Anyone running kennedy LP on lly? - Page 5 - Chevy and GMC Duramax Diesel Forum
 11Likes
post #41 of 50 (permalink) Old 02-26-2019, 07:44 AM Thread Starter
jwelder3's Avatar
Originally Posted by Trucklover63 View Post
I used two of these and plumbed them.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Just looked these up. Thanks
05 Silverado 2500HD LT CC 4x4 LLY 280k miles
LBZ mouthpiece. PCV reroute. JK LP. Edge monitor.
P/S cooler.
jwelder3 is offline
post #42 of 50 (permalink) Old 02-26-2019, 08:18 AM
LHN...We ARE the Joneses
Looks like the Hastings side mount, relabeled for wix.
Most all filter mfr's offer a filter head. Some are top mounts (Baldwin), others are side mounts, and many offered are relabeled from another source.
jwelder3 likes this.
Hook'em_Horns! is online now
post #43 of 50 (permalink) Old 02-26-2019, 09:39 AM
407driver's Avatar
When I added the dual Kennedy pumps I also put a dual filter/separator immediately after the lift pumps. I also kept the stock filter in place up front. The lift pumps really help if somebody runs your truck empty. I also got the fuel test port gauge. I check every oil change and once the pressure drops enough it's time for a filter change.
You would be better off moving the WS/Filter to be located before the LP. It works better in suction (before the LP emulsifies any water with the fuel) than in pressure.
The second filter works better under pressure so it should be after the LP.
FASS 95 Lift Pump (with Baldwin filters), Edge Insight CTS Monitor on a Windshield Mount, Nicktane Fuel Filter Adapter w/ CAT 306-9199 UHE tertiary fuel filter, Bilstein 5100 Stock Height, MBRP Downpipe back 4" exhaust with muffler and FTE 30" resonator/muffler, Sinister EGR Delete, Tuned but wont say who did it, Bushwacker Bed Rail Caps, AMP Research Bedstep, Fumoto oil drain valve, Dorman PS Oil cooler, Pioneer AVIC 7200NEX GPS/Stereo, Air Lift LoadLifter 5000 Air Bags.
407driver is offline
post #44 of 50 (permalink) Old 02-26-2019, 10:52 AM
I've been thinking about that for about six months now Agree it is better to suck through the water separator. I do get water out of my separator pushing fuel through it.
2017 Sierra 2500HD Denali Dmax
2011 Silverado 3500HD Dually Dmax
Trucklover63 is offline
post #45 of 50 (permalink) Old 02-26-2019, 11:07 AM
That will work, it's just more efficient at water removal the other way around.
post #46 of 50 (permalink) Old 06-10-2019, 07:51 PM
DRC67's Avatar
I just bought a Kennedy dual lift pump. I have the wiring done, I just need to install the pumps, extra filtration and fuel lines. I checked the wiring on it, and had ohm reading (closed) on the wires to the oil pressure switch when the pickup was off and when I started it the oil pressure switch had an infinitive (open). Is the oil pressure switch suppose to be open when it senses pressure?
The reason that I am installing a lift pump is that when I am towing a heavy load the pick up goes into limp mode with the code for low rail pressure. I was told that when the fuel heats the rubber hose, it will collapse causing the low rail pressure code to come in. A lift pump should eliminate this from happening.
2008 LMM GMC CCSB
EDGE INSIGHT PRO CTS2
DRC67 is offline
post #47 of 50 (permalink) Old 06-10-2019, 10:47 PM
D_R_C's Avatar
BUT, if your rubber fuel lines are collapsing a liftpump is only a bandaid.
The fuel lines should really be checked out and replaced if they are bad.
Dan
EFILive TCM Duramax Tuner
DHD PCV Re-Route
AirDog 4G100
D_R_C is online now
post #48 of 50 (permalink) Old 06-10-2019, 11:59 PM
Originally Posted by DRC67 View Post
I just bought a Kennedy dual lift pump. I have the wiring done, I just need to install the pumps, extra filtration and fuel lines. I checked the wiring on it, and had ohm reading (closed) on the wires to the oil pressure switch when the pickup was off and when I started it the oil pressure switch had an infinitive (open). Is the oil pressure switch suppose to be open when it senses pressure? ...
Yes. I did mine in Oct. '17. I had the very rare bad OPS. Ohm readings were correct (closed when no pressure; open when it senses pressure). But when there was actual voltage applied from the controller (about 11.3v for what it's worth), the OPS stayed closed (conducted) when there was oil pressure. Again, a rare failure, but just my luck.
If you have installation questions or problems, John Kennedy is very good about responding to emails!
DRC67 likes this.
2004.5 Silverado 3500 SRW 4x4, D/A (LLY), Ext. Cab, Long Bed
engineer837 aux rad, TxC CAI, LBZ MP, Scangauge II, Nicktane aux filter head, KD lift pump, 2008 PS pump, 2011 hydroboost, Frederico Swaybars, Rancho 9000XL, Torklift StableLoads, BFG AT/KO2, Lance 835 Camper often in the bed.
jake111 is offline
post #49 of 50 (permalink) Old 06-11-2019, 01:54 AM
407driver's Avatar
The LP will mask the problem. This is the solution, with LP or not:
https://www.duramaxforum.com/forum/d...nder-load.html
DRC67 and LMLLover like this.
post #50 of 50 (permalink) Old 06-11-2019, 07:54 PM
DRC67's Avatar
Thanks for the replies. It only goes it to limp mode while towing a heavy load. If it continues to do it after the lift pump is installed I will check it out further to find out what the problem is.
Sent from my Nexus 9 using Tapatalk
2008 LMM GMC CCSB
DRC67 is offline
Similar Threads
Air Dog LP jaredXwoodsman Performance Upgrades 4 06-01-2012 02:15 PM
Lp???? tiborcser14 07.5-10 LMM Performance Parts Discussion 0 03-18-2012 03:02 PM
Raptor 150 LP Price DURAMAXD219 Vendor Price Request ( Site Vendors Only Respond) 4 02-20-2012 01:15 PM
LP + Aeroforce + fuel PSI senor = ???? 45cal4life Gauges, Electronics and Wiring. 1 05-18-2011 06:00 AM
LP install, on all the time or 15psi hobbs switch? pwrtripls1 04.5-05 LLY Performance Parts Discussion 0 06-30-2009 06:51 AM
