Titanium Series Pump - EFI Live DSP5 - PPE Race Valve - PPE Fuel Rail Fitting - 3" AFE Ceramic Downpipe - 4" Straight Pipe - BD Exhaust Manifold - BD Stainless Up Pipes - Yukon Grizzly Locker - Mag-Hytec Diff Cover - Cognito Traction Bars - Leveling kit - Zone Upper Control Arms - Air Lift Air Bags - 33" Hankook RT03 - 18" XD Addict Rims - HID's all around LED taillights and mega 3rd brake light - Autometer Fuel Pressure, Boost, and Pyro Gauges
ippielb is offline
post #10 of 14 (permalink) Old 01-21-2020, 06:15 AM
Jwaggonersr's Avatar
After 4 days on the New FASS mine has started the dreaded loping, Thinking its actually the FPR valve. It will be at the parts store today so we shall see. Guess I'll need to get me some fancy cab gauges and install them so I can watch pressures. Might just be easier to get a tuner, but Im not a fan of "Tuners" on stock trucks. Its a total struggle since my oldest boy is a Cummings guy, youngest is a Power Stroke guy and I like Duramax. Too each there own though, I help them they help me. All I hear daily is you need to get you a Edge!!
denarli6.6 likes this.
Jwaggonersr is offline
