Another Meth question - Chevy and GMC Duramax Diesel Forum
Propane/Nitrous/Meth Discuss all your propane/nitrous/meth stuff here.
post #1 of 3 (permalink) Old 06-13-2015, 09:30 PM Thread Starter
As always, I'm wanting more from my truck and have started to research Meth. My question is from what i have read, the Meth doesn't make as big of a difference on a turbo that is near maxed out. I believe my Stealth is running near the max of it's capability. If i run Meth i am looking at the Snow Boost Cooler Stage 2 and plan on only running the Boost Juice. Yes i know there are cheaper routes but i just want to make sure i get a good quality consistent mix. Does anybody have experience in a similar situation?
01 ECSB LB7 4x4
Stealth 64 Turbo
30% Exergy Injectors
Exergy LBZ Sportsman
Built Trans
Built front end
Other supporting mods
NRA223 is offline
post #2 of 3 (permalink) Old 06-13-2015, 09:44 PM
DaJokr's Avatar
Blue washer fluid is consistent, 49/51 I believe. That's why lots of guys use it. How much research have you done already?
Beastly Build
LBZ Drag Racing
2006 GMC LBZ 4x4 CC/SB
1/4 Mile [email protected]
1.793 60'
DIED 09/19/17 11:02AM
REVIVED 12/21/17 3:57PM
DaJokr is offline
post #3 of 3 (permalink) Old 06-14-2015, 07:04 AM Thread Starter
I've read about people having issues with clogged nozzles and whatnot using the washer fluid. I've been searching here and on DD, but it seems like most of what i come across is towing and mileage set ups and stock turbo trucks. That's also when i found some people saying that if a turbo was near it's max it wouldn't help as much.
01 ECSB LB7 4x4
Stealth 64 Turbo
Built Trans
Built front end
NRA223 is offline
