Nitrous questions. - Chevy and GMC Duramax Diesel Forum
Propane/Nitrous/Meth Discuss all your propane/nitrous/meth stuff here.
post #1 of 8 (permalink) Old 04-20-2015, 09:18 PM Thread Starter
Maxed 08's Avatar
Nitrous questions.
I have a 07 classic gmc 2500 HD with all the normal goodies, efi live by atp, built Suncoast trans with 1056 converter, ad2 lift pump, and so on, everything else is in my sig. The truck smokes heavy at wot on the race tune and I was just toying with the idea of adding say a 50 shot of gas to clean up the smoke. I said if I were to do it I'd want to use a wot micro switch in conjunction with a rpm window switch to make sure everything came on and went off when I wanted it to. My question is, with that small of shot of gas would it be necessary to get rob to mod the tune?
2007 GMC Sierra 2500 HD Efilive by Idaho Rob w dsp5 switch, built trans with gmax 6 and 1056 TC, 150 lift pump, 4in dual exh, s&b intake,tie rod sleeves,DHD centerlink brace, 3in drop shackles, caltracs, pcv reroute,resonator pluged, egr blocker plate,autometer gauges,20x9 0 offset gear 726 wheels and 305/50/20 Toyo proxes st.
RIP 2008 Chevy 2500 HD 8.22 @ 82 1.71 60ft
Maxed 08 is offline
post #2 of 8 (permalink) Old 04-20-2015, 10:22 PM
Robby05's Avatar
You need a bigger turbo before you play with nitrous. Your running out of air is why you can't clean up all the fuel, it's the nature of the beast running a stock turbo max effort tune. Log it & have Rob pull some of the fuel.
Edit* make sure you don't have a boost leak
05 GMC 3500 SRW ECLB, EFI by Kory Willis, Built trans w/1056 converter, Raptor 150, built front end, DHD brace, 4" straight exhaust, banks air intake, afe mp, Profab EGR delete, Insight CTS.
Never water yourself down just because someone can't handle you at 100 proof
Robby05 is offline
post #3 of 8 (permalink) Old 04-21-2015, 07:45 PM Thread Starter
Maxed 08's Avatar
I understand the reasoning of why my truck smokes at wot, and I do agree I need more air, just don't have the coin to drop on the Danville 68 that I want and thought that a small shot of nitrous would solve my air deficiency without breaking the bank and hopefully the motor as well.
Maxed 08 is offline
post #4 of 8 (permalink) Old 04-22-2015, 07:52 AM
lparrill's Avatar
I don't think it would be a bad deal. Essentially nitrous is air in a bottle. In the tune make sure you drop some timing off
Levi
04.5 GMC CCSB LLY - Code name- PPRWT - Built Motor, Built Trans, Big Twins, Dual CP3, etc - HSP l Industrial l LDS l Burkette Racing l Danville l Suncoast l Socal l Bullsye
05 Chevrolet CCSB LLY - ADII, Profab EGR delete, 4" exhaust, Built trans
lparrill is offline
post #5 of 8 (permalink) Old 04-22-2015, 12:35 PM
CaptPhil's Avatar
Do it, you don't need a bigger turbo, that's what nitrous is for. Just turbo in a bottle.
2005 LLY CC/SB
Big Dipper Trans
Bullseye S366
[email protected] w/ stock injectors, stock cp3
2005 LLY EC/SB
Built motor
Triple turbo
Limitless Diesel Comp Trans
100% injectors
[email protected] Fuel only
CaptPhil is offline
post #6 of 8 (permalink) Old 04-22-2015, 12:41 PM Thread Starter
Maxed 08's Avatar
That's what I thought?
Maxed 08 is offline
post #7 of 8 (permalink) Old 04-23-2015, 04:42 PM
Robby05's Avatar
Nitrous for dummies? - Duramax Diesels Forum
Here's some good info on nitrous & tuning. I learned some from it. Sounds like it would do what you want. Never mind my first post
Robby05 is offline
post #8 of 8 (permalink) Old 05-04-2015, 08:13 AM
#SecretSquirrel
TowU4Free's Avatar
Send a message via Yahoo to TowU4Free
I read that thread! I can get a kit pretty cheap and i think itd be a fun little add-on. My tuner doesnt seem very thrilled about it though so ill probably hold out on it for now.
07.5 LMM "CL1MAXN"
Some Detrimental Go-Fast Goodies...
7.30 @ 95MPH Thanks To..
Mark, Evan, And Dan
TowU4Free is offline
