Water/meth - school me - Chevy and GMC Duramax Diesel Forum
Propane/Nitrous/Meth Discuss all your propane/nitrous/meth stuff here.
post #1 of 3 (permalink) Old 04-16-2016, 09:05 AM Thread Starter
oscyjack's Avatar
So i'm pretty well sold on Water/Meth injection. I don't care about the extra power, but I love that fact that it will clean the top end of my engine. I'm in the build planning stage as I have most of the supporting mods installed or already ordered.
What I'm wondering is, how to get it working and how it plays with an existing EFIlive PPEI DSP5. Is it a separate entity as far as usage? Or do I need to have my tunes re-customized.
Additionally, in regards to when used in conjunction with a "race pipe"/egr delete. Most manufacturers of EGR deletes allow for the addition of a few more 1/8NPT bungs for addition of water/meth and boost gauges or NOS. When requesting additional bungs for the purpose of water/meth injection, does specific placement along the boost tube matter?
Lastly, if I wanted to use water meth in conjunction with a boost tube mounted boost gauge, can the meth injectors and boost gauge be placed in the same tube? Does the boost gauge need specific placement either pre/post injectors?
Thanks
jack
LMM CCSB with stuff
oscyjack is offline
post #2 of 3 (permalink) Old 04-17-2016, 05:04 AM
CaptPhil's Avatar
personally I think it is a waste of money, and yes I ran a kit for about 5k miles.
you don't need to be retuned.
it should probably go after the boost line but they can be in the same tube.
Sent from my SM-G900T using Tapatalk
2005 LLY CC/SB
Big Dipper Trans
Bullseye S366
[email protected] w/ stock injectors, stock cp3
2005 LLY EC/SB
Built motor
Triple turbo
Limitless Diesel Comp Trans
100% injectors
[email protected] Fuel only
CaptPhil is offline
post #3 of 3 (permalink) Old 04-17-2016, 07:41 AM
LHN...We ARE the Joneses
Moving thread to Meth section....you'll find most of your answers here
Propane/Nitrous/Meth - Chevy and GMC Duramax Diesel Forum
StepChild cleaned his up spotless running just H2O....also stretched that van out to 30mpg too.
Hook'em_Horns! is online now
